Go to Post Oh, and your t-square and pencil can't crash, unlike your laptop :D - scottydoh [more]
Unread 02-04-2006, 17:14
Re: Do you agree?
This is a trick question and my brain already hurts!
Each alliance has 40 balls to start, right? So to block 80 points that means your alliance must have put at least 40 balls into your own goals, giving you 40 points or 120 points already.
but if you block the 80 points does that mean 80 balls, or 26.6666 balls are now on the play field, or are they still in the opponents robot that could not get off any shots?
If they are on the field then it depends whether your robot can snarf them back up off the floor. If your alliance cant do that you may be better off letting them score in the side goals, so you can (maybe) reload your robot and score them in your center goal?
My answer: insufficent input - please specify all required parameters necessary to determine a meaningfull answer! :^)
[moderated] Sportsmanship! Tyler Olds General Forum 30 23-03-2004 16:41
pic: Gerrish Gearbox MK-III #2 CD47-Bot Extra Discussion 26 12-09-2003 11:35
Poor Man's Balance archiver 2001 16 24-06-2002 02:07
Picker Or Pickee archiver 2000 54 23-06-2002 22:26
