Go to Post The engineer mentors ARE part of the team, equals with the students in every aspect - KenWittlief [more]
View Poll Results: Reuse drive design?
Yes, exactly the same design every year 5 5.75%
Yes, but with improvements 54 62.07%
No 28 32.18%
Voters: 87. You may not vote on this poll
Unread 04-04-2006, 00:58
Re: reusing drive design
Originally Posted by Billfred
1293 started with window-motor drive in 2004, then progressed to kitbot-based 2WD, then this year went to 6WD with Skyways and IFIs.
Heh. We went from drill motors in '04 to kitbot 2WD last year to 6WD with 9x2 Skyway Beadloks this year. But then you are a much older team than we are...
Unread 04-04-2006, 01:19
Donut Donut is offline
The Arizona Mentor
AKA: Andrew
FRC #2662 (RoboKrew)
We have used similar drive trains the past 2 years (6WD with 4 motor kit transmissions), the only changes being wheel position and sprocket size. 2 years ago though we had our 2WD and casters, and prior to that we had a series of 4WD that turned terribly.
Depending on how the off-season goes will determine what happens with the drive train next year. If we aren't using an almost identical one to the past 2 years then we will finally be trying a drive train without wheels.
Unread 04-04-2006, 01:38
killerofkiller's Avatar
killerofkiller killerofkiller is offline
S.P.A.M. .... IT's PEOPLE!
FRC #0180 (S.P.A.M)
killerofkiller will become famous soon enoughkillerofkiller will become famous soon enough
Since the begining SPAM has been using our evoultion of a Tank design. in 2004 we hung out on the limb and made a VERY sucsessful Holonomic drive. in 2005 we made used the dewalt gear boxes with a new 4 tread system. we reused it this year.
Who are we?
180
Who are we?
SPAM SPAM!
Unread 04-04-2006, 01:43
GB330033 GB330033 is offline
Programming Manager
FRC #1255 (Team Blarglefish)
GB330033 will become famous soon enough
Send a message via AIM to GB330033
Team 1255 started with a tread-based drive two years ago, kept the treads last year, and moved away from them to a 4WD this year. However, all three years the drives were structured for power over mobility. Anyone that saw us this year wouldn't dare call us an "agile" team, but when you can nearly push another robot onto your ramp at 3/4 power (missing one of 4 chains) then you know you've got a strong drive.
I'm graduating this year, but I'd like to think that the team will keep the defensive strategy that has served us well. That said, hopefully they will explore other 4WD setups (other trannies besides the kit), 6WD setups, and maybe delve back into the tread designs.
Hook'Em
Unread 04-04-2006, 01:56
LightWaves1636's Avatar
LightWaves1636 LightWaves1636 is offline
is all over it.
AKA: Sarah Le
LightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to beholdLightWaves1636 is a splendid one to behold
Send a message via AIM to LightWaves1636 Send a message via Yahoo to LightWaves1636
well, this is our second year and we used the same four wheel drive, but I don't know, as long as the wheels don't get pressed in, the chain won't fall off. So we'll see what we do next year.
FLL Team - Hackberry Hill Elementary - Arvada, CO ('08 - '10 Coach)
FRC Team 1636 - Reds Robotics - Arvada High School - Arvada, CO ('05 - '07 Alumni)
FRC Team 1583 - Rambotics - Ridgeview Academy - Watkins, CO (Volunteer/Supporter)
FRC Team 2859 - Blasterbots - CSM Robotics Outreach - Golden, CO ('09 - '10 Coach)
FRC Team 3320 - Miracles & Machines - Eastside Memorial High School - Austin, TX ('10 - '12 Mentor)
Unread 04-04-2006, 03:35
Squidget357 Squidget357 is offline
Graphic Designer/Web Development
AKA: Adam
FRC #0357 (Royal Assault)
Squidget357 is an unknown quantity at this point
Send a message via AIM to Squidget357
We (357) stuck with our mechanum wheels this year but used 9 rollers per wheel instead of 6, redesigned the rollers to have a hard inner core for durability and a soft outer layer for traction, and also mounted one set of the wheels on a pivot to make sure that all four wheel came in contact with the ground at all times. Our record this year so far is 16-4-0, and the modifications really helped achieve that.
I gues my vote is that if you can make it better, go for it.
On Game Design Matt Leese General Forum 38 30-04-2004 19:08
1 stick drive to 2 stick drive wayne 05 Programming 18 01-04-2004 16:41
How do you design your robot? Gui Cavalcanti General Forum 23 16-11-2003 18:33
Quad- 1/2 track drive system Ben Mitchell Technical Discussion 24 30-01-2002 11:55
