Go to Post It will mean far more than you can imagine...and really, you can't lose. - David Kelso [more]
Unread 31-03-2006, 16:06
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: Joystick Triggers No Longer Work
Originally Posted by amateurrobotguy
The problem was a bad OI. Ports 1 and 3 don't work but 3 and 4 did. We just got last years board hooked up.
I had a feeling that could have been the problem. It sounded very familiar. Glad to hear that it has been worked out.
Were the entire ports malfunctioning or just the digital inputs? If you ever needed to utilize those ports again and the analog inputs were still functioning (so long as you didn't need all the analogs) you could always remap some of the digital switches to use the analog inputs. It's a relatively painless process and it is a good workaround if necessary. I know I've had to do this a few times: once because of that broken port issue, and the rest just to use additional controls; I'm sure many, many people have dealt with the same thing in the past.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
What Artist Influence You? Koko Ed Chit-Chat 12 01-12-2006 11:33
speeding up the work on 3ds MAX (and then some) Nimmy 3D Animation and Competition 1 01-02-2006 14:57
Major CMUcam issues - LabView app won't work, very low-quality picture scottmso Programming 5 19-01-2006 17:51
Getting the Camera and Default Code to Work nukem Programming 5 18-01-2006 11:48
When to leave that first tech job? Morenoh149 Career 4 07-10-2005 00:40
