Go to Post But don't forget about the little details, that can (and will) come back to haunt you. - Ben Piecuch [more]
Unread 06-04-2006, 00:29
Ben Englert Ben Englert is offline
FRC #1072
Ben Englert has a spectacular aura aboutBen Englert has a spectacular aura aboutBen Englert has a spectacular aura about
Re: Critique this code
Originally Posted by Tom Bottiglieri
Why did you use integer math in control_system.c and floating point in drive_control.c. All assignments are being dropped into int variables, so multiplying by 1.30 is just going to put extra strain on the processor to just get the same answer.
Try
targetticks = (percentage * 26) /20;
That's something I've always wondered... people say that doing floating point math really does stretch the PIC to the edge of its capacity, but I haven't had any problems with it, even when it is handling a lot of interrupts from encoders etc. Is there an easy way to tell how much load it's under?
Before a match at SVR, 3/17/06
Tatsu: "Yo Englert, what's our autonomous mode?"
Me: "We'll find out, won't we."
Both: *maniacal laughter*
After the match's autonomous period ends:
Me: "Well, the basic control system still responds. That's always good."
Both: *further laughter*
Out of the Box Camera Code russell Programming 9 21-10-2009 05:28
Problem with idata_user_routines.o? Adrien Programming 3 12-02-2006 01:33
Team THRUST - Kevin's Code and Camera Code Combine Chris_Elston Programming 3 31-01-2005 22:28
Sourceforge for Code Repository and other stuff SilverStar Programming 9 15-01-2005 21:16
