Go to Post Uhh... we were supposed to be building a robot? *looks at giant wooden Trojan Rabbit in the corner that was built instead for the past 6 weeks* Whoops... - Adam Richards [more]
Go Back   Chief Delphi > Technical > Kit & Additional Hardware
  #31   Spotlight this post!
Unread 29-03-2006, 12:07
Biff Biff is offline
AKA: Tom Cooper
#1227 (Techno Gremlins)
Biff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the roughBiff is a jewel in the rough
Re: Bring Back the Rotating Light
Originally Posted by DanielBCR
Honestly, I was not a huge fan of the rotating light because of how they broke. If they do bring it back, it should be with a tougher cover that won't crack (and in several cases shatter). Also, it would be better if it didn't count towards the weight limit.
You hit the nails on the head(s).
  #32   Spotlight this post!
Unread 29-03-2006, 16:33
Alex Burman's Avatar
Alex Burman Alex Burman is offline
∆o□
AKA: The Burmanator
FRC #0075 (Roboraiders)
Alex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud ofAlex Burman has much to be proud of
Send a message via AIM to Alex Burman Send a message via MSN to Alex Burman Send a message via Yahoo to Alex Burman
i think we brought the rotating light to a whole new level
The Burmanator
www.Roboraiders.com
http://www.myspace.com/burmanator
  #33   Spotlight this post!
Unread 29-03-2006, 17:35
gizmoman1089's Avatar
gizmoman1089 gizmoman1089 is offline
AKA: ray palmere
None #1089 (gizmoman1089)
Team Role: Driver
gizmoman1089 can only hope to improve
Wink Re: Bring Back the Rotating Light
I beieve that know matter what happens there will always be some sort of light on the robot. This light ensures the ref's and yourself that your robot is powered up and on the right team. Though the rotating lights did break in the 2003 season (my rookie year) I sort of liked them better. This year FIRST only supplied teams with one L.E.D. If FIRST is going to keep the L.E.D's then they should ensure that all teams have an L.E.D on all four sides of there machine. OR they should bring back the rotating light. To solve the issue of weight, when you get weighed in they should subtract the exact amount of weight for the LIGHT. not including wireing. (even the light weight L.E.D.'s had wires.)
PROUD TO BE A BMS TEAM
1089 woohoo
  #34   Spotlight this post!
Unread 29-03-2006, 22:10
chrisinmd's Avatar
chrisinmd chrisinmd is offline
AKA: Chris Pickett
FRC #0888 (Robotiators)
chrisinmd is a jewel in the roughchrisinmd is a jewel in the roughchrisinmd is a jewel in the rough
Send a message via AIM to chrisinmd
I found an old LED from last year so I had two to mount on the robot. One on each side of our bin, high up. I think the hight and the fact that there was two of them helped a lot to tell whether or not the robot was powered up, what mode it was in, and which alliance it was on. Sometimes it was hard to see the LED on other robots, although I didn't see any that had negelected it entirely, some of them were hidden well!
The flags worked well, but there was an issue with them coming out when robots were tipped, and I did see one instance where a poof ball from a shooter hit the top of the flag and sucked it right out of the holder.
-Chris
Virginia Tech 2010!
Chesapeake Regional
Pittsburgh Regional
  #35   Spotlight this post!
Unread 30-03-2006, 07:38
mtaman02's Avatar
mtaman02 mtaman02 is offline
FIRST's Spare, Queuer & Tech guy =)
AKA: Mike M. / Mouse =)
no team (FRC Volunteer)
mtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant futuremtaman02 has a brilliant future
Send a message via AIM to mtaman02 Send a message via Yahoo to mtaman02
Originally Posted by KenWittlief
there is something deeply ingrained in our subconscous, when we see a rotating red or blue light it triggers an almost instinctive emotional response:
"DANGER! WARNING! EMERGENCY! POWER! CAUTION! STAY BACK!"
The old rotating lights had that sense of seriousness: this is a powerfull dangerous machine - stay back!"
You just dont get that same emotional punch from a bunch of blinking LEDS, or bicycle flags.
Yeah on a lot of the robots from 3 years ago, with the rotating light they looked extremely cool
The Good Things about the lights
- They worked and you didn't have to worry about the connectors falling off the RC
The Bad Things about the lights
- They did use alot of energy and in a game like this years the battery would be completely dead.
- They had their share of weight and location issues.
The Good Things about the LEDs
- They too also work and last alot longer then a standard light bulb
- They help identify certain issues with the robot (mainly hardware or software) if they are mounted were they can be easliy seen
- They're virtually weightless
The Bad Things about the LEDs
- They too also have location issues
- There is no way to fasten them to the RC whatsoever so that the connectors don't come off if a robot went head on with a wall or another robot.
I don't like the flags all that much makes the robots look alot less serious. Yeah they help with identifying the teams but only if the team remembers to put them on their robot. They can become a flying projectile, they can break extremely easliy if not mounted the right way. There's just to much problems with having a flag on the robot, and it can confuse the driver as to where the robots position is on the field. At least with light covers & LEDs they didn't waive in the wind or obstruct anothers view.
Too Solve the LED wiring issue if you cut the wires for the leds to the size you need it and resolder the wires you'll be okay but always leave like 3 inches on the connector end and take what off what you don't need from the LED end and mate the pieces together simple 1-2-3 =) and it looks better too.
Heres an Idea: If FIRST set some guidlines that the light can be powered off of its own source but must remain in the electrical circuit and it would not be counted towards the weight & that a mandatory LED must be attached to the robot & clearly visible so that IFI can identify problems with your robot before / during / after a match , would you the teams take the light back. Theres just one catch Teams cannot abuse the amount of wire used. I see alot of teams that have nice looking robots and nicely mounted electronics but a ball of yarn underneath everything in hiding. Use only What you need and dispose of the rest, You'll save the little bit of weight that matters the most that way. Wire doesn't way much but will help in getting rid of that couple of ounces rather then swiss cheesing (Drilling) the chassis which should always be a last resort. And it will make everything look so much more neater and accessible.
Past FIRST Robotics Events that I proudly volunteered at:
FLL: NY State Competition '03
FRC: NYC Remote Kickoff '04 & NYC Regionals '04-'15 ,'10-'13 & NJ Regionals '06-'10, Finger Lakes Regional '09 & SBPLI Regional '08-'15 and the World Championship in '05 (Galileo Field) '07 (Newton Field) '09 (Practice Fields Attendant / FTA(A)), CeBIT Convention in '04 & NextFEST in '06 both held @ the Javitts Center, Monty Madness '07-'10, Panda-monium '08, B.Eruption '08 & '09, Ramp Riot '08, PARC '09 & '10, BR^2 '09 & Wol. Inv. '09 -'15
2015 FIRST Robotics Off Season Events that I hope to volunteer at:
Where is Wolcott Invitational
2015 FIRST Robotics Events that I will be volunteering at:
SBPLI Reg. & Championships
Volunteer Resume:
Alt & Lead Team Queuer, Field Repair/Reset, Field Setup/Breakdown, Spare Parts Attendant, Field Power Controller/Score Keeper, Co-Emcee & Official Scorer, Control System Advisor, FIRST Tech Advisor Assistant & recently Practice Field Attendant.
  #36   Spotlight this post!
Unread 30-03-2006, 13:46
dhitchco's Avatar
dhitchco dhitchco is offline
Awards/Photo/Video "wizard"
AKA: Doug Hitchcock
FRC #1511 (Rolling Thunder)
dhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant futuredhitchco has a brilliant future
Here are some LED light assemblies that scream "danger, I'm tough".
http://www.galls.com/style.html?asso...og&style=GR030
Maybe next year. I agree that I like lights better than flags. The other "small" issue with flags this year is that they're popping-out of the PVC pipes as robots get hit hard and become nuisance items on the playing field. Plus lights are easier to see who's in the backfield, not fromthe judging perspective, but from a fan's perspective sitting in the "nose bleed" seats in the Georgia Dome.
The THUNDER just keeps getting LOUDER in 2008....
Team 1511 now supports over 15 FLL teams
RollingThunder....Winner of the 2007 Chairman's Award at Finger Lakes Regional and Spirit Award at Boston.....Winner of 2006 Finger Lakes Regional Engineering Inspriation and Boston Imagery awards.......Winner of 2005 World Championship Rookie All-Star (plus FLR Rookie All-Star, Buckeye Top-Seeded Rookie, GTR Champion, Spirit, and Inspiration)
"Gracious Professionalism is a WAY of life".....
  #37   Spotlight this post!
Unread 30-03-2006, 13:51
uhmmmm.... what?! the page in your link has Halogen lamp warning lights - $45 each.
Halogen LEDs?! did I miss a breakthrough in displays? :^)
  #38   Spotlight this post!
Unread 30-03-2006, 14:58
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
I agree. Those lights owned. I think one of the reasons they got rid of them in the first place is so teams don't have to worry about what alliance they are going to be on. That's why the crew has them and gives them out while the teams que for their match like this year.
  #39   Spotlight this post!
Unread 30-03-2006, 16:17
Rich Wong Rich Wong is offline
NYC FIRST Planning Committee Member
no team (NYC FIRST)
Rich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond reputeRich Wong has a reputation beyond repute
Send a message via AIM to Rich Wong
I found these items that maybe a better solution for FRC in the future-
LED clusters and LED light bulbs. All use 12vdc.
The 3 inch cluster only draw 220ma; but kind of expensive at $181 a piece.
The colors available are white, red, green, blue and amber.
popularis de ob instinctus agnitionis scientia technologia
Home website: www.nycnjfirst.org
Member of NEMO & e^(i*pi)+1 Fraternity.
Member of Friends of Robots
Member of NYCFIRST Planning Committee
  #40   Spotlight this post!
Unread 30-03-2006, 21:30
in between teams
AKA: Luke Van Oort
I have to admit, I was overjoyed to read the flag rule this year. Last year I was a rookie, so I can't speak about the old rotating lights (although I have tapes of old matches), but those LEDs were darn near impossible to see. The way I see it there are four problems: the blink time is too long, they are too small (for visibility), they aren't bright enough, and they aren't eye catching. The blink time is just a programming thing and could be easily changed (I think). The next two issues can be solved by upgrading the LED. However the last one is hard, and is a fault with the flags too. If a robot goes haywire in auto and comes charging at you, are you going to notice something with little blinkers on it or a flag? Definatly not, it needs power. The rotating lights are better in this respect but they are a bit bulky. So, I'm going to go with the independent unit that can be quickly mounted, not included in the wieght limit, and self powered, as well as a diagnostic LED. It just seems to solve the most of the problems with either system. (Assuming the lights aren't huge)
Team 1219: 2009 - Mentor
  #41   Spotlight this post!
Unread 04-04-2006, 21:42
Rob2713g's Avatar
Rob2713g Rob2713g is offline
FRC #0540 (Screaming Eagles)
Rob2713g has a spectacular aura aboutRob2713g has a spectacular aura aboutRob2713g has a spectacular aura about
LEDs are pretty cheap, so you could probably build your own with a couple resistors for a few bucks. Is there something special about these clusters that makes them a $181?
  #42   Spotlight this post!
Unread 04-04-2006, 22:16
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
LEDs can get very expensive very fast, when you are talking about the superbright ones. About 50 cents each maybe. Say you want a square that is 10 led's on an edge (maybe about 2", so they are fairly tightly packed). Filled, that is 100 LEDs and $50.
  #43   Spotlight this post!
Unread 04-04-2006, 22:43
Umm Errr...
Right now we have 1 superbright. I think that about 9 more and the brightness would be quite workable.
I vote for an improved LED cluster.
Originally Posted by Gdeaver
Xenon strobes have become cheap, small and low power. Much greater visibility than LEDs.
I think strobing robots would be destracting
1139 Alumni
  #44   Spotlight this post!
Unread 05-04-2006, 20:53
BerserkerSpyke's Avatar
BerserkerSpyke BerserkerSpyke is offline
#0871 (Robotechs)
BerserkerSpyke is an unknown quantity at this point
Originally Posted by Al Skierkiewicz
In Wisconsin, a team actually scored a flag into the high goal.
That happened on Long Island in one of the many final matches I do believe.
I think that the LEDs are useful but we need more of them, at least one for each side. At one point during SBPLI, I couldn't see from the stands that the LED was on (Neither could anyone on my Team) so we obviously thought it wasn't. I ran down onto the field shouting "Don't start the match; 871 isn't on!" It caused a little disruption, but as it turned out we were on, the light just wasn't visible. We didn't want to mess up match 33 take 3.
  #45   Spotlight this post!
Unread 05-04-2006, 21:28
Billfred's Avatar
Billfred Billfred is offline
Just as a thought, why not bring back the rotating light, but protect the thing better?
Bring back the light, but then also provide a metal grate to protect it from most whacks. If you need to change the cover for the next match, just unbolt the grate and bolt it back before the match.
Visible, pretty durable, and surely not too expensive if you're getting a couple thousand made at a go. (FIRST has had parts made expressly for itself in the past, after all--tetra clovers, anyone?)
camra light naor52 Programming 3 10-01-2006 20:54
[OCCRA]: Question about a light MatthewArthur OCCRA Q&A 1 26-10-2005 22:21
Light Sensing Robot John Gutmann Technical Discussion 6 24-08-2005 10:47
RC Hardware Light Orange arnagaraja Control System 5 25-02-2005 13:40
Good or bad: back wheels coming off the ground Gui Cavalcanti Technical Discussion 2 17-03-2002 22:09
