Hex Couplers
Where can i buy the hex couplers and housing for the cim motors
ive looked all over the internet and i cant find a place that sells them also if anyone has any advice on holomorphic drive i am designing one to build during off season |
Re: Hex Couplers
holomorphic? you mean holonomic?
anyway, for holonomic, use mecanum wheels. they're harder to make, but allows you to push, and otherwise behave like a normal bot. Cheers! Tatsu |
Re: Hex Couplers
I'm not exactly sure about this, and someone please correct me if I'm wrong, but when buiding a holonomic drive, can't you also just use omni wheels rotated at 45 degrees from the chassis? Each wheel must be driven by individual motors but by using different sets of motor combinations you can move "sideways" and "forwards" without actually turning.
Re: Hex Couplers
Re: Hex Couplers
i designed the drive to use one motor for each of the wheels and they have there own transmission that i have also designed so each wheel is powered. But i cant find the hex couplers to build the drive train. Here is the picture.
Re: Hex Couplers
Those hex couplers are from the kit of parts provided several years ago. They are no longer available commercially, as far as I'm aware, as they were made for FIRST by Nypro. That said, there are probably plenty of teams who have them laying about their shop with no good use for them.
Before you get too far along, however, consider the eligibility of such parts for use in future robotics competitions. |
#7
Re: Hex Couplers
i could also use other suggestions for connecting cim motors to gears especially if i wont be able to buy them now.
#8
Re: Hex Couplers
Re: Hex Couplers
4 of the AndyMark single speed gearboxes wouldn't be a bad choice either, nor would Dewalt transmissions.
#10
Re: Hex Couplers
I'm going to second Sanddrag on using Dewalt gearboxes in a holonomic drive. They are very compact, reliable, relatively easy to mount and will give you a good speed to drive at. A bonus is that they're shiftable on the fly too. I'm a little worried from your picture that you're currently geared too fast. I can't tell the ratio exactly but a single geardown from a CIM usually isn't enough. You're definitely on the right track. Keep with your design and it looks like you should have a nice holonomic set up.
| I cant get my program into a hex file | Serge | Programming | 8 | 17-02-2006 03:28 |
| PIC16F84 -> Problem converting ASM to Hex | Ballam | Programming | 8 | 18-11-2005 14:12 |
| Hex file downloads | Ryan M. | Control System | 2 | 29-10-2005 19:50 |
| IFI Loader problem - "Invalid HEX file" | wun | Programming | 9 | 22-09-2004 12:35 |
| Securing hex shaft to drill output | D. Gregory | Technical Discussion | 6 | 24-01-2003 14:05 |
