Go to Post Just remember, FIRST isn't about the robot, just have fun, meet new people, and try to learn something new. Killing yourself with inhumane amounts of pressure just isn't fun for anyone. - Ian W. [more]
Unread 28-03-2006, 22:49
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Shooter Help
Hey folks
We have a shooter problem. Basically, we don't have enough friction on the balls as they go through the mechanism. Since Ff = uk*Fn and we've tried everything we can to increase uk (even double-sided tape won't get us enough grip on the balls), we need to increase the normal force by squeezing the balls more. However, this is a large problem because we built the spinning wheels of our shooter too far apart. We can't move the actual spinning wheels closer together, since they are driven by a single motor, and the power transfer from one side to another is done by a horizontal shaft. We cannot easily shorten the shaft at the competition, as it would mean basically re-sizing the entire shooter assembly.
We have decided we need to somehow legally increase the radius of the skyway wheels so that they crush the balls more as the balls pass through. However, simply wrapping things like entire rolls of duct tape around the wheels is out, as duct tape is adhesive and therefore against the rules. I thought of saran wrap, but it would be difficult to apply and keep on. The current competition plan is to just put weather stripping around the wheels to again try and increase the coefficient of friction, but we don't have high hopes. Can anyone think of a clever, legal way to make our shooter better?
Replacing the wheels with slightly larger wheels is a distant possibility (taking the wheel axles out is nearly as difficult as shortening the shaft)
Unread 28-03-2006, 22:51
Re: Shooter Help
Replace the wheel on one side with a fixed post. Your balls will have an interesting side spin, but they will shoot. Try for about one inch of compression. I'm guessing that you won't find anything that will make your Skyways bigger. I guess that you could replace one of the Skyways with a wheel that is one inch larger, but that could be really complicated.
Unread 28-03-2006, 22:53
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
Re: Shooter Help
Wrap roughtop or wedgetop belting around your wheels to increase the OD. You can do this legally with rivets or screws.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 28-03-2006, 22:58
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Re: Shooter Help
The above are available from McMaster Carr . Search for "Incline conveyor belting".
2001-2004: Team 100
2006-Present: Team 254
Unread 28-03-2006, 23:04
Karthik Karthik is offline
VEX Robotics GDC Chairman
Karthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond reputeKarthik has a reputation beyond repute
Re: Shooter Help
Come visit our pits on Thursday of the GTR. I've got some ideas that could alleviate your problems. We're always willing to help a team, especially one that we won a regional with.
:: Karthik Kanagasabapathy ::
"Enthusiasm is one of the most powerful engines of success. When you do a thing, do it with all your might. Put your whole soul into it. Stamp it with your own personality. Be active, be energetic, be enthusiastic and faithful and you will accomplish your object. Nothing great was ever achieved without enthusiasm" -- R.W. Emerson
My TEDx Talk - The Subtle Secrets of Success
Full disclosure: I work for IFI and VEX Robotics, and am the Chairman of the VEX Robotics and VEX IQ Game Design Committees
Unread 28-03-2006, 23:12
MrBamboo MrBamboo is offline
Lead Designer of #1888 (Plano West)
AKA: Fei
FRC #1888 (Sigma F)
MrBamboo is an unknown quantity at this point
Re: Shooter Help
I second the idea of screwing multiple layers of wedge top treads around the skyway wheels to increase the radius.
Unread 28-03-2006, 23:18
Re: Shooter Help
If you go with attaching conveyor material on wheels spinning 2500 rpm you want to make sure it is attached REALLY well, and that it is evenly spaced around the perimeter. You run a real risk of hurling conveyor material around the arena at 25 MPH, or having your mechanism shake itself apart from vibration. I would think long and hard before attempting this -- it's not like riveting conveyor material onto wheels spinning at a few hundred RPM.
Unread 28-03-2006, 23:25
Vince lau's Avatar
Vince lau Vince lau is offline
Building robots since 1995
FRC #4914
Vince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond reputeVince lau has a reputation beyond repute
Send a message via MSN to Vince lau
Re: Shooter Help
thanks karthik, we'll drop by on Thurs.
2005 - GTR WFFA
2006 - Waterloo Regional Champions with 1114 and 1503
2010 - Waterloo Rookie inspiration and Highest Rookie Seed, #2 Alliance Captain, Semi-finalists.
2011 - Waterloo Finalist thanks 1310 and 610
2014 - imagery and rookie allstar award gtr west
2014 - rookie inspiration and winners with 188 and 610 north bay
Unread 28-03-2006, 23:43
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
Re: Shooter Help
foam padding of varying densities could be tried, they limit destruction of the balls, and they are easily interchangable if there is a need.
Blargha!
Unread 28-03-2006, 23:48
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Shooter Help
The belting is your best bet. I would go with rough top, or a smoother finish, rather than wedge. Bring really good contact glue and small screws and a belt sander. Run the shooter at a reasonable speed use the belt sander (80 grit or so) to get the wheels closer to flat, glue and screw the belting on and you should get both, better grip and a larger wheel. Normal procedure to make the wheels flat is a metal lathe, we have done it that way I've never been present. I did try a router once.....Not a good idea. The carpet on the skyway wheels last year did a nice job on our non belted wheels that's why the sanding suggestion. BTW your wheels should be spinning about 1200 give or take a little 2400 would be the case if you were only driving one side and a had a non moving side.
Bongle's Avatar
Re: Shooter Help
These are all good ideas guys, thank you very much.
I thought of another one while talking to a teammate: a thick car timing belt as a rigid backing to weather stripping. The timing belt would increase the radius, while the weather stripping would increase the coefficient of friction. A long-enough timing belt would be wrappable around the wheel multiple times, and any little bumps would be smoothed over by the weather stripping layer. Any thoughts?
Unread 29-03-2006, 00:01
RogerR's Avatar
RogerR RogerR is offline
its spelled *ya'll*, not *y'all*
AKA: Roger Riquelme
FRC #3844 (Wildbots)
RogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond reputeRogerR has a reputation beyond repute
Send a message via AIM to RogerR Send a message via MSN to RogerR
Re: Shooter Help
you could also move the pairs of wheels closer to the centerline of the ball, or replace each pair with a single wheel. since the ball is wider in the center the wheels would contact it at its widest point, without having to increase the wheel size, or bring them closer together horizontally.
"But to say that the race is a metaphor for life is to miss the point. The race is everything. It obliterates whatever isn't racing. Life is a metaphor for the race." -- Donald Antrim
Unread 29-03-2006, 00:05
Scott Morgan Scott Morgan is offline
None #1138
Scott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura aboutScott Morgan has a spectacular aura about
Re: Shooter Help
nevermind, Roger beat me to it, and explained it better as well
Unread 29-03-2006, 00:12
run the trap!!!
Team Role: Human Player
Re: Shooter Help
-Get a garden hose or some sort of tubing, preferably something with a lot of traction.
-Split it down one side.
-Curl the cut hose around the rim of the skyway.
-Use rivets, zip-ties, or better yet wood screws to keep it on.
-Viola!
Unread 29-03-2006, 00:14
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Shooter Help
With how fast these will be spinning, please keep balance in mind.
Ideal Alliance Structure Lil' Lavery Rules/Strategy 34 22-04-2006 18:21
Van De Graff effect on shooter Not2B Technical Discussion 26 09-03-2006 03:13
2-Speed Shooter Gearbox JVN Technical Discussion 4 08-02-2006 13:52
Shielding the Shooter WebWader125 Rules/Strategy 10 05-02-2006 20:05
Team 1280 Prototype Ball Shooter Shelbykr7 Robot Showcase 8 25-01-2006 09:57
