Re: pneumatics or hydraulics ?
Thank you for your help.A lot more help than I expected.This chamber
I want to build will also hold the computer and lcd monitors(2).The chair won't have to be so strong as to lift a person ,just side to side and front and back movement.Also would work as flight simulation. Thanks Rex |
Heres an interesting prefab motion chair I came across. Maybe it can give you some ideas? Link below...
http://shop.rightthing.nl/index.php?...products_id=17 Last edited by BoyWithCape195 : 28-03-2006 at 16:40. |
Im not sure I understand why people are saying pneumatics are rough, and hydraulics would be smoother?
Pneumatics use air, which will compress. Pneumatic cylinders act like adjustable air shocks, or air springs. Hydraulics use oil, which is un-compressible. When you extend a hydraulic piston to a certain position it will be rock solid and will have zero give. With hydraulic valves you can let small rates of fluid through - they are proportional valves, but you can also let large amounts of fluid at high pressure through, and send very violent jerks into the chair someone is sitting in. Last edited by KenWittlief : 28-03-2006 at 19:36. |
I think that everyone means that it will be smoother(if u want it that way) with hydrolics, with air its very fast and harder to control accurately.
To me it think i would need to know more about the kind of motion you want, it you want it smooth and undeniable but still very flexible(in options) then go pneumatics, if you want insta-action that is giving but sometimes "mushy" then go pneumatics the choice is ultimately up to you. |
Thanks for the reminder, I just still say hydraulics because you can regulate the stroke . I am not sure if it is the same on pneumatics, because I have never seen a device that can do that. |
I have a post puller or frame machine and it uses pneumatics and
hydraulics. the pump is connected to my compressor witch pumps the fluid into the ram,slow but real strong. If this chair is to react to video game software ,it needs to be quick and smooth.Maybe even use an electric motor ,that would pull and push the chair from side to side,or just push with an opposable spring of some kind.Braking would be quicker motion forward and a slower motion coming back to normal position and the reverse of that for acceleration.Also the chair would have to lean and accelerate at the same time.Any Ideas I can get get would greatly appreciated. |
| pneumatics for 2006 competition? | Joobacca | Pneumatics | 10 | 21-01-2006 23:14 |
| Using previous years pneumatics? | ChuckDickerson | Pneumatics | 0 | 30-01-2005 18:22 |
| General Pneumatics | Drok00 | Pneumatics | 8 | 11-01-2005 23:35 |
| pneumatics and joysticks | Jared Stofflett | Pneumatics | 3 | 24-02-2004 23:56 |
| pneumatics and joysticks | Jared Stofflett | Programming | 1 | 24-02-2004 17:45 |
