Go to Post No Firsting way! - Tytus Gerrish [more]
Go Back   Chief Delphi > Competition > Regional Competitions
Unread 30-03-2006, 10:48
Sean Schuff's Avatar
Sean Schuff Sean Schuff is offline
Year 18 in FRC!
FRC #0093 (N.E.W. Apple Corps)
Sean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond reputeSean Schuff has a reputation beyond repute
"Random" Match List Generation
I've searched the forums for a discussion like this and found none. I'm curious to know if others have noticed this (and I'm sure many have) and what you think of it.
Our team attended the Wisconsin Regional a couple weekends ago and were very intrigued by the "randomness" of the alliance pairings in the quailfying matches. In addition to our own team's awareness of this, many other teams expressed that they noticed the same thing. As an example, our team played four matches in a row with team 525. We played against team 111 three times in a row (won 1 by some small miracle!) and team 111 played against team 494 four times! In our final three matches we either played with our against teams 1714 and 1732, both of whom played on the same alliance for the last three matches.
I'm not sure how the match lists are generated but sometimes it feels like there is a puppet-master working the strings. If the match lists truly are randomly generated then someone needs to work on the sophistication of their generator so there is a bit more mix to things. With 34 teams at the Wisconsin regional we should have played with and against every team there at least once. Instead we ended up playing with our against the same teams over and over again and never played with/against a handful of teams.
I don't want this to sound like sour grapes because it is anything but that. Regardless how many times we played against the WildStang juggernaut we still ended up seeded third and played respectably and we're proud of our performance. It would be nice to have the opportunity to play with some of these teams as well as against them. I can't imagine what it would be like for a rookie team to come in and find the deck "randomly" stacked against them.
Anyone else have thoughts on this or is this regional just a fluke in the pairings?
Thanks!
Sean
Every child. Every program. Everywhere.
Thanks Plexus Corp. for two decades of partnership and counting...your company gets it!!
www.nacteam93.com | Tesla Engineering Charter School
Unread 30-03-2006, 11:01
Re: "Random" Match List Generation
people have raised this issue before. Maybe its time to drive a stake through the random match generator and make something better.
You are right, during the seeding matches every team SHOULD play against and/or with all of the other teams at least once. So why do we assign matches at random?
Why not take the number of teams at the event, arrange a sliding schedule so the teams at the oppositie ends slide towards each other during the seeding rounds, and then assign the teams to those slots at random.
That way you wont have all the high number rookie teams at one end (together) and the low number veteran teams at the other (allied together). Something like a football pool - every team gets a slot, then those team slots are assigned to the sliding schedule at random?
The only way to verify the random-ness of the current system would be to collect all the data from each regional and do a statistical analysis. When you flip coins sometimes heads does come up 5 times in a row - if you are that team then it will not feel random, but the regional as a whole should average out to a random distribution.
maybe that kind of randomness is not what we really want? Maybe we want something more like the playoff tiers, except your team is not eliminated when you lose.
Unread 30-03-2006, 11:16
Software Engineer
VRC #0111 (Wildstang)
Rookie Year: 1995
I don't believe the problem boils down to just the algorithm used. There's a few tunable parameters in the generation algorithm and the setting of these will greatly influence the randomness. For instance, one setting is the minimum number of matches a team must "sit out" between rounds that they play in. If this is set too high then the generator becomes very constrained on which teams it can place in any given match. This is especially noticable at events with a relatively small number of teams (such as Midwest and Wisconsin). If they had reduced the match spacing, it would have been much more random but at the expense of some really short breaks between matches. I know at Midwest for example that we played every 20 minutes. It was barely enough time to make a few quick repairs and get back in the queue. It would have been really tough if that number had been reduced even more.
Unfortunately I think there's a bigger problem here: when you have 6 teams on the field at once, and you only have about ~30 teams in attendance, you don't have a lot to work with. Maybe FIRST needs to consider a game where it can be either 2-on-2 or 3-on-3 depending on the number of teams at the event or something.
Unread 30-03-2006, 11:52
Warren Boudreau Warren Boudreau is offline
FRC #0180 (Team SPAM)
Warren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond reputeWarren Boudreau has a reputation beyond repute
Another option would be to limit the number of matches that each team plays in a regional.
I'm guessing that the smaller regionals play a lot of matches.
Simply extend the time per match from 6 minutes to 8 or 9. Then crank the number of matches that a team sits out to a smaller number to increase the spread.
You'll have more time between rounds, but you'll play fewer matches. Which would you prefer?
Warren B
Pool Noodles. They're not just for bumpers anymore.
Unread 30-03-2006, 12:12
Year 18 in FRC!
That's a real double-edged sword, isn't it?! The nice thing about six teams on the field at a time is that all teams get more qualifying rounds which equates to more time to tweak an unruly robot and more time to play the game. For those teams that may only attend one or two events a year, more field time is a real bonus. Otherwise these teams are building a robot that sees action maybe a half dozen times.
The downside to more quailfying matches and more teams on the field, like you said, is the short duration between matches for any given team. We've dealt with short turnaround times in the past and it can be a real hassle, especially if things aren't going so well.
How about this for an off-the-wall game concept - not only random pairings but also a random number of robots on the field! Anywhere from 1-on-1 to 3-on-3! That would REALLY mix things up! ANd it would work for this years game! I think you're on to something Dave!
Unread 30-03-2006, 12:19
GaryVoshol's Avatar
Cogito ergo arbitro
The problem really is too much randomness, not too little. What we really want is a defined tournament scheme, not a random scheme. Total randomness can create some surprisingly non-random looking results.
There are very well defined schemes for tournaments involving 4 teams/individuals. Bridge, for example. Given "X" players (x divisible by 4), a schedule can be set up so that you are partnered with each other player once, and against every other player twice. (Since at any one time, you have one partner and 2 opponents.) Or for round-robin leagues, where every team plays every other team once.
I don't know if such schemes are defined for a 3v3 competition.
The restrictions on not playing too many matches within a given time period also puts constraints on the selection process.
(since 2004)
Unread 30-03-2006, 12:31
Raul's Avatar Unsung FIRST Hero
Raul Raul is offline
Somewhat Useful Person
no team (Formerly - Wildstang)
Raul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond reputeRaul has a reputation beyond repute
How about keeping the number of matches, but extending the day? Allow 8 or more minutes per match (instead of the usual 6 minutes) when the regional is small.
For example - MWR only had 60 total matches (12 per team for 30 teams). At regionals with 60+ teams (such as VCU), they were able to run 59 matches in the first day and 86 total matches. They did this by going from 9:20 AM to 4:12 PM at VCU versus 10:00 AM to 3:56 at MWR. So, if they ran the same schedule at MWR as VCU, they could slow down, still run 60 matches (12 per team) and not rush everyone on and off the field.
Warning: this reply is just an approximation of what I meant to convey - engineers cannot possibly use just written words to express what they are thinking.
Unread 30-03-2006, 12:50
I like this idea, but it would have to be part of the game from day one (kickoff).
Some teams have built simple purely defensive robots that are in-capable of scoring. They did this because they know their bot will be valuable when matched with shooters and dumpers
but if you put them on the field alone they will automatically lose every match (because they cannot score).
Unread 30-03-2006, 13:09
sw293 sw293 is offline
Former Coach (2005)
AKA: Scott Weingart
FRC #0293 (SPIKE)
sw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of lightsw293 is a glorious beacon of light
Most chess tournaments of the size of a FIRST regional are paired with what is called a swiss system. In round 1, the players are seeded (by rating), and split into top and bottom halves. The #1 seed in the top half plays the top seed in the bottom half, the #2 seed plays the second highest seed in the bottom half, and so on and so forth. In subsequent rounds the players are divided into groups by score, seeded inside those groups by rating, and each group is split into top and bottom halves and paired as above. The system's goal is to pair players who are playing well against one another. A variation is the accelerated swiss pairing system.
While the system as used in chess tournaments is not clearly not viable for a FIRST competition, the concept behind it (pair strong players against one another) should be.
Team 293
Uncrowned Champions, 2005 Philadelphia Regional
Champions, 2007 Chesapeake Regional
Unread 30-03-2006, 16:00
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
I don't ever think this match generator is going to be disseappearing anytime soon. Personally at the NYC regionals the matches were fairly random and so were the alliances. It made the event a little bit more exciting to see different alliances. Personally I like the randomness an event has. It gives teams a chance to change stratedgy to compensate for what they don't have. If anything the amount of robots on the field will be extremely more competitive, the only problem is the day would have to be extended or the time in between matches would have to be shortened so that each team can play all the scenarios.
Any thoughts ?
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
Unread 30-03-2006, 16:41
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
I haven't studied algorithms for generating matchlists. Superficially, it seems that repeat alliance partners and/or repeat opponents are more likely to occur
1) as the number of matches is increased -- if the event staff tries to schedule more matches while maintaining a larger minimum interval between appearances of the same team (say four matches off between field appearances) the result is that teams that have been on the field together once will share the field again, probably several times, and
2) as the number of teams is decreased -- for similar reasons.
To allow teams to share the field (as partners or opponents) with a wider variety of other teams, the match list must allow more variability in the interval between appearances of the same team.
It has been proposed here and in previous threads on this topic that, to prevent repeat field partners/opponents, the minimum interval between field appearances should be controlled in minutes rather than matches; i.e., increase the time interval between matches at smaller regionals, and allow more variance in the match interval between field appearances at larger ones. I think a statistical review of repeat field partners/opponents vs. appearance interval might support this proposal, but I don't have the time to do the analysis now. Any volunteers?
Richard Wallace
since 2003
Unread 30-03-2006, 17:34
I dont see why a short interval between two matches for one team would be a problem. In the finals you may play three matches back to back, depending on your last match of the semi finals maybe even 4 or 5.
If you have 60 teams at a regional, then there will be an average spacing of 9 matches between each teams time on the field. If a fixed pattern was used (instead of psuedo random) then you might end up with two matches back to back, but then you would also have two matches with 18 or 19 in between - so it would balance out over the 3 days.
Unread 30-03-2006, 17:44
Sakura141's Avatar
Sakura141 Sakura141 is offline
...muffins.
AKA: Debbie
FRC #0141 (Wo-Bot)
Sakura141 is a jewel in the roughSakura141 is a jewel in the roughSakura141 is a jewel in the rough
Send a message via AIM to Sakura141 Send a message via MSN to Sakura141
at the Midwest, us, 71, and another team (rookie), were on the same alliance in the same sides on the same positions. On the other alliance, only one changed, so basically the match was the same groups of people, except for one team. It was weird. Match 10, and then Match 15, and all the same bots but one were in line for Match 15.
Go Team 141!
2004 West Michigan Chairman's Winner/2004 West Michigan Regional Winner (thanks 1024 and 1243!)/2004 Cheasapeake Imagery Winner/2004 Buckeye Engineering Inspiration Winner
2005 Buckeye Engineering inspiration Winner/2005 West MIchigan Enterprenuership Winner
2006 Buckeye Regional finalists (Thank you 1018 and 461!)/2006 Buckeye Regional Sportsmanship award winner/2006 Midwest Regional Motorola Quality Award Winner/2006 Midwest Regional Finalists (Thank you 71 and 1775!)/2006 West Michigan Entreprenuership award/2006 West Michigan QuarterFinalist (Thanks 74 and 858)
2007 Boilermaker Judges Award Winner/2007 West Michigan Judges Award Winner/2007 West Michigan QuarterFinalist (Thanks 67 and 326!)/2007 Boilermaker QuarterFinalist (Thanks 573 and 868!)
Unread 30-03-2006, 18:22
mtaman02's Avatar
I forgot how the NYC Regional Match list was generated. I think it was 12 matches The Start Time was 9:50 End Time was 4 something for the first day lunch was between 11 / 12 & 1, time in between matches i think was like 4 1/2 minutes - 6 1/2 minutes and the start times for saturday was 9:20 and end was somewhere around 11:30ish so that kinda helped in not seeing any alliance repeats. Like I said I was around when the matches were being generated but I was giving one copy one day and a totally different copy the following day. As I said before there should be a SET amount of matches to be played for each regional based on the amount of teams - like 10 matches for 30 teams so on and so forth that way those volunteers who are at the scoring table don't have to use their best judgement in how many matches to run.
Volunteer Resume:
Unread 30-03-2006, 18:50
Dave Scheck's Avatar
Dave Scheck Dave Scheck is offline
Dave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond reputeDave Scheck has a reputation beyond repute
Do you value your sanity? That is a lot of back and forth between the pits and the stands/field. Not to mention that there is very little time to just sit back and enjoy the surroundings.
At both Midwest and Wisconsin, I helped a few teams with their software. The changes were easy, the testing was easy, but there was a huge problem with timing. I'd be working with them and one of our matches would come up, so I'd run out to barely catch our robot beginning to move in auton. I'd return to their pit after the match to find that they were just about to go to a match. By the time they came back it was time for another one of our matches. It became a huge game of tag trying to coordinate time to work together. If we had an extra 2-3 matches worth of spacing, both of our lives would have been a lot less chaotic....they would have been able to play all of their matches with the changes that they needed, and I would have been able to watch the matches with my team.
Don't get me wrong, I really enjoyed helping these teams and watching their students go from down to excited, but I'll tell you what, I sure was exhausted by the end of the day.
I'm all for the extra spacing, even if it means having a 5 minute break every 10 matches. I think it benefits all parties involved.
Championship Elimination Rounds Goobergunch Championship Event 20 24-04-2005 08:02
Real Time Match Results/Comments AIBob Championship Event 6 17-04-2005 18:14
Out with the match list printouts, in with... Pat Fairbank General Forum 19 07-02-2005 20:15
FIRST sumo matches list A. Snodgrass General Forum 61 14-03-2002 10:42
