Go to Post It's not a proper FIRST season if you don't have a robo-diet before ship date! - Mr MOE [more]
Unread 02-04-2006, 16:22
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
Re: Do you agree?
Originally Posted by Jeff Beckett
one thing you can forget is if there is another robot that can score lots of points. you can't block both at the same time. this is where i would say scoring the points is better just for the fact of keeping it close. just my two cents.
lets say the opposing alliance has a defensive bot, and two offensive. One of the offensive and defensive can play defense on these two bots and the other can score...this is what happened throughout eliminations in Boston with 1568 (defense) 233 (offense) 121(offense), by taking turns playing offense and shooting, 233 and 121 provided the points, while 1568 blocked any bot trying to shoot in the center goal.
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 02-04-2006, 17:14
Re: Do you agree?
This is a trick question and my brain already hurts!
Each alliance has 40 balls to start, right? So to block 80 points that means your alliance must have put at least 40 balls into your own goals, giving you 40 points or 120 points already.
but if you block the 80 points does that mean 80 balls, or 26.6666 balls are now on the play field, or are they still in the opponents robot that could not get off any shots?
If they are on the field then it depends whether your robot can snarf them back up off the floor. If your alliance cant do that you may be better off letting them score in the side goals, so you can (maybe) reload your robot and score them in your center goal?
My answer: insufficent input - please specify all required parameters necessary to determine a meaningfull answer! :^)
Unread 02-04-2006, 19:51
MasonMM's Avatar
MasonMM MasonMM is offline
AKA: Mason Markee
FRC #0118 (Robonauts)
MasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond reputeMasonMM has a reputation beyond repute
Re: Do you agree?
I think it is what you consider "good".
It's more impressive and crowd pleasing to see a robot score 80 points in a match by itself.
But as far as scoring and winning a match it can go both ways. As 418 already stated they used the "Stop the other guys from scoring at all cost" strategy and without it they wouldn't have won the regional. So in that sense is is quite as good to stop a team from scoring, especially if it means winning a regional.
Unread 02-04-2006, 20:15
StephLee's Avatar
StephLee StephLee is offline
Deadlines? What are those?
AKA: Stephanie
FRC #0639 (Code Red Robotics)
StephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond reputeStephLee has a reputation beyond repute
Send a message via AIM to StephLee
Re: Do you agree?
From my experience as coach and strategizer for our team at two regionals, it always DEPENDS. One strategy will very very rarely work for all matches in this game; you have to take each match as it falls out and go from there. Our robot can play multiple roles on an alliance: if we have a good shooter on our alliance, we can play defense and dump a bit, but if we're the top shooter on the alliance, we can shoot quite well. We're an all-around robot, basically. So for our strategy...
Say we're with two dumper/defenders. We'd be the primary offense, ask the others to play defense for us while we shoot, then go for the ramp. But what if we're with two good shooters? We'd play defense with the better pusher of the other two, and we'd block for them so they can shoot effectively.
What about the opponents? If you're against two or three shooters, you concentrate your defense on the center of the field. If you're against three dumpers, though, you sit in front of the corner goals. If your opponents can't push well, defending your scorer isn't as crucial; but if you're up against a minitank, you keep them away from that shooter at all costs.
My point is, it depends on your alliance partners' capabilities, as well as those of your opponents, as to whether it's better to stop the scoring of 80 points or to score those 80 points yourself. Due to all the headaches trying to strategize before the competitions, I've decided "Case-by-case basis" is a great motto for this game.
Proud alum of FRC Team 1629 and mentor of FRC Team 639
Cornell Engineering class of 2012!!
Unread 02-04-2006, 20:17
George A.'s Avatar
George A. George A. is offline
I come through in a spinsch
AKA: George- The Voice
FRC #0303 (TEST Team)
George A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond reputeGeorge A. has a reputation beyond repute
Send a message via AIM to George A.
Re: Do you agree?
Commenting on the pick and screen method.
From what I hear (I've yet to see video) In Palmetto, 11 was able to shoot 10 for 10 through the center hoop in autonomous. Then in later matches other teams wised up and knocked into them throwing off their alignment. In the eliminations 11 had one of their partners set up a screen to block the defender so they could score...I guess that strategy worked since 11 and their allaince won the event.
Then at Philly 306 was able to shut down 84 and 365 (two of the powerhouse scorers) to win the event. So I'd go out on a limb, that if you get a robot that can score a few points in autonomous then play defense you're golden.
My Volunteer Resumé
Game Announcer NJ: 2005-Present
Game Announcer Philly: 2006-Present
Game Announcer NY: 2005-2008
Game Announcer Champsionships: 2005-2008
Unread 02-04-2006, 20:20
StephLee's Avatar
AKA: Stephanie
Re: Do you agree?
Our alliance at Pittsburgh did the same thing; 393 dumped in the corner for a solid, reliable 10, we (1629) shot in the center and generally made at least 3 or 4, and 1370 blocked for us.
Unread 02-04-2006, 21:18
Freddy Schurr Freddy Schurr is offline
FRC #0204
Freddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond reputeFreddy Schurr has a reputation beyond repute
Re: Do you agree?
I would think that scoring 80 pts would be better because you could always block a robot from scoring.
Unread 02-04-2006, 21:20
George A.'s Avatar
Re: Do you agree?
You can find my predictions for the winning allaince
here
here
and
here
notice my third one (on the list, actually the first one chronologically speaking) is from February BEFORE the start of regionals...so it's not like I just jumped on the bandwagon. I've been preaching it for a while...and now it's coming to fruition.
My Volunteer Resumé
Unread 02-04-2006, 22:23
DaveA412's Avatar
DaveA412 DaveA412 is offline
the other left
Team Role: Driver
DaveA412 has a little shameless behaviour in the past
Send a message via AIM to DaveA412
Re: Do you agree?
Originally Posted by Tim Delles
The real question is can you score 80 points. Thier aren't many teams that can score 80 points.
at the two regionals ive been too half the teams atleast could score 80 points easily and effectively one team even scored 130 some odd points(233) ive definitely seen a lot of teams score 80 points without breaking a sweat but idk a lot fo veyr good teams were at my regionals not to say there wasnt at yours but it was jaw dropping with teams like 121 233 40 1276(i think kaizen blitz if i got the number wrong maybe it was 1257 idk)but once these teams got it it was amazing team 126 even shoots 2 balls at once
Team 1568 driver
2005 highest rookie seed
13th at UTC
2005 judges award
2006 boston regional winners along with 121 and 233
Unread 02-04-2006, 22:24
DaveA412's Avatar
the other left
Team Role: Driver
Re: Do you agree?
Originally Posted by Dillon Compton
Hey, guys, it wasnt a question of whether or not you could stop 80 pts from being scored, or score 83, 87, 1394... points; the question was if blocking 80 points is as good as scoring 80 points- that is to say80 points in both situations- the point differential will not be any different
I'm inclined to say that it is as good or better to block points as score them, in equal amounts- in the interest of being selected, at least, even if not selecting during alliance picking, I think that strong defensive robots are much more visible and noticeable than strong scoring robots; there are less people that can shut down (insert number of points here) than can score (insert same number) at any given event.
my view exactly well put and well said
Team 1568 driver
13th at UTC
2005 judges award
Unread 02-04-2006, 22:42
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: Do you agree?
The LA regional showed that Defensive bots prosper.
968 (offensive), 1138 (defensive), 4 (defensive).
968 has the same bot as the Cheesey Poofs so they are just as good.
If you are a good enough defensive bot. Stopping 80 points is equally as rewarding as making 80 points.
I'm not sure what's more fun though. Keeping one of the big-shot teams from scoring, or actually scoring yourself. I'd say keeping the big-shot team from scoring.
Unread 02-04-2006, 22:43
Re: Do you agree?
I have to take the opposite position. You cannot win unless you score at least one point.
The logical extreem of the question would be one robot that can only shoot and score, against another robot that can only block (play defense).
so if it comes down to blocking OR scoring, scoring is better. Its the only option that allows you to win the match.
Unread 02-04-2006, 23:28
The Lucas's Avatar
CaMOElot, it is a silly place
Re: Do you agree?
Scoring 80 pts is better. There are only 80 sec (2 periods) of offense in this game. Defense can take all 120 sec (3 periods). So the offensive bot is more productive since it only takes 2/3 of the time to do its 80 pt job. The offensive bot could play defense during the defensive period and prevent other bots from scoring (bring its point total above 80 pts). Or the offensive bot could be the backbot (required) and let other bots play defense.
Also, the offensive bot might draw defenders effectively preventing them from scoring. In one qualifying match at Philly, a bot was the best offensive and defensive bot on an alliance. They spent their entire match playing good defense on a high scoring bot and probably prevented more points than they would have scored, but their alliance was unable to to score enough points without them. Their point gain is the difference between the points they prevented and the points they would have scored if they were not playing D. The other bot's point gain is the sum of points they managed to score while being defended and the points the defender would have scored.
I am not saying defense is not important because it is very important in this game. However, it is not a 1 for 1 tradeoff with offense and if you have a choice I suggest you score 80 pts.
Robot Inspector
Unread 02-04-2006, 23:43
Back after 4 years off
FRC #5279
Re: Do you agree?
OK first off I am on the same team ans DaveA and Guju4life, however I have to take the opposite point of view scoring points is far more important, If you can't put points on the board you can't win. Especially in qualifying rounds when you need good scores by both teams to seat well for picking.
In the elimination rounds scoring is most important this is why you nearly always see the top shooters picked first, defense can also be used effectively abut not nearly as effectively as scoring. Many of the best alliances are 2 shooters and one defensive bot (I believe this is largely due to the serpentine draft) three defensive bots will never beat 3 offensive bots, the period system this year makes it very difficult to effectively block shooters for the whole game. Over all I would say big shooters are the best but strategy will always reign supreme, as much as I would like to take credit for having an effective defensive autonomous all these do is go across the field really fast and at high torque, the success of 90% of these modes is properly predicting what the other robot will do rather than elegant design of the bot or elegant programming. Defense is bigger this year than it was in the past, however I believe at nationals it will be less defensive and more emphasis will be on robots with good traction that can shoot and push (like the triplets 121, 233 and 1276 I'm sure there are plenty more that I haven't seen).
James
p.s. Dave there is no way half the robots we have been against can score 80 points, I would say that no more than 5 of them could.
I'm Back
5279 (2015-Present)
3594 (2011)
3280 (2010)
1665 (2009)
1350 (2008-2009)
1493 (2007-2008)
1568 (2005-2007)
Unread 02-04-2006, 23:53
DaveA412's Avatar
the other left
Team Role: Driver
Re: Do you agree?
James
James i was overexaggerating but i totally agree with u and 3 good offense is the elite alliance but because of the picking its hard to comby 3 good shooters they are usually all picked up and im pretty certain more then 5 bots could score more then 80 points id say 6 but at atlanta i think their might be more then 6 maybe 7 or so idk
Team 1568 driver
13th at UTC
2005 judges award
[moderated] Sportsmanship! Tyler Olds General Forum 30 23-03-2004 16:41
pic: Gerrish Gearbox MK-III #2 CD47-Bot Extra Discussion 26 12-09-2003 11:35
Poor Man's Balance archiver 2001 16 24-06-2002 02:07
Picker Or Pickee archiver 2000 54 23-06-2002 22:26
