Go to Post Man, Earthquakes all over the place, Volcanos and clouds of ashes, S&Ps down 25 pts! and now 1114 is first seed and going to probably pick 469... yep, id say the end of the world is near - scessama [more]
Unread 01-04-2006, 18:20
in between teams
AKA: Luke Van Oort
If you could make your own...
If you could make you own gameport joystick for FIRST, out of whatever you want, what would it be? (Within reason)
Team 1219: 2009 - Mentor
Unread 01-04-2006, 20:50
Back after 4 years off
FRC #5279
Re: If you could make your own...
Ive always been a fan of lexan (or clear resin) so you could see all of the inner workings as you used it, then throw in leds so it would glow, that would be cool.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 01-04-2006, 21:16
Elgin Clock's Avatar
FRC #0237 (Black Magic)
A bowling pin. But.. I can't seem to find a scaled down one that can be easily modified to fit ergonomically within one hand.
Maybe a duck pin bowling pin? Or a candle stick pin? Hmm..
Runs to ebay to look for (new or used) bowling pins.
Unread 01-04-2006, 21:22
Andy A. Andy A. is offline
Getting old
FRC #0095
I'm a huge fan of the CH flightstick. When you start with the best, its hard to think of a way to improve upon it. Still, there are some things I would change...
I suppose I would prefer a stiffer plastic throughout such as nylon. Some components should be steel, such as the stick it's self. A grippy rubber hand hold, such as those on some guns, would be lovely. Stronger springs (perhaps something like adjustable gas springs) for a heavy precise feel and better return to center. Perhaps a non linear pull? I'm not certain how that would feel. Higher quality pots to cut down on that annoying center drift we have to trim out so often. I'd also like to have trim wheels recessed and covered, to cut down on accidental loss of trim. Nothing is worse then starting a match with your 'bot spinning around in circles. I prefer to hold the stick low, so a shorter stick hight would put the top buttons in easy access. I would also duplicate the stick buttons onto the base, in case I would rather trigger them with my left hand. Perhaps a modular system to give options between momentary and positional switches?
For drivers who like having two sticks, having a game port on each stick that would allow you to daisy chain two sticks onto one port with out any additional wiring would be nice.
Overall, I would like a stick that has a heavy, solid feel with high quality internals and easily accessed buttons. If anyone knows of one already out there, I'd like to know about it.
Unread 02-04-2006, 17:46
Bill_Hancoc's Avatar
Bill_Hancoc Bill_Hancoc is offline
Volkswagen Enthusiast
AKA: Bill Hancock
FRC #0573 (MechWarriors)
Bill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud ofBill_Hancoc has much to be proud of
Send a message via AIM to Bill_Hancoc
i made a metal control stick that could be mounted to the regular controlers and would have a button on the top. If i realy wanted to i could add momre buttons elsewhere but i havnt had the time
tell me if you like it
MechWarriors 573
Unread 02-04-2006, 17:52
Jeff Rodriguez Jeff Rodriguez is offline
Too young to be an 'old guy'
FRC #0155 (Technonuts)
Jeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond reputeJeff Rodriguez has a reputation beyond repute
Send a message via AIM to Jeff Rodriguez Send a message via Yahoo to Jeff Rodriguez
CH flightstick with 1) slightly stronger springs that don't wear out, 2) one more button on the left side, and 3) rudder control (so the joystick can twist side to side).
Now if I can only get my MS sidewinder 3D pro to work.
173, student: 1999-2002
173, mentor: 2005-2010
155, teacher: 2011-
Unread 02-04-2006, 18:01
Greg Marra Greg Marra is offline
[automate(a) for a in tasks_to_do]
FRC #5507 (Robotic Eagles)
Greg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond reputeGreg Marra has a reputation beyond repute
I want buttons lowers on the joysticks. I hold the sticks right around the base, instead of way up at the top. It gives me a lot finer control and makes it easier on my hands. If I had some sort of trigger down there or maybe buttons my fingers could reach up at the "front" area of the base of the stick, that would give me a lot more control.
But still, I <3 my CH Flightsticks.
Unread 02-04-2006, 18:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Old style CH flightstick with slightly stiffer springs and a two position rocker switch in the handle on the side closest to the operator.
Unread 02-04-2006, 18:26
Alex Burman's Avatar
Alex Burman Alex Burman is offline
∆o□
AKA: The Burmanator
FRC #0075 (Roboraiders)
Alex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud of
Send a message via AIM to Alex Burman Send a message via MSN to Alex Burman Send a message via Yahoo to Alex Burman
I'll take this as my dream controls:
I'll I'd have to due is figure out some way to rig them up to a game port
The Burmanator
www.Roboraiders.com
http://www.myspace.com/burmanator
Unread 08-05-2006, 09:24
Cuog's Avatar
Cuog Cuog is offline
Registered Linux User: 390661
AKA: Alex
FRC #0422
i would want a flight stick that isnt too hard too move like the old flightsticks from first since i also hold down toward the base, i would use that with one hand then have a nice switchboard with linear pots for other adjustments on my left hand.
KK4KQO
http://voltair.us
Unread 09-05-2006, 22:55
TopRamen1138's Avatar
TopRamen1138 TopRamen1138 is offline
ToppRamen: It's-a-cause of my hair.
AKA: ConnorTrentChambers
FRC #1138 (EagleEngineering; (E^2);)
TopRamen1138 is on a distinguished road
Well, as much as I'd hate to admit it:
Our FORMER presidente Jordan decided that it was possible to hook up some USB Cyborg Joysticks (well, wire up the buttons and POTS)
(the cool ones with the folding base)
up to some serial cable and bam: some gameport cyborgs!
Nope; they were linear pots that self adjusted using drivers... so we never got a good reading off of them.
Solution: Take the cyborg joystick part (sans base) and screw them on to the kit joystick bases (POTS inside, no worries). It worked, but it took him a week to do a job I told him had to be done in two days...
Lots a whining, but a cool end result. The piece-de-resistance (Im in french III) was a custom bent aluminum switchplate:
heres a pic of me and our CURRENT presidente Jeff, who was VP so took Jordan's place:
Old school distressed plastic labeling:
"If you think a weakness can be turned into a strength, I hate to tell you this, but that's another weakness."
Unread 10-05-2006, 16:14
anna~marie's Avatar
anna~marie anna~marie is offline
misses FIRST
AKA: HOT's first female operator
FRC #0067 (HOT- Heroes of Tomorrow)
anna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond reputeanna~marie has a reputation beyond repute
Send a message via AIM to anna~marie
when I was waiting behind the field I saw the greatest thing...an old NES controller! that would be so awesome
program the buttons and the keypad... so dueable
I'm proud to be a...
Unread 10-05-2006, 17:04
Morgan Gillespie's Avatar
Morgan Gillespie Morgan Gillespie is offline
I haven't any bullets
AKA: NPC / Mercury Rising
FRC #0025 (Raider Robotix)
Team Role: Driver
Morgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond reputeMorgan Gillespie has a reputation beyond repute
Send a message via AIM to Morgan Gillespie
I was just about to post this. But honestly do you have one?
Bristol-Myers Squibb Company
Events Competed:
-Duel on Delaware 05, 06, 07, 08 - Ramp Riot 05, 06, 07 08 - Brunswick Eruption 05, 06, 07 08 - PARC 06, 07, 08 - Monty Madness 0608 - Battle O' Baltimore 07 08 - Pascack Panda-monium - 08
__________________________________________________ _________________________
NJ 06, 07, 08 09 - UTC 07 -LV 06 - HI 08 - ATL CMP 06, 07, 08
Make all command pmzq Programming 3 24-01-2006 16:16
Could you make me some Mac floppies? sanddrag IT / Communications 1 12-09-2004 22:53
Anyone ever make something rideable (go-kart/scooter/misc.) from the Kit Of Parts? Elgin Clock Technical Discussion 9 29-07-2004 22:09
trying to make a piston in inventor gren737 Inventor 4 03-02-2004 15:16
