Go to Post ...trapping Chuck Norris is worth infinity, Dave, Dean, and Woodie are 500 apiece, and trapping Andy Baker is worth double infinity - EricH [more]
Unread 02-04-2006, 16:54
AV_guy007's Avatar
AV_guy007 AV_guy007 is offline
AKA: Sam
FRC #0177 (bobcats)
AV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud ofAV_guy007 has much to be proud of
Re: Electrical tape as a non-functional decoration
5.3.11 Non-Functional Decoration Rules
Teams may add “Non-functional” decorations to robots under the following conditions:
<R101> Decorations must be on the robot at the time of final inspection, and must not cause the robot weight or
size to exceed the Rule requirements.
<R102> Decorations must not affect the outcome of the match, and must be in the spirit of “Gracious
Professionalism.”
<R103> Any decorations that involve broadcasting a signal to/from the robot, such as remote cameras,
cleared with FIRST Engineering prior to use. Teams may not use 900 MHz camera systems.
<R104> Decorations may draw power from the 12v electrical system as long as they are powered via
20A or 30A circuit breaker and do not affect the operation of other control system components.
these are all the rules in the manual about non-functional decorations. none of these imply that decorations cannot consist of tape. so i would say yes you can have them at Nat's.
p.s. good job yesterday. it was fun!
Team 177
bobcat robotics
BLUE ALLIANCE CREW MEMBER
Next event attending: Kickoff 08- Manchester NH With TBA
Legality of using Tape for Labels? Goobergunch Rules/Strategy 7 18-02-2005 01:35
Duct Tape yamo18 Rules/Strategy 10 14-12-2004 19:08
Electrical Tips for Rookies Anne Shade Technical Discussion 15 03-12-2004 12:08
Hot Glue/Electrical Tape Jeff Zampieron Electrical 7 25-02-2004 03:52
How is reflective tape applied to HP crates? Dr.Bot General Forum 2 06-01-2003 15:17
