#21
Re: Ball speed testing after matches
Assuming the measured length is 1 meter, there is a simple calibration that can be performed to check the speed tester. Simply hold it so the ball can drop through it vertically. Hold the ball close to the first sensor and drop it through. The ball speed should read 2.2 m/s.
Don't belive me? do the math! Hint d=(at^2)/2. If anybody needs more than that post here and I'll walk you through it. I figured this out for our own tester. ChrisH |
| Physics: ball launch using gravity | JoeXIII'007 | Math and Science | 8 | 02-03-2006 18:32 |
| side shooter | Korbin | Robot Showcase | 21 | 14-02-2006 17:23 |
| Speed Sensor for Ball Shooter | Justin Stiltner | Electrical | 15 | 28-01-2006 14:40 |
| Low quality 2X ball? | Rob | General Forum | 16 | 22-04-2004 22:36 |
| Knocking out Doubler Ball | mightywombat | Rules/Strategy | 47 | 23-02-2004 15:18 |
