Go to Post The stated goals of FIRST are to inspire a culture that values science and technology. Inspiration needs Motivation. What motivates people? Competition. - Dmentor [more]
Unread 27-03-2006, 17:59
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Replicating parts of drawings
What I'm trying to do with the sketch below is to continue on to make 30 of those rectangles in an exact row. I've tried using copy/paste but I can't get it to paste where I want it, it'll show up just offset overlaying the original. When I drag it around, it won't snap to the grid unlike if I were to draw it from scratch. I've already done a differnet part drawing the rectangles one by one but I'd like to know if there's a better way and how. If you need me to be more descriptive, lemmie know. Thanks in advance for any help.
-Mike
What I'm trying to do - Continue the rectangles along this way in a perfect row.
You start with a bag full of luck and an empty bag of experience. The trick is to fill the bag of experience before you empty the bag of luck.
Unread 27-03-2006, 18:02
sburro's Avatar
sburro sburro is offline
AKA: Joe
FRC #0663 (crusaders)
sburro will become famous soon enoughsburro will become famous soon enough
Send a message via AIM to sburro
Re: Replicating parts of drawings
-Mike
In solidworks, I would use the mirror option, or the linear patern. I do not know if this is helpful
K.I.S.S
Keeping It Simple Stupid
Clark Gilbert's Avatar
Clark Gilbert Clark Gilbert is offline
Clark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond reputeClark Gilbert has a reputation beyond repute
Use the "rectangular pattern" button that is available in sketch mode for Inventor.
Purdue Alumni
Cummins, Inc.
Unread 27-03-2006, 18:13
Ok, I got it to replicate with the pattern tool, but have a new problem - It's replicating up and down, whereas I want it to go to the right. I can't seem to figure out how to rotate it in the tool. Would I have to hit ok, then rotate the whole thing after?
EDIT * Nevermind, I got it. Thanks for the tip. =)
Unread 27-03-2006, 18:19
Ben Martin's Avatar
Ben Martin Ben Martin is offline
Long Distance Mentor
FRC #0225 (TechFire)
Ben Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond reputeBen Martin has a reputation beyond repute
What are you drawing? It looks like a vex part.
Unread 27-03-2006, 18:25
After extensive searching the ONLY parts I could find from VEX were the threaded rods, and those were on fcl. So I'm going to be putting ALL my vex parts into inventor 10 and probably going to put them on my server when they're done. I'm in the middle of building my own robot for the '05 game, scaled down, because I want to try a design I came up with but was never used by our team last year. Instead of just diving in and building, I want to build it in inventor first... Sort of like my own, non time-limited build season.
Unread 27-03-2006, 18:46
Ben Martin's Avatar
Try www.vexcad.com, they have downloadable parts.
Unread 27-03-2006, 19:21
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Why did you draw 2 of them? You only need to draw one most of the time and then perform some sort of Linear Pattern option.
Unread 27-03-2006, 19:46
BMartin, thank you very much, I hadn't seen that before. It's not ALL the parts but it will certainly save me a lot of time!
And Elgin - I had started to draw them the hard way when I posted here.
Unread 27-03-2006, 21:00
CraigHickman
Posts: n/a
When doing a linear pattern, use rectangular pattern. Select the top horizontal line as your direction, (for direction 1), then select your interval and number of items.
Unread 08-04-2006, 13:03
negfrequency's Avatar
negfrequency negfrequency is offline
the guy with the drawings
AKA: Willomatic
FRC #1559 (Devil Tech)
negfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nicenegfrequency is just really nice
Send a message via AIM to negfrequency
Yea rectangular pattern is pretty useful. You can even send the items at an angle, pending on the line that you choose as a reference. Besides doing it in the drawing though, you can also rectangular pattern the features and even the parts in asseblies. Keep in mind that the circular pattern tool exists too!
Spare Parts Tips EricH General Forum 1 27-03-2006 10:07
**IMPORTANT FIRST EMAIL**/Replacement Parts Deadline Reminder AmyPrib FIRST E-Mail Blast Archive 0 11-01-2006 11:48
**FIRST EMAIL**/Replacement Parts Request Process Pat Fairbank FIRST E-Mail Blast Archive 0 04-01-2006 17:26
Rules on making spare parts fyi DougHogg General Forum 0 02-04-2003 16:18
Inventor drawings of parts from kit patrickrd Inventor 1 11-01-2002 14:16
