Go to Post If sponsors are only interested in blue banners and trophies, then they don't get it. - Taylor [more]
View Poll Results: Which of these sensors did your team use on your robot?
Limit Switch 27 57.45%
Optical Encoder 16 34.04%
Gyro 28 59.57%
Allen-Bradley Photoswitch 11 23.40%
Banner sensor 7 14.89%
Optical mouse 1 2.13%
Gear tooth sensor 17 36.17%
Accelerometer 7 14.89%
IR or Ultrasonic Ranger 10 21.28%
Other (please post about what you are using) 10 21.28%
Multiple Choice Poll. Voters: 47. You may not vote on this poll
Unread 05-04-2006, 12:30
Re: What sensors do you use?
Originally Posted by mechanicalbrain
Did anyone use a optical mouse? From what I understand, besides needing a lense setup to give it any range, it only has 12 ips with a 1 to 1 lense ratio as set by NASA (http://www.nasatech.com/Briefs/Oct05/NPO_40173.html). I guess this should be odometers in general.
We did a lot of experimenting last year with using an optical mouse for position tracking. Mark Koors came up with the right lens for making it into a "telephoto" system, Wildstang's programmers contributed code for communicating directly with a specific mouse chip, and we had travel and turn sensing working okay as long as the height of the mouse above the carpet did not vary. However, as little as a millimeter of height change gave a significant difference in detected travel. I finally decided that it wasn't going to be possible to get consistent data from the scheme if the mouse wasn't physically in contact with the carpet.
Our robot last year used a trio of miniature "follower" omniwheels with encoders to give us feedback on forward/backward travel, sideways travel, and turn angle.
Sharp IR distance sensors Gdeaver Electrical 13 10-02-2007 20:36
where can we buy hall effect sensors or gear tooth sensors amirjpl Electrical 3 13-02-2006 11:02
jumper cabling from sensors to controller Gary Dillard Electrical 4 23-12-2005 07:42
Bumper sensors jeffmorris FIRST Tech Challenge 1 02-10-2005 16:20
Why not analog sensors?? gnormhurst Programming 16 07-03-2004 16:14
