Go to Post FIRST is not the party- its the people. We can have a great competition no matter where we hold it. - Wayne C. [more]
Unread 03-04-2006, 23:00
Re: pic: My weekend project
Originally Posted by mechanicalbrain
Actually after some testing I found I can run everything except the larger motors with one of these. If I combine 12 volt cables I can get the larger motors to run but im very hesitant to do it.
NOTE: I haven't run anything for more than brief moments at a time and im going to add fuses before I do anything else.
If that is a power supply from a computer you will fry it running motors. Its not designed to handle large loads (the CIMs can pull >50A when they first start up) and they are not designed to handle inductive loads either.
If you want to power the robot motors you need something with a big transformer that can supply the amps.
Unread 03-04-2006, 23:06
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Originally Posted by Nuttyman54
So THAT's where all the cold cathodes went...
Related Thread?
Where did all the cathodes go? Long time passing.
Where did all the cathodes go? Long time ago.
When will they ever learn? When will they ever learn?
Unread 03-04-2006, 23:35
mechanicalbrain's Avatar
mechanicalbrain mechanicalbrain is offline
The red haired Dremel gnome!
FRC #0623 (Ohm robotics)
Team Role: Electrical
mechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond reputemechanicalbrain has a reputation beyond repute
Send a message via AIM to mechanicalbrain Send a message via Yahoo to mechanicalbrain
Yeah it worked fine for free spin but I'm not trying it while mounted to anything. I think ultimately I'm going to use this to power our test board that we use for programming and sensors. Not a bad use since it's a pain to switch out batteries for a couple sensors, especially because people keep mischarging them. I've been playing with AC to DC converters a bunch lately, first running our light target and now for the test board... It's just easier then lugging batteries and chargers.
"Oh my God! There's an axe in my head."
623's 2006 home page
random mechanicalbrain slogans
Unread 04-04-2006, 17:12
[527]phil's Avatar
[527]phil [527]phil is offline
Alumni
AKA: Phil
FRC #0527 (red dragons)
[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light[527]phil is a glorious beacon of light
Send a message via AIM to [527]phil
this is perfect for using as a power supply for my workbench!!! normally i use wall warts. But usually i need 2-3 (9volts, 5volts, and 12 volts). This is perfect for PIC prototyping . Too bad you can't draw too much current or else i could use it when i experiment with electro kinetics :/. And you have excellent timing, i was just about to unsolder a power supply
Whats the difference between mechanical engineers and civil engineers?
Mechanical engineers build weapons, civil engineers build targets
Want to learn PIC Programming? Good deal here! Rombus Chit-Chat 2 10-04-2006 11:43
Ideas for my Gold Award Project Sarah Bowes General Forum 4 24-06-2005 18:25
Programming a 2nd PIC ImmortalAres Programming 8 16-06-2005 12:13
openFIRST Project Stats Timothy D. Ginn FIRST-related Organizations 4 01-06-2005 15:54
MS Project Build Schedule joe_balint Technical Discussion 1 07-01-2002 03:25
