| View Poll Results: Reuse drive design? | |||
| Yes, exactly the same design every year |
5 | 5.75% |
| Yes, but with improvements |
54 | 62.07% |
| No |
28 | 32.18% |
| Voters: 87. You may not vote on this poll | |||
Re: reusing drive design
Can you? As long as it meets the rules of whatever manual you happen to have, yes.
Have you? Not yet. 1293 started with window-motor drive in 2004, then progressed to kitbot-based 2WD, then this year went to 6WD with Skyways and IFIs. Should you? I believe it was Dr. Joe who said a good drive base is key to an inspirational season. If you can best inspire the kids by using an older design, go for it. Will you? Ask me in about nine months. Seriously, though, if the game next year calls for what we used (and abused) on Chomp, I intend to push for its return. |
We have used similar drive trains the past 2 years (6WD with 4 motor kit transmissions), the only changes being wheel position and sprocket size. 2 years ago though we had our 2WD and casters, and prior to that we had a series of 4WD that turned terribly.
Depending on how the off-season goes will determine what happens with the drive train next year. If we aren't using an almost identical one to the past 2 years then we will finally be trying a drive train without wheels. |
Since the begining SPAM has been using our evoultion of a Tank design. in 2004 we hung out on the limb and made a VERY sucsessful Holonomic drive. in 2005 we made used the dewalt gear boxes with a new 4 tread system. we reused it this year.
Team 1255 started with a tread-based drive two years ago, kept the treads last year, and moved away from them to a 4WD this year. However, all three years the drives were structured for power over mobility. Anyone that saw us this year wouldn't dare call us an "agile" team, but when you can nearly push another robot onto your ramp at 3/4 power (missing one of 4 chains) then you know you've got a strong drive.
I'm graduating this year, but I'd like to think that the team will keep the defensive strategy that has served us well. That said, hopefully they will explore other 4WD setups (other trannies besides the kit), 6WD setups, and maybe delve back into the tread designs. |
| On Game Design | Matt Leese | General Forum | 38 | 30-04-2004 19:08 |
| 1 stick drive to 2 stick drive | wayne 05 | Programming | 18 | 01-04-2004 16:41 |
| How do you design your robot? | Gui Cavalcanti | General Forum | 23 | 16-11-2003 18:33 |
| Quad- 1/2 track drive system | Ben Mitchell | Technical Discussion | 24 | 30-01-2002 11:55 |
| "Motors and Drive train edition" of Fresh From the Forum | Ken Leung | CD Forum Support | 6 | 29-01-2002 12:32 |
