Go to Post FIRST doesn't end after your last year within a team. It's never going to end. - Tetraman [more]
View Poll Results: Which of these sensors did your team use on your robot?
Limit Switch 27 57.45%
Optical Encoder 16 34.04%
Gyro 28 59.57%
Allen-Bradley Photoswitch 11 23.40%
Banner sensor 7 14.89%
Optical mouse 1 2.13%
Gear tooth sensor 17 36.17%
Accelerometer 7 14.89%
IR or Ultrasonic Ranger 10 21.28%
Other (please post about what you are using) 10 21.28%
Multiple Choice Poll. Voters: 47. You may not vote on this poll
Unread 04-04-2006, 14:04
devicenull devicenull is offline
Robot? We need a robot?
Rookie Year: 1234
devicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nicedevicenull is just really nice
Re: What sensors do you use?
CMUcam was probably the most important sensor this year.. without it, our turret would have been useless. Limit switches were used to prevent the turret from turning too far, although because of its construction, they weren't really needed.
The gyro was on our robot, but not used for much. It worked, but once we started using 4WD IFI traction wheels, it wasn't needed at all.
Encoder kept the shooter running at the proper speed which resulted in very small delay's between balls.
Sharp IR distance sensors Gdeaver Electrical 13 10-02-2007 20:36
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
jumper cabling from sensors to controller Gary Dillard Electrical 4 23-12-2005 07:42
Bumper sensors jeffmorris FIRST Tech Challenge 1 02-10-2005 16:20
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
