Go to Post Maybe it just seemed like five hours...I had freshmen in my vehicle! - Qbot2640 [more]
View Poll Results: Reuse drive design?
Yes, exactly the same design every year 5 5.75%
Yes, but with improvements 54 62.07%
No 28 32.18%
Voters: 87. You may not vote on this poll
Unread 03-04-2006, 21:22
Re: reusing drive design
the chances of the optimum drive subsystem from one year being the optimum drive system for any other year are slim.
Unread 03-04-2006, 21:34
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
Can you?
absolutely
Have you?
for as far as i can remember, except for last year
Should you?
If it works
Will you?
Absolutely, 8 wheel drive on trucks works extremely well, even on ramps. we are guaranteed 6 wheel ground contact all the time.
Blargha!
Unread 03-04-2006, 21:40
Richsgt Richsgt is offline
AKA: Rich
FRC #0836 (Bobcat Robotics)
Richsgt is a jewel in the roughRichsgt is a jewel in the roughRichsgt is a jewel in the rough
Send a message via AIM to Richsgt
I don't think we've ever used the same drivetrain year to year, portions that work have been used but one item we have used the exact same design is the 177 arm...the long aluminum construction goes back to 1997 and has been used in some variation nearly every year.
Will we re-use...
If the game merits defensive strength again i can say we will definitely use this years again.
Should you...You definitely need to re-use what you know or at least take the best of what you know, i mean if you have a solid drive design with just tweaking it leaves more time to focus on the game specifics..and you can let the younger kids make the system as the design is 'mostly' done giving a good way to get them involved and up to speed on how to work with metal etc..
http://www.swindsor.k12.ct.us/Highschool/bobcats/
UTC Regional Champions 2006
Philly Regional Champions 2006
Galileo Division Champions 2006
Unread 03-04-2006, 21:46
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
This year we basically used last years design with some modifications. We added the larger CIM motor to the FIRST gear box and changed the size of the middle wheels. Anyhoo, trying to have one drive train for every year is hard. HOT BOT 67 was one of those teams. All of my years in FIRST they have started up right then fell over. This year the rules say you can't fall over, so they had to have a new design. This may not be the reason they changed there design, but its one of the reasons I think. (anybody from team 67 can correct me on this) Finally, If the specs for your drive train from past years will benefit you, then use it. Unless there were motors that aren't in the kit anymore, thats when it get interesting.
Unread 03-04-2006, 21:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We have done FRC for 6 years now. Every year, our drivetrain gets significantly better. However, there is always room for improvment. Next year's drivetrain will be the keeper I think.
Unread 03-04-2006, 21:59
Aaron D. Aaron D. is offline
AKA: A-ron
FRC #0341 (Miss Daisy)
Aaron D. is on a distinguished road
Send a message via AIM to Aaron D.
we have used the same drive system the past 2 years with 4 chips and 2 AM gear boxes, but we have always used tank drive, but we built an omni bot just to see how it worked. BUt I beilive it was talked about in a west v. east thread that the east coast tends to use the same drive, i find this true with most teams , 103 used the same drive last year and this year, so did 357, 341 did, and also 25 did.
It's Game Time
2006 to do list
Ship Robot- Mission Accomplished
Chesepeake regional-Engineering Inspiration
Philly Regional- Sportsmanship award
Nationals in Atlanta- 4th in GALI...LEO, Sportsmanship award
thanks to 86 and 190 for an awesome run in GA
Unread 03-04-2006, 22:10
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
We do believe in adapting to the game and we have experimented in the off-season with omni drive. Unfortunately in 2005 we thought that pushing and shoving would be more of a game factor.
For 2006 We did improve our drive system by adding a pop caster system that was programatically integrated. When you make a hard turn the air cylinder automatically fires, dramatically increasing your maneuverability. We also introduced an improved program based, automatic transmission.
Both improvements have contributed to our success (13-6) this year.
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Unread 03-04-2006, 23:20
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Can you? Yes, we can do it because we have time between now and next year to think about designs.
Have you? Certainly. Our 2005 robot was all about hugging the floor to avoid wedges. This year our robot (see photo- tag: frc604) was built with Poof clearance both sides and front/back, keeping it high off the floor. Two very diiferent designs.
Should you? I think so, because our center of gravity was just a tad too high this year. (You know what that means... Timber!)
Will you? Yes, because we are eager to try something different once again. You'll see next year!
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
On Game Design Matt Leese General Forum 38 30-04-2004 19:08
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
