Go to Post A VERY credible statement ... coming from a 400-pound Pooh Bear - Rich Kressly [more]
Unread 02-04-2006, 22:27
TimCraig TimCraig is offline
AKA: Tim Craig
TimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to beholdTimCraig is a splendid one to behold
Re: Scaling
We had intended to try the Victor with a purely resistive load but didn't have time before we had to go to "build" mode. Seeing that plot leads me to believe that the source of the nonlinearity is the back EMF from the motor. If your turn the shaft on a DC motor, it turns into a generator. When you drive it as a motor, it also acts like a generator, however, the sense of the voltage is inverse to the supplied voltage. This is why stall current is the maximum current the motor sees and then drops with speed. It could also be that speed is proportional to power and power it proportional to Voltage squared or Current squared.
I've also noticed a lag in seeing the motor start after an output is applied to the Victor and hence the motor. I've yet to do the experiments to determine if it's in the Victor repsonding to the input or if it's the rise time of the magnetic field in the motor.
Scaling algorithms rhobincu Computer Graphics 1 10-10-2005 13:25
VEX 2005 = Mini FRC 2004 Joe Johnson FIRST Tech Challenge 12 08-04-2005 17:22
Example gyro code released. Kevin Watson Programming 60 17-03-2005 18:32
Scaling Values in the Control Program archiver 2000 15 23-06-2002 22:24
Scaling on motors Jeff Waegelin Motors 2 13-01-2002 23:07
