Go to Post "Why use a CNC when you can get it done with wood, duct tape, and zipties!" - gcgeobuff [more]
Unread 01-04-2006, 04:56
Nimmy Nimmy is offline
also Head of Strategy\Translation
AKA: Nimrod Amir
FRC #1577 (SteamPunk)
Team Role: Animator
Nimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the roughNimmy is a jewel in the rough
Send a message via ICQ to Nimmy Send a message via AIM to Nimmy Send a message via MSN to Nimmy
Re: 3ds Max Help!
oh and about special tips, this is one thing I learned which is simply an annoyance that can be fixed, im sure you wanna make an elaborate model that will look really good and all, and I'm sure if you try hard you will do it
but what I learned is that most parts of a model can be done in several ways
some of which are the "right" ways and some aren't so "right"
take note to the amount of faces, in your models, we ended up with half a million faces for a small model because we used too many vertex for it's teeth, so try to save up where you can, it will end up cutting you a lot of time on working, our machine almost froze because we used too much faces, gotten to a point we had to go back to the original file of that model, and do it over again (looked the same eventually, but with 90,000 faces instead of 500,000)
We cannot enter into alliances until we are acquainted with the designs of our neighbors.
- Sun Tzu
I guess someone should tell Mr. Tzu about FIRST
check out our HERBEW translation to the 2006 game manual at: http://www.avivrobotics.net
Don't mess with Nimrod's
questions about the 3ds max license BuddyB309 3D Animation and Competition 3 27-10-2005 16:32
Importing Inventor Into 3ds max? Jeremiah Johnson 3D Animation and Competition 8 31-01-2005 21:30
**FIRST EMAIL**/Gear Up with Live Inventor and 3ds max Trainings! Billfred FIRST E-Mail Blast Archive 0 22-12-2004 16:30
Text effects in 3DS Max... Ranma 3D Animation and Competition 6 28-02-2002 21:56
Autodesk Inventor -> 3ds Max (File Format) Adrian Wong Inventor 1 22-01-2002 23:06
