Go to Post ... you know you are a nerd when you want safety glasses for your birthday! :P - Ashley Christine [more]
View Poll Results: Does your 06 robot have pneumatics?
Yes 98 45.16%
No 103 47.47%
undecided 13 5.99%
Pneumatics? 3 1.38%
Voters: 217. You may not vote on this poll
Unread 06-02-2006, 02:52
ForgottenSalad's Avatar
ForgottenSalad ForgottenSalad is offline
In search of a home...
AKA: Michael Wessler
ForgottenSalad will become famous soon enoughForgottenSalad will become famous soon enough
Send a message via AIM to ForgottenSalad
Re: Does your 06 robot have pneumatics?
We most likley will be using a small pneumatic piston and two cylinders for a small job, but pending further tests it is unknown wether or not we will use the full system. (Compressor, etc...)
Unread 09-02-2006, 18:59
Veselin Kolev's Avatar
Veselin Kolev Veselin Kolev is offline
X51 Production Company PGM (TM)
Veselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond reputeVeselin Kolev has a reputation beyond repute
We're only using two small .75" bore cylinders, 1/2" stroke, to shift our transmissions, at 30 psi. We're not using a compressor, and only one air tank. We dont need the weight, we just dont have unlimited room for electronics and stuff in our cassis.
Unread 09-02-2006, 19:25
Freak999's Avatar
Freak999 Freak999 is offline
AKA: Snowman
FRC #0829 (Warren Robotics)
Freak999 will become famous soon enough
Send a message via AIM to Freak999 Send a message via Yahoo to Freak999
We only have 2 pneumatic cylinder for transmission shifters w/ Air Resivore.
(>'-')> Ben <('-'<)
Unread 09-02-2006, 19:39
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Since '03 and '04 we used pneumatics for our two speed transmissions.
'05 we originally used them for our manipluator but, for some reason, that didn't work so we took off the compressor all together. Even though it wasn't running it still held a purpose. It was deadweight and kept us from tipping!
This year we are using Pneumatics for our two speed transmissions and for feet to stabilize our robot while shooting.
Unread 19-02-2006, 17:22
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
No. We decided at the beginning that we were going to try and build the robot without using pneumatics. We could have used them, but in only one or two areas, so we decided that it wouldn't be worth the weight.
VEX Robotics Blog
Unread 19-02-2006, 21:02
DarMagi DarMagi is offline
DarMagi will become famous soon enoughDarMagi will become famous soon enough
pneumatic dump works beautifully =]
Unread 25-02-2006, 11:27
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Of course we did! Just have to wait to see her to find out where we used them.
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 28-02-2006, 15:54
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
I think we actually cut a little wieght with our pneumatics. We have no compressor, but we will charge the tanks before each match. We have only one piston, but it is pushing a lot of wieght, so we used two tanks. Having a motor with chain and gears would be i think about the same, or even a littleh heavier than what our pneumatics weighs.
Unread 05-03-2006, 15:36
ewankoff's Avatar
ewankoff ewankoff is offline
hurdling=touch but don't spill
AKA: -=The WANK=-
FRC #1676 (PI-oneers)
ewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to allewankoff is a name known to all
we didnt use pneumatics for weight and because last year we tried pneumatics and failed horribly. we used a small pnematic cylinder to grab and a larger one for the arm that was arguably the worst decission we made
if you go to the FIRST web site and enlarge the front page picture our robot is in the back left of the picture. it is struggling to do something I dont exactly remember that moment
2005- NJ rookie all-stars
2006- NJ judges award winners
NJ&Palmetto safety credit award winners
Palmetto finalists
2007-NJ Website award winners
NJ Motorola quality award and J&J sportsmanship award winner
Buckeye Motorola quality award winner
NJ #3 seed and semifinalist
2008NJ Chairman's Award
JOHNY FIVE is ALIVE!!
Unread 05-03-2006, 22:18
Cheuk Hung Ng Cheuk Hung Ng is offline
Alumnus
FRC #0492 (Titan Robotics Club)
Cheuk Hung Ng is an unknown quantity at this point
No, we didn't use pneumatics this year because we didn't really need it with our robot design.
#1 in the Northwest: 2001 Silicon Valley Regional Rookie All-Star Award || 2001 Galileo Incredible Play Award || 2002 Southern California Regional Judge's Award || 2002 Pacific Northwest Regional Finalist || 2003 Silicon Valley Regional Entrepreneurship Award || 2003 Pacific Northwest Regional Website Award || 2003 Pacific Northwest Regional Finalist || 2003 Pacific Northwest Regional Engineering Inspiration Award || 2004 Pacific Northwest Website Award || 2004 Pacific Northwest Regional Champions (#1 seed) || 2004 Galileo Semi-Finalist || 2005 Pacific Northwest Regional General Motors Industiral Design Award || 2005 Pacific Northwest Regional Champions (#1 seed) || 2005 Galileo Finalist || 2006 Pacific Northwest Regional Chairman's Award Winners
Unread 06-03-2006, 09:41
CaseyKasem_1251's Avatar
CaseyKasem_1251 CaseyKasem_1251 is offline
AKA: John Casey
FRC #1251 (TechTigers)
Team Role: Student
CaseyKasem_1251 is on a distinguished road
Send a message via AIM to CaseyKasem_1251
We are using pneumatics this year for shifting and for use with part of our hopper. We have the compressor on the robot along with 1 storage tank. Cant wait to get up to UCF and see our gearboxes in action
2008 UCF Regional Champs thanks to 233 and 86
2008 UCF Regional GM Industrial Design Award
2007 Palmetto Regional finalists thanks to 1626 and 1758
2007 Palmetto Regional Motorola Quality Award
2007 UCF Regional Champs thanks to 1270 and 86
2007 UCF Regional GM Industrial Design Award
2006 Palmetto Regional Champs thanks to 11 and 247
2006 UCF Regional Semifinalist thanks to 86 and 710
2005 Palmetto Regional finalist thanks to 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional finalists thanks to 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award
Unread 03-04-2006, 00:54
Tyler M. Tyler M. is offline
Visit our webpage: www.khsfirst.com
FRC #0213
Tyler M. will become famous soon enough
To my knowledge, we've never used ours. And we used to be team number 9, one of the originals. So I imagine they've stacked up. We get along just fine without 'em. Oh well
Tyler Mundell, Team 213-The Dirty Birds
Unread 03-04-2006, 01:22
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
This year, we just used them for shifting. Our original design had them for use also as like, a gate, but due to weight, we had to scrap the shooter/feeder/gate. We also have the compressor onboard for weight.
Unread 03-04-2006, 23:03
Pavan Dave's Avatar
Pavan Dave Pavan Dave is offline
Busy in College
AKA: I am John Gault.
FRC #1745 (P-51 Mustangs) FRC #118 (Robonauts)
Pavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond reputePavan Dave has a reputation beyond repute
Send a message via AIM to Pavan Dave
My mentor said "Thank god you guys chose not to use pneumatics!".. not exact words..just a summary. ROFL. By former Controlls people I dont even want to use Pnedumatics..ive heard its a pain.
Pavan
Times change. People change. Teams change.
2008-Present: FRC1745, P51-Mustangs - Mentor
2005-2008: FRC118, Robonauts - Alumni
National Director of Philanthropy - Delta Epsilon Psi Fraternity, Inc.
1745 - 118 - ΔΕΨ
Unread 04-04-2006, 11:52
Kim Masi's Avatar
Kim Masi Kim Masi is offline
125 Member, cause Brando says so :p
FRC #0125 (NUTRONS)
Kim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond reputeKim Masi has a reputation beyond repute
Send a message via AIM to Kim Masi
for the last few years, 177 has used pneumatics on their machine.
This year, we are using it for shifting and to load our ball launcher system.
I know in 2004 instead of using a compressor we created our own vacuum pump using pistons. it was a very interesting design.
Bobcat Robotics-Team 177: 2004-2007
The NUTRONS-Team 125: 2008-2009, 2011-2012ish
Winning Robot or Quality Robot? Eric Bareiss General Forum 30 09-02-2006 13:19
pneumatics for 2006 competition? Joobacca Pneumatics 10 21-01-2006 23:14
Honda's robot... Don Wright Math and Science 7 17-12-2005 13:15
If you could change one rule - eliminate ship requirement discussion Andy Baker General Forum 53 28-10-2005 22:23
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
