Go to Post Based on EXTENSIVE analysis of this image, I have concluded that we will have to use wires on our robots. I am certain of it. - theCADguy [more]
Unread 01-02-2006, 15:54
packmons grunt's Avatar
packmons grunt packmons grunt is offline
FRC #1918
packmons grunt will become famous soon enough
our robot is awsome
i am part of team 1918 and we have an awsome robot i dont have any pictures (that is packmons driver's job) but i am open to any sugestions people are willing to give
Unread 01-02-2006, 15:57
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
Re: our robot is awsome
Make it MORE awesome.
MattB703 MattB703 is offline
AKA: Matt
None #0703 (Team Pheonix)
MattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud ofMattB703 has much to be proud of
Welcome to the Chiefdelphi community.
Unread 01-02-2006, 16:23
occra 23.
AKA: ryo
None #1481
well i assume you know this, but post pics!!!
and well. other than making itmore awesome, keep working on it.. assuming you're done.
theres ALWAYS something you can do tyo make it better
Unread 01-02-2006, 16:35
aaeamdar's Avatar
aaeamdar aaeamdar is offline
Post-A-Holic
AKA: Paul Dennis
FRC #1719 (The Umbrella Corp)
aaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant futureaaeamdar has a brilliant future
I don't know what to say. That's just... awesome.
Paul Dennis
Unread 01-02-2006, 18:00
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Make it so awesome it has real ultimate power!
Unread 01-02-2006, 18:13
Andrew Blair's Avatar
FRC #0306 (CRT)
Well, first drive it into a wall and destroy it, fix it, and then it will have ULTIMATE POWER!!! (Don't worry, it's a natural progression in every robot's life)
What good is ULTIMATE POWER!!! when it breaks down at the first regional?
-Sir Francis Bacon
-Albert Einstein
Unread 02-02-2006, 09:18
kevinw kevinw is offline
kevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to allkevinw is a name known to all
I have a few generic suggestions. You may find that only some of them are applicable to your specific robot (as you've seen it and I haven't, I can only guess what might be useful to you).
1) Make it easier to replace parts that are likely to need replacing during the competitions
2) Make it less likely that parts will need to be replaced during the competitions
3) Make parts easier to machine / assemble / more simple so that spare parts can be created more easily
4) Make it lighter and stronger, and add weight to areas where it would be to your advantage - or keep it light for ease of shipping, lifting, etc.
5) Find less expensive ways of accomplishing the same things, so that you can afford to do more
6) Make your robot faster
7) Make your robot be able to push with more force
8) Use less power so that you don't need to change your batteries as often
9) Add more functionality and features
10) Make it simpler and more robust
Unread 02-02-2006, 15:11
Mike Shaul's Avatar
Mike Shaul Mike Shaul is offline
FRC #0065 (Huskie Brigade)
Mike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant futureMike Shaul has a brilliant future
Thumbs up Re: our robot is awsome
Kevin, I would have to agree, excellent suggestions... that *would* be MORE awesome.
By far the best proof is experience. - Sir Francis Bacon
Unread 02-02-2006, 16:40
Of course, there's the obvious suggestion of identifying all sources of loss in your robot and minimizing them to make your transfer of power more efficient. Sorry I left that out.
Unread 03-04-2006, 01:37
Packmon's_girl's Avatar
Packmon's_girl Packmon's_girl is offline
Rei, and guys...stop being so male
AKA: Rebekah Olson
FRC #1918 (Packman)
Team Role: Student
Packmon's_girl is an unknown quantity at this point
Send a message via AIM to Packmon's_girl Send a message via MSN to Packmon's_girl Send a message via Yahoo to Packmon's_girl
you guys know, we got All-Star Rookie, and Top Seeded Rookie, and have four words: WE'RE GOING TO ATLANTA!!!!!!!!!!!!
2006 - All-Star Rookie, Top Seeded Rookie (West Michigan regional)
2006 Nationals - Top Seeded Rookie, Newton Division
((FYI Steller_mist is my gaia username))
Unread 03-04-2006, 17:56
IraJason IraJason is offline
In Search of "Bang Head Here" Sign
AKA: Ira Goldberg
FRC #3632 (D-Tecs); FRC #1712 (Dawgma)
IraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant futureIraJason has a brilliant future
Send a message via AIM to IraJason Send a message via MSN to IraJason
AWESOME!!!!!! I hope you guys have an awesome time! As part of another rookie team that won those two awards, I'm looking forward to seeing all of the RAS award winners!
Many respectable physicists said that they weren't going to stand for this - partly because it was a debasement of science, but mostly because they didn't get invited to those sort of parties."
-Douglas Adams The Hitchhiker's Guide to the Galaxy
2007 Galileo #6 seed, 5th Alliance Captain, Semi-finalist
2007 Philly Regional #4 Seed, Philly Regional GM Industrial Design Award Winner
2006 Philly Regional Highest Rookie Seed,Philly Regional Rookie All Star
Robot songs Alex Burman Chit-Chat 19 24-01-2006 08:07
2005 FRC Team Update 14 Jeffrafa General Forum 43 01-03-2005 15:52
Manual placement of tetras Petey Rules/Strategy 7 22-02-2005 18:04
A Question on Sportsmanship Steve M General Forum 31 25-05-2004 23:52
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
