Go to Post You don't see teams plastering the arena with signs saying "Show your spirit!" or "Be creative in your robot design!" or "Be sure to be innovative in your control!" - Mr. Van [more]
Go Back   Chief Delphi > Other > Dean Kamen's Inventions
Unread 30-03-2006, 23:44
ahecht's Avatar
ahecht ahecht is offline
'Luzer'
AKA: Zan
Re: mini segway project
You might want to look at the Legway code, since that incorporates the ability to do things such as line tracking (which implies riderless movement). He does it exactly the way you describe, by moving backwards slightly to offset the inverted pendulum.
Zan Hecht
Unread 31-03-2006, 01:20
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
1. Ride a Segway
2. Be amazed
3. Say,"I can do that for around $1000"
4. Try to build your own.
5. Quickly discover why the real Segway costs so much
6. Abandon the project and save your money.
7. Buy the real thing.
I have completed step 5.
Unread 31-03-2006, 10:11
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
This sounds like a really fun project! Keep in mind that keeping a mini Segway balanced is actually more difficult than the real thing. Think about trying to balance a pencil on the tip of you finger versus a broomstick. But it is by no means impossible.
As for getting it started: When it's normally balanced and stationary, the drive motors are constantly canceling out minor displacements forward and backward. If you suddenly ALLOW a small amount of forward displacement (while still restraining backward tilting) it would naturally fall forward a bit. It would provide enough torque at the wheels to balance this offset and start moving forward. When you are done accelerating, take out the offset and it should return to constant velocity. Easier said than done...but it might be a starting point.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 08-04-2006, 11:20
David55 David55 is offline
AKA: David Hillman
FRC #1577 (Steampunk) & FRC #125 (NUTRONS)
David55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to beholdDavid55 is a splendid one to behold
This page should help you:
http://www.geology.smu.edu/~dpa-www/robo/nbot/
And here is some info from the segway site:
http://www.segway.com/segway/how_it_works.html
http://www.segway.com/segway/component_details.html
Unread 08-04-2006, 13:07
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
You got to post pics when you are done. I think a segway that a pet can ride would be pretty funny. lol. You may want to look into gyroscopes that will fit the project. Since it will be a lot smaller, a foot you said, than try and make sure that the motors, speedcontrollers, gyroscopes, battery, and everything else can fit.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 08-04-2006, 23:00
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
i would try finding an rc parachutist and using the servos in tthat control your wieght issue. another thing u could consoder is using an rc gyro also, however i really dont know much about custom electronics so ggood luck.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 09-04-2006, 15:03
Has anyone ever thought about using a servo neat the top of the balancing bot to shift the platform's center of mass? This would probably simplify things code wise, because all you would need is a handler to change the position of the servo, and the robot to always try and balance itself.. instead of the robot trying to balance and modifying the wheel speed to drive which way you want.
Unread 11-04-2006, 23:51
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
You could also use ultrasonic sensors, so when it tips forward the ultrasonic sensor is at an angle and can "see" the ground. You know if the ultrasonic sensor is on the front or back, you can accelerate in either direction based on this knowledge.
VEX Robotics Blog
Unread 12-04-2006, 03:14
FRC #0599 (RoboDox)
problem there, going up hills, like a slight hill. Wont work that well without some major fine tunning, programming, and engineering. I dont recomend the ultrasonic sensor idea.
Unread 12-04-2006, 06:42
MattK's Avatar
MattK MattK is offline
Tap it.
MattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to beholdMattK is a splendid one to behold
Send a message via AIM to MattK
This sounds like a fun project and all the power to ya! Just please keep in mind any and all safety hazards if you or a friend decides to "ride" it (I know its a "mini segway" right now)! Sometimes experimental balancing machines can go a little funky, and its really no fun to be moving around 10mph and have the machine fail- sending you pounding down into the pavement at that speed.
The views expressed in my posts are Mine and mine only.
my myspace!
openFIRST Project Announces Pending Deadline for End of Support for Old Versions Timothy D. Ginn FIRST-related Organizations 0 11-07-2005 22:40
Off-Road Segway Clark Gilbert Dean Kamen's Inventions 21 29-04-2005 15:32
Senior Project 05: Mini competition to help fundraise for local rookie teams Alex Cormier Fundraising 0 07-10-2004 15:58
Segway has obstacle in Japanese market Robb Gerber Dean Kamen's Inventions 10 10-11-2002 23:08
L.A. Times Article Greg Ross Dean Kamen's Inventions 25 26-07-2002 22:00
