Go to Post And then since this is GTR-W there's also maple syrup somewhere and the drive team says "Sooory." - PayneTrain [more]
View Poll Results: Reuse drive design?
Yes, exactly the same design every year 5 5.75%
Yes, but with improvements 54 62.07%
No 28 32.18%
Voters: 87. You may not vote on this poll
Unread 03-04-2006, 17:21
VEN's Avatar
VEN VEN is offline
The future isn't what it used to be
AKA: Volodymyr
VRC #0478 (Mustang Robotics)
VEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to allVEN is a name known to all
Send a message via MSN to VEN
reusing drive design
vote vote vote
Unread 03-04-2006, 17:26
Madison's Avatar
Madison Madison is offline
Dancing through life...
FRC #0488 (Xbot)
Re: reusing drive design
Can you? Have you? Should you? Will you?
Details, details, details.
--Madison--
...down at the Ozdust!
Unread 03-04-2006, 17:38
VEN's Avatar
VEN VEN is offline
AKA: Volodymyr
Can you? i think as long as its not the exact same chassis from last year its ok..as long as you build one
Have you? we haven't
Should You? if you see it as a great advantage, yes
Will you? if you see it as a great advantage, yes
sometimes its better to focus on the game piece part as that should take a lot of thought
Unread 03-04-2006, 17:57
Nuttyman54's Avatar
Nuttyman54 Nuttyman54 is offline
Mentor, Tactician
AKA: Evan "Numbers" Morrison
FRC #5803 (Apex Robotics) and FRC #0971 (Spartan Robotics)
Nuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond reputeNuttyman54 has a reputation beyond repute
Send a message via AIM to Nuttyman54
can you? most certainly. If it works, don't ignore it
Have you? not to my knowledge. Our best drivetrain (2004) is no longer usable because a) it used the drill motors and b) it used very heavy snowblower treads, which were great for getting up steps, but unnecessary for flat carpet or ramps. Plus it was really heavy.
Should you? Yes and no. If it works well, try to improve it. customize it for the specific game. I wouldn't suggest reusing the EXACT same drivetrain because you will probably be at a disadvantage to ones that were specially designed for the game. change the gear ratios, the wheels, etc.
Will you? probably, if we find one that works well. The team really liked the shifting transmissions we used this year, so we'll probably have some sort of multi-speed capability in the future.
Unread 03-04-2006, 18:05
shamuwong's Avatar
shamuwong shamuwong is offline
pretty little words.
AKA: Mike Wong
FRC #0469 (Las Guerillas)
shamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to beholdshamuwong is a splendid one to behold
On our team, we design the robot around the strategy. That includes the drive base.
While holonomic and crab drives were quite useful last year, with little defense and more focus on maneuverability, it has become apparent that such a drivetrain can be easily defended this year. This year requires more stability, as the field is very open and the objective of launching balls through the air into a goal is rather delicate.
If you're low on resources or design time, re-using a base may be a better idea. However, if you have the time/resources, I feel that your strategy should dictate 100% the design of your robot. This way, nothing is compromised.
Plus, it's more fun to try new drivetrains. I've always wondered what it's like to drive a holonomic or crab drive robot. Trying new things is part of the fun of FIRST.
ΜOΛΩΝ ΛΑΒΕ!
attending: great lakes regional, west michigan regional, detroit regional, the championship
Unread 03-04-2006, 19:05
kborer22's Avatar
kborer22 kborer22 is offline
kb
AKA: kb
FRC #0125 (Nutrons)
kborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud ofkborer22 has much to be proud of
Send a message via AIM to kborer22
if you look at what are considered the "great" teams in first you see, lets call it consistency with their drive trains. Teams such as 56(Robbie) 25(raider robotix) 11(MORT only in the last 3 years) 494 and many more tend to have a similar design. 25 has had 6 wheel drive forever....I think that it helps to establish a team, you have a strong base to build off of every year. I was a member of MORT from 03'-05' and starting in 04' we were able to design a drive train that was both powerful and quick. It ended up being one of the main reasons we won the Palmetto regional and placed 7th in our division at nationals. This year the team took that design and adapted it to fit this years game. I am currently on team 125 and last year they had a transmission, and this year we kept that but we also made changes to the sprocket ratio so that we could go faster and have more torque. Having a proven drive train allows you to make small adjustments and then concentrate more on the end effector or manipulator of choice.
NUTRONS 125
2007 Boston Regional Champs (125, 126, 69 NU-Hyper-Force!)
MORTTeam 11
2004-Palmetto Regional Champs
2004-Palmetto Regional Daimler Chrysler Team Spirit Award
2005-NJ Chairman's Award Winner
Unread 03-04-2006, 21:22
the chances of the optimum drive subsystem from one year being the optimum drive system for any other year are slim.
Unread 03-04-2006, 21:34
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
Can you?
absolutely
Have you?
for as far as i can remember, except for last year
Should you?
If it works
Will you?
Absolutely, 8 wheel drive on trucks works extremely well, even on ramps. we are guaranteed 6 wheel ground contact all the time.
Blargha!
Unread 03-04-2006, 21:40
Richsgt Richsgt is offline
AKA: Rich
FRC #0836 (Bobcat Robotics)
Richsgt is a jewel in the roughRichsgt is a jewel in the roughRichsgt is a jewel in the rough
Send a message via AIM to Richsgt
I don't think we've ever used the same drivetrain year to year, portions that work have been used but one item we have used the exact same design is the 177 arm...the long aluminum construction goes back to 1997 and has been used in some variation nearly every year.
Will we re-use...
If the game merits defensive strength again i can say we will definitely use this years again.
Should you...You definitely need to re-use what you know or at least take the best of what you know, i mean if you have a solid drive design with just tweaking it leaves more time to focus on the game specifics..and you can let the younger kids make the system as the design is 'mostly' done giving a good way to get them involved and up to speed on how to work with metal etc..
http://www.swindsor.k12.ct.us/Highschool/bobcats/
UTC Regional Champions 2006
Philly Regional Champions 2006
Galileo Division Champions 2006
Unread 03-04-2006, 21:46
Jherbie53's Avatar
Jherbie53 Jherbie53 is offline
Hoshua The 2nd
AKA: Joshua aka "Hosh"
FRC #0085 (Built On Brains B.O.B.)
Jherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to beholdJherbie53 is a splendid one to behold
Send a message via Yahoo to Jherbie53
This year we basically used last years design with some modifications. We added the larger CIM motor to the FIRST gear box and changed the size of the middle wheels. Anyhoo, trying to have one drive train for every year is hard. HOT BOT 67 was one of those teams. All of my years in FIRST they have started up right then fell over. This year the rules say you can't fall over, so they had to have a new design. This may not be the reason they changed there design, but its one of the reasons I think. (anybody from team 67 can correct me on this) Finally, If the specs for your drive train from past years will benefit you, then use it. Unless there were motors that aren't in the kit anymore, thats when it get interesting.
Unread 03-04-2006, 21:50
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
We have done FRC for 6 years now. Every year, our drivetrain gets significantly better. However, there is always room for improvment. Next year's drivetrain will be the keeper I think.
Unread 03-04-2006, 21:59
Aaron D. Aaron D. is offline
AKA: A-ron
FRC #0341 (Miss Daisy)
Aaron D. is on a distinguished road
Send a message via AIM to Aaron D.
we have used the same drive system the past 2 years with 4 chips and 2 AM gear boxes, but we have always used tank drive, but we built an omni bot just to see how it worked. BUt I beilive it was talked about in a west v. east thread that the east coast tends to use the same drive, i find this true with most teams , 103 used the same drive last year and this year, so did 357, 341 did, and also 25 did.
It's Game Time
2006 to do list
Ship Robot- Mission Accomplished
Chesepeake regional-Engineering Inspiration
Philly Regional- Sportsmanship award
Nationals in Atlanta- 4th in GALI...LEO, Sportsmanship award
thanks to 86 and 190 for an awesome run in GA
Unread 03-04-2006, 22:10
OZ_341's Avatar Unsung FIRST Hero
OZ_341 OZ_341 is offline
#0341 (Wissahickon)
OZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond reputeOZ_341 has a reputation beyond repute
We do believe in adapting to the game and we have experimented in the off-season with omni drive. Unfortunately in 2005 we thought that pushing and shoving would be more of a game factor.
For 2006 We did improve our drive system by adding a pop caster system that was programatically integrated. When you make a hard turn the air cylinder automatically fires, dramatically increasing your maneuverability. We also introduced an improved program based, automatic transmission.
Both improvements have contributed to our success (13-6) this year.
2010 Championship Chairman's Award
2016 MAR District Champion (thank you 225 & 1257)
2016 Galileo Division, #6 Seed, 9 W - 1 L
2016 MAR District Innovation in Controls Award
2016 Westtown District Finalist (thank you 4954 & 484)
2016 Westtown District Imagery Award (It took 17 yrs)
2016 Hatboro District Judge's Award
Overall Record 49 W - 21 L
Unread 03-04-2006, 23:20
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Can you? Yes, we can do it because we have time between now and next year to think about designs.
Have you? Certainly. Our 2005 robot was all about hugging the floor to avoid wedges. This year our robot (see photo- tag: frc604) was built with Poof clearance both sides and front/back, keeping it high off the floor. Two very diiferent designs.
Should you? I think so, because our center of gravity was just a tad too high this year. (You know what that means... Timber!)
Will you? Yes, because we are eager to try something different once again. You'll see next year!
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 04-04-2006, 00:14
Billfred's Avatar
Billfred Billfred is offline
Can you? As long as it meets the rules of whatever manual you happen to have, yes.
Have you? Not yet. 1293 started with window-motor drive in 2004, then progressed to kitbot-based 2WD, then this year went to 6WD with Skyways and IFIs.
Should you? I believe it was Dr. Joe who said a good drive base is key to an inspirational season. If you can best inspire the kids by using an older design, go for it.
Will you? Ask me in about nine months. Seriously, though, if the game next year calls for what we used (and abused) on Chomp, I intend to push for its return.
On Game Design Matt Leese General Forum 38 30-04-2004 19:08
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
