Go to Post Having someone with as much mainstream appeal as will.i.am is a great strategy to draw large amounts of attention to a program that has been relatively hidden to the masses. - Karthik [more]
Unread 28-03-2006, 22:49
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Shooter Help
Hey folks
We have a shooter problem. Basically, we don't have enough friction on the balls as they go through the mechanism. Since Ff = uk*Fn and we've tried everything we can to increase uk (even double-sided tape won't get us enough grip on the balls), we need to increase the normal force by squeezing the balls more. However, this is a large problem because we built the spinning wheels of our shooter too far apart. We can't move the actual spinning wheels closer together, since they are driven by a single motor, and the power transfer from one side to another is done by a horizontal shaft. We cannot easily shorten the shaft at the competition, as it would mean basically re-sizing the entire shooter assembly.
We have decided we need to somehow legally increase the radius of the skyway wheels so that they crush the balls more as the balls pass through. However, simply wrapping things like entire rolls of duct tape around the wheels is out, as duct tape is adhesive and therefore against the rules. I thought of saran wrap, but it would be difficult to apply and keep on. The current competition plan is to just put weather stripping around the wheels to again try and increase the coefficient of friction, but we don't have high hopes. Can anyone think of a clever, legal way to make our shooter better?
Replacing the wheels with slightly larger wheels is a distant possibility (taking the wheel axles out is nearly as difficult as shortening the shaft)
Ideal Alliance Structure Lil' Lavery Rules/Strategy 34 22-04-2006 18:21
Van De Graff effect on shooter Not2B Technical Discussion 26 09-03-2006 03:13
2-Speed Shooter Gearbox JVN Technical Discussion 4 08-02-2006 13:52
Shielding the Shooter WebWader125 Rules/Strategy 10 05-02-2006 20:05
Team 1280 Prototype Ball Shooter Shelbykr7 Robot Showcase 8 25-01-2006 09:57
