Go to Post my original intention were that the 5 of them were the power rangers, but then i thought of Copioli as the Pink Ranger and laughed... a lot - Mike Schroeder [more]
Unread 04-04-2006, 23:08
Chriszuma's Avatar
Chriszuma Chriszuma is offline
Jack of all trades
AKA: Chris Hammond
FRC #0068 (Truck Town Thunder)
Chriszuma is just really niceChriszuma is just really niceChriszuma is just really niceChriszuma is just really nice
Send a message via AIM to Chriszuma
pic: PSA: Watch your metal shavings
2006 T3 World Tour: Great Lakes - Waterloo - Palmetto - IRI
2006 Awards: Motorola Quality - RadioShack Innovation in Control
My website: http://zuma.phire.org/
Truck Town Thunder's website: http://trucktownthunder.com/
Unread 04-04-2006, 23:12
Umm Errr...
Re: pic: PSA: Watch your metal shavings
This seems to be a very common problem among teams. IFI slathers conformal coating all over the board except the FET heatsinks. Maybie they leave out the sinks for thermal reasons. If this is the case, why don't they use some anodized aluminum heatsinks.
The heatsinks would provide improved thermals and the anodization would provide some shaving protection.
The IFI people are smart. I would think that they would work toward a way to fix this issue. Sure its the team's fault, but competitor's speed controller designs do not have exposed FETs.
1139 Alumni
Unread 04-04-2006, 23:14
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
Well what they really should do is put some sort of rubber above the circuit board and below the heatsinks so little shavings can't slip into the holes in the case. Maybe we'll find a way to modify them.
Unread 04-04-2006, 23:18
Richard Wallace's Avatar
I live for the details.
FRC #3620 (Average Joes)
Or (to take the electrical engineer's side) we could all just refrain from drilling, sawing, grinding, filing, and other chip-making activities in proximity to closely spaced electrical conductors!
(Why yes, I am an electrical engineer!)
Richard Wallace
since 2003
Unread 04-04-2006, 23:20
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
Ah, how nice it would be to live in a perfect world... ;-)
Unread 04-04-2006, 23:57
What a marvelous picture! Wonder what might have been in the hole? There is a FET missing from the board. Once the shaving(s) were layed down and power applied, a hot spot/arc developed, then the FET set itself on fire or might have exploded. Then the board succumbed to the high heat. I bet it smells really bad as well. Conformal coatings are not meant for transistor packages that exist above the circuit board or those components that may get hot. In this case, a little insulation around the FET leads (as they entered the board) might have helped. Now you know why electrical guys are always complaining about metal shavings and inspectors are always watching for wiring errors and circuit breaker use. I bet the breakers were tripping but the wires leading to the controller were not damaged.
Unread 05-04-2006, 02:15
David Brinza's Avatar
David Brinza David Brinza is offline
Lead Mentor, Lead Robot Inspector
FRC #0980 (ThunderBots)
David Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond reputeDavid Brinza has a reputation beyond repute
I wouldn't be surprised if when we get to Atlanta, Team 4 discovers at least one of our Victors has a toasted FET.
When we powered on our robot at the start of our second semi-final match at the GTR, a cloud of "magic smoke" appeared. Prior to going onto the field for match #2, we had used our timeout to repair battle damage. In the first match, the sheet aluminum "scoop" for our ball collector had snagged on the edge of the ramp, folded under the robot and ripped a portion of the lexan sheet on which our electronic components are mounted. The sheet aluminum was removed and, in order to re-attach the lexan board with zip-ties, some holes were drilled some sheet aluminum above the board. In the heat of battle, the electronics were not covered nor blown out with compressed air before going back onto the field. I suspect a bit of aluminum may have found its way into a Victor and caused a short - poof!
Our #4 alliance (229, 217 and 4) managed to beat the #1 alliance (1114, 1503, 865) in the first semi-final match. In the second and third matches, our drive system was clearly hobbled. Teams 1114 and 1503 were an awesome scoring pair and if you give them a few seconds, they can rack up a big score. We couldn't harass either of the two triplets effectively, so they rattled the chains over heads with a deluge of balls.
"There's never enough time to do it right, but always time to do it over."
2003 AZ: Semifinals, Motorola Quality; SoCal: Q-finals, Xerox Creativity; IRI: Q-finals
2004 AZ: Semifinals, GM Industrial Design; SoCal: Winners, Leadership in Controls; Championship: Galileo #2 seed, Q-finals; IRI: Champions
2005 AZ: #1 Seed, Xerox Creativity; SoCal: Finalist, RadioShack Controls; SVR: Winners, Delphi "Driving Tomorrow's Technologies"; Championship: Archimedes Semifinals; IRI: Finalist
2007 LA: Finalist; San Diego: Q-finals; CalGames: Finalist || 2008 San Diego: Q-finals; LA: Winners; CalGames: Finalist || 2009 LA: Semifinals; Las Vegas: Q-finals; IRI: #1 Seed, Finalist
2010 AZ: Motorola Quality; LA: Finalist || 2011 SD: Q-finals; LA: Q-finals || 2013 LA: Xerox Creativity, WFFA, Dean's List Finalist || 2014 IE: Q-finals, LA: Finalist, Dean's List Finalist
2016 Ventura: Q-finals, WFFA, Engineering Inspiration
Unread 05-04-2006, 10:13
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
I'm sure out EE's work work toward a fix, if we felt there WAS an issue.
It's really not a common problem.
We shipped about 4000 Victors in the kit this year. I wonder how many of those were burnt out by teams. 1% = 40? Less?
I think everyone will agree it's a very robust product.
Now would you rather pay more for every victor, for protection to solve a non-issue, or would you rather lay down a towel?
-JV
Unread 05-04-2006, 10:44
Billfred's Avatar
Billfred Billfred is offline
-JV
I'd imagine that the number of Victors that release the magic smoke for one reason or another is in the lower hundreds. Every team has that moment of foolishness, that moment of "Eh, surely we can't blow a Victor doing this..."
That said, the cheap option remains to find a towel/box/big piece of bubble wrap for the purpose. (I think it'd be kinda awesome to have an aftermarket cover that fits over the Victor and around the wires for these kinds of fabrication events. Then again, that may just be me.)
Unread 05-04-2006, 10:57
O-H
FRC #0048 (Delphi E.L.I.T.E.)
A heavy fabric shop coat works well. The shavings easily brush off upon removal for quick cleanup and reuse. Towels and rags leave gaps for shavings to get through. One continuous covering to protect the electronics is better.
Unread 05-04-2006, 11:11
Another possibility is to apply a conformal coating to the exposed leads on the FETs. Putting electrical tape over the power and motor connections is a no brainer, but most teams won't want to open up the Victor to brush on an insulating coating on the FET leads.
Unread 05-04-2006, 11:24
Dave,
This is not a sure fix with all the vibration and bumping of the FET cases. The coating would eventually break out. It is far simpler to protect with a shop coat or turn the robot on it's side and let gravity take over. If your mechanical guys knew the cost of replacement, there would be more care taken around an expensive component. Remember too, it is not always just one wayward shaving. Many of the Victor failures I have examined were full of aluminum "dust" and shavings. Enough to wipe your finger across the board and come back visibly silver. Drilling is not the only operation, deburring creates as much or more and using compressed air makes matters worse. Use a vacuum when possible. Compressed air drives the metal into open frame motors, bearings, gears and electronics. Any of which will cause some form of failure.
Unread 05-04-2006, 11:54
Originally Posted by Al Skierkiewicz
...Drilling is not the only operation, deburring creates as much or more and using compressed air makes matters worse. Use a vacuum when possible. Compressed air drives the metal into open frame motors, bearings, gears and electronics. Any of which will cause some form of failure.
Slightly off-topic, but this reminds me of the machine shop supervisor I worked with in college. He did not allow any use of compressed air to blow chips (a practice I have since observed in many shops) on the grounds that you can't control where a blown chip will land. This supervisor rigidly enforced a policy of vacuuming all chips between cutting operations, and stopping work 30 minutes before shop-closing time to thoroughly vacuum the areas around all the machines.
Of course, this guy worked for the School of Electrical Engineering (now ECE) at Georgia Tech, and many of his jobs were for research in electronics and optics, so maybe he was a little more sensitive about chips than your average mechanical person.
Richard Wallace
since 2003
Unread 05-04-2006, 22:08
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
This reminds me of two things:
1. Our Robot Controller a couple months ago
2. My Computer's Power Supply 3 weeks ago
Funny thing is, our robot controller quit because of aluminum chips too
I watch everyone with a drill like a hawk now.... kinda paranoid i guess you could say.
-Q
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 06-04-2006, 00:21
Chriszuma's Avatar
Jack of all trades
AKA: Chris Hammond
-Q
Yeah that has always been the policy, to be paranoid about metal shavings, somebody just didn't get the memo I guess.
pic: 865 Robot: Cant watch this davelu Robot Showcase 0 22-02-2005 14:01
pic: Team 343 Metal In Motion CD47-Bot Robot Showcase 7 27-03-2004 20:43
