Go to Post its kind of a bad idea to implement traction control when you have no traction in the first place. - Uberbots [more]
Unread 01-04-2006, 01:55
Ben Englert Ben Englert is offline
FRC #1072
Ben Englert has a spectacular aura aboutBen Englert has a spectacular aura aboutBen Englert has a spectacular aura about
Team 1072 - underglow!
Let's see. 2005 robot, still in relatively good working order + extra green cold cathodes from 2006 game + too many spare Spike relays...
It had to be done eventually.
Before a match at SVR, 3/17/06
Tatsu: "Yo Englert, what's our autonomous mode?"
Me: "We'll find out, won't we."
Both: *maniacal laughter*
After the match's autonomous period ends:
Me: "Well, the basic control system still responds. That's always good."
Both: *further laughter*
Unread 01-04-2006, 02:24
rachal's Avatar
rachal rachal is offline
multipurpose tool
AKA: Rachel
FRC #1072 (Harker Robotics)
rachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nicerachal is just really nice
Send a message via AIM to rachal
Re: Team 1072 - underglow!
Now if only we had some more cathodes and a better cart...
2005 Sacramento Winners with 245 and 766
2005 SVR Semi-Finalists with 840 and 668
2005 SVR Judges Award
Unread 01-04-2006, 14:32
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
Now seriously, why can't FIRST allow underglow?
And hey, on a spike relay, you can have alternating, flashing underglow.
Unread 01-04-2006, 16:04
FRC #1072
Unfortunately both cathodes are behind a single spike... for now. I'm sure we have another inverter laying around, so the situation can easily be resolved.
And then, yes, we can have alternating blinking underglow.
Unread 01-04-2006, 16:14
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
FIRST does allow under glow, you just need to be able to change the colors in correspondence to your alliance color if you are planning to use red or blue, and green cannot be used b/c of the green target, if you wanted any other color i am sure they would be fine assuming FIRST doesn't change the target color.
Blargha!
Unread 01-04-2006, 16:15
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Err are you doing this with a spike? Spikes are mechanical in nature, I wouldn't recommend clicking them on and off quickly for extended periods of time. I can just see it now five robots turn to you, lock on, and bury your robot under a small hill of balls. I like the cool factor though. I didn't put them on because I figured an inspector would flag it.
I'm not so sure about that. I know for example that white light would throw off the camera. They might ask you not to use it just in case.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 01-04-2006, 17:20
FRC #1072
I'm sure they would be fine with it if it could be made to reflect your alliance color. However, a consideration on 1072 has always been WEIGHT.
Unread 01-04-2006, 17:24
Umm Errr...
Last year FIRST allowed our green underglow, but we programmed it to turn off during autonomous. This year cameras a used throughout the whole game. I would think any other color should be a problem. You could even have a red a blue set to match your alliance color. That would be alot more obvious than the flags.
In fact, i think it might even be a good requirement for or strong recomendation for next year. During the heat of a match, there is nothing worse than trying to figure out who the enemy alliance is.
the rotating lights - good
LEDS - pretty poor
Flags - much better than LEDs but not as good as the rotating lights
Neons - awesome
---edit----
On second thought an underglow requirement would create too many overrestrivtive rules about how high the underneath of your robot would have to be, neon placement etc. I still think they should be a "recommendation" as the team color LEDs were this year.
1139 Alumni
Unread 01-04-2006, 17:35
SamC SamC is offline
AKA: Sam Couch
FRC #0103 (Cybersonics)
SamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond reputeSamC has a reputation beyond repute
I wanted to put some of those on our cart!
Unread 01-04-2006, 22:55
fimmel's Avatar
fimmel fimmel is offline
Founding Mentor, Team 2370
AKA: Forest Immel
FRC #2370 (iBots 2370)
fimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond reputefimmel has a reputation beyond repute
team 885's cart had side cathodes that i installed.
Unread 01-04-2006, 22:58
AKA: Sam Couch
Did the FIRST officials make you guys turn them off during matches while the cart was on the side of the field? i know the robots with cameras will track anything that is green! At LA and Pheonix they were even trying to trak the 'Exit' signs!
2006 St. Louis Regional Andy Baker Regional Competitions 31 02-05-2006 22:04
East Coast Drivers Union Corey Balint FIRST-related Organizations 153 10-04-2006 15:50
Please post your 2006 Chairman's Award entries nehalita Chairman's Award 3 22-03-2006 19:22
How do you organize your team? NoodleKnight Team Organization 18 03-11-2005 22:57
Real names, please Andy Baker General Forum 131 21-07-2004 22:07
