Go to Post Without mentors, you wouldn't even be participating in FIRST. Your team wouldn't exist, and FIRST as a program wouldn't exist. If it did, it'd just be another form of a science fair. - Cory [more]
Unread 28-03-2006, 23:48
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Shooter Help
The belting is your best bet. I would go with rough top, or a smoother finish, rather than wedge. Bring really good contact glue and small screws and a belt sander. Run the shooter at a reasonable speed use the belt sander (80 grit or so) to get the wheels closer to flat, glue and screw the belting on and you should get both, better grip and a larger wheel. Normal procedure to make the wheels flat is a metal lathe, we have done it that way I've never been present. I did try a router once.....Not a good idea. The carpet on the skyway wheels last year did a nice job on our non belted wheels that's why the sanding suggestion. BTW your wheels should be spinning about 1200 give or take a little 2400 would be the case if you were only driving one side and a had a non moving side.
Ideal Alliance Structure Lil' Lavery Rules/Strategy 34 22-04-2006 18:21
Van De Graff effect on shooter Not2B Technical Discussion 26 09-03-2006 03:13
2-Speed Shooter Gearbox JVN Technical Discussion 4 08-02-2006 13:52
Shielding the Shooter WebWader125 Rules/Strategy 10 05-02-2006 20:05
Team 1280 Prototype Ball Shooter Shelbykr7 Robot Showcase 8 25-01-2006 09:57
