Go to Post Learning by failure is quite common. - Gdeaver [more]
Unread 09-03-2006, 14:06
TubaMorg TubaMorg is offline
Programmermechanicalelect ricalcoach
AKA: Dan
FRC #1480 (Robatos Locos)
TubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond reputeTubaMorg has a reputation beyond repute
Shooter wheel balancing
So we noticed (but pretended not to) that our shooter wheel had a little vibration in it during testing right before shipping. Does anyone have any clever ideas on how to balance it? Obviously we would want to remove a little material from the heavy side (it's an 8" plastic wheel with rubber tread). I was thinking of spinning it a few times by hand and waiting to see which side ends up at the bottom. The problem with this is that the axel bearings are a little stiff, so this method may not be too reliable. Any cool ideas out there? I'm hoping to have time to fix it during our Lonestar Regional, you know how much free time there is! Or maybe we should just call it our ball agitator/shooter
Unread 09-03-2006, 20:39
Michael Corsetto's Avatar
Michael Corsetto Michael Corsetto is offline
Breathe in... Breathe out...
FRC #1678 (Citrus Circuits)
Michael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond reputeMichael Corsetto has a reputation beyond repute
Re: Shooter wheel balancing
One way to do it would be set up to beams about 4" apart parallel to each other. Then put an axel through your wheel and set the two sides of the axel on the beams with the wheel in the middle. Look for the side that falls to bottom, and START FILING
Mike C.
Team 1678: Citrus Circuits - Lead Technical Mentor, Drive Coach **Like Us On Facebook!**
Unread 09-03-2006, 20:41
It only has to last about three minutes. I wouldn't worry about it, unless the vibation threatens your structure.
Unread 09-03-2006, 20:47
DjAlamose's Avatar
DjAlamose DjAlamose is offline
AKA: Teh Albie
FRC #0279 (Tech Fusion)
DjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to beholdDjAlamose is a splendid one to behold
Send a message via AIM to DjAlamose
Originally Posted by Rick TYler
It only has to last about three minutes. I wouldn't worry about it, unless the vibration threatens your structure.
I agree, but it all depends on the amount of vibration. If you feel that it’s excessive then go ahead and try to fix it. But I wouldn't worry too much about it. There could be any number of things that are throwing it out of balance as so it might not just be the wheels (of coarse I’m thinking of a shooter with a drive train, but who would do that ).
WHAT TIME IS IT????? 279!!
2006 GLR Safety Award (2nd year in a row)
2005 National Xerox Creativity Award
2005 National Curie Quarter Finalist w/ 1126 and 180
2005 Buckeye Regional Champs w/ 67 and 274
2005 Buckeye Regional GM Industrial Design Award
2005 Buckeye Regional Safety Award
2005 GLR Quarter Finalist
2005 GLR Xerox Creativity Award
2005 GLR Safety Award
2004 Nationals Curie Division Finalist
2004 GLR Champs
2004 Buckeye Delphi Driving Tomorrow Award
2004 Buckeye Quarter Finalist w/ 1001 and 869
2003 GM Industrial Design Award GLR
2001 National Champs
Unread 09-03-2006, 21:31
in between teams
AKA: Luke Van Oort
Again, it all depends on where you mounted your vibration sensitive parts. Our wheel shook like there was no tomorrow. (maybe not as bad a s yours, but still pretty strongly) We fixed it, sort of. For us it was more of a aesthetics issue than a functionality problem. So, anyway, we got rid of the turreting action (for other reasons) and tightened some bolts. Now, instead of only having to shake itself, some 80/20, and sheet metal while mounted on a single turntable bearing, it had to shake the whole robot. It really couldn't overcome the inertia of the bot to produce meaningful shaking. Even if it did, it wouldn't have mattered much since all our electricals were mounted to Plexiglas which would absorb vibrations.
Team 1219: 2009 - Mentor
Unread 09-03-2006, 23:16
AKA: Dan
Our vibration isn't all that bad. As an ex-Navy mechanic, though, it sort of offends me I'm pretty sure the vibration is coming from the wheel, the shaft is good-n-straight with nice sturdy block bearings on either side of the wheel coupled via spider coupling to the motor. It really is sort of a low priorty fix right now, we need to complete some more important things first (like our ball feed). Just in case I have a kid standing around, though, I can have him work on it.
I think this idea should work I was hoping for something to do in place though.
Unread 10-03-2006, 00:23
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
Be sure to not completely ignore off balance wheels. Our wheel had part of the tread come off; the then massively off balance wheel rotating at 4000 rpm broke our rotator (this was during build).
If you're not going that fast, you shouldn't have to worry much though.
Unread 10-03-2006, 09:13
Dad1279 Dad1279 is offline
FRC #1279 (Cold Fusion)
Static and dynamic balance will be different. You may be better off with trial & error. Try a light weight in different spots around the wheel and see if it gets better. If it gets better, try more or less weight.
Unread 10-03-2006, 11:53
AKA: Dan
Excellent idea, at least we can try it in situ and see if it works. How to attach small weights, though? Perhaps small screws in the side of the wheel?
Unread 10-03-2006, 12:36
Elgin Clock's Avatar
FRC #0237 (Black Magic)
I'm sure the wheels are held at the manufacturing plant for them to some sort of trueness, but the higher RPM they spin the more you notice imperfections.
The wheels you are talking about were probably designed to go way slower than you are spinning them. How many wheelchairs do you know that have the front wheels spinning 20+mph? lol
Anyways, keeping that in mind, check your pillow block or whatever you are affixing it to your frame to. Make sure they are aligned right. One .050" difference in center lines of the block from the X axis will make your wheel wobble a heck of a lot at these high speeds.
Unread 10-03-2006, 15:05
AKA: Dan
Yes as you said the wheel we are using is normally a drive wheel (from NPC robotics), but they aren't made for the speeds we are using them at! I used a dial indicator to check alignment on the wheel and motor shaft and it was pretty good. But, it is quite possible that it has gone out of true since then. We use VERY high tolerance engineering (i.e. 1" +- .25") Maybe we should harness the vibration as a battery charging mechanism!
Unread 10-03-2006, 15:35
Manoel's Avatar
Manoel Manoel is offline
FRC #0383 (Brazilian Machine)
Manoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond reputeManoel has a reputation beyond repute
Send a message via ICQ to Manoel Send a message via MSN to Manoel
That's exactly what we did, except we sent it out to be balanced in a shop with specific equipment. They balance car and truck tires so a request to dynamic balance a small tire at 1500 RPM sounded a bit weird to them. Only cost $20 dollars, though. With guarantee (one of the tires was out of balance after a while so they redid it)!!
I think the machine uses lasers to detect the tire wobble, but I'm not sure. Anyway, it's a fancy machine.
That's probably not a solution now that your robot is gone, but you can try the low tech method described above. It won't be perfect, though, since you probably won't be able to balance it up to the high rotation speed we normally use in FIRST shooters.
Manoel Flores da Cunha
Brazilian Machine
Team # 383
Unread 27-03-2006, 18:34
Justin_302's Avatar
Justin_302 Justin_302 is offline
Justin
AKA: Justin
FRC #0302 (Mechanical Dragons)
Team Role: Driver
Justin_302 is on a distinguished road
Send a message via AIM to Justin_302
Ours were balanced professionaly. They are high speed gocart wheels.
Team 302
Unread 29-03-2006, 18:39
Dan,
I wanted to add some observation here. After two weeks of inspections, the teams that had problems with vibration were using small wheels designed for a much slower speed. As they brought them up to get near to the 12M/s speed rule, they would vibrate. Typically this was the 4" diameter vs. 6" diameter wheel chair type wheels.
Unread 29-03-2006, 18:47
AKA: Dan
Originally Posted by Al Skierkiewicz
Dan,
Sounds about right. Our's is 8" so at least we don't have to spin it TOO fast, although we are estimating 1200 rpm. Still faster than it was really designed for. Maybe the magical crate fairy will fix it for us! We will find out tomorrow!
How much of our wheel used for the shooter can be exposed? waialua359 Technical Discussion 4 14-02-2006 13:27
One or Two Wheel Shooter Nitroxextreme Technical Discussion 6 14-01-2006 01:10
How did you control your Robot? 1? 2? Wheel? How? ChrisCook Control System 9 17-05-2005 21:41
Clamping wheel hubs sanddrag Technical Discussion 7 29-02-2004 00:20
how can you use a gyro in autonomous mode magical hands Programming 3 02-01-2004 13:31
