Go to Post Welcome to the world of pros and cons. - Billfred [more]
Unread 06-04-2006, 12:03
Bongle's Avatar
Bongle Bongle is offline
FRC #2702 (REBotics)
Offense/Defense rankings for 1043 teams
Warning: Use for scouting at your own risk. These numbers are for entertainment purposes only. The way these were computed leaves them open for a team without a shooter (like 1281) to be carried by some high-scoring teams (like 1114 and 1503) to the top of the rankings. In fact, if you look at the finals-only data, you'll see that 1281 ended up ABOVE 1114 and 1503, despite not having a shooter in all the matches played (GTR isn't included). Another example of the flaw in this method is that the top 3 defensive teams are all Israeli, since they were competing against mainly rookie teams.
I grabbed all the matches that FIRST had posted and ran it through an excel macro. So here are the results.
Top 10 Offensive Teams by average points scored:
Team	For	Against
25	83.42	31.23
1114	75.67	26.08
1126	69.84	26.58
987	67.73	32.39
1503	67.26	31.36
1625	67.13	32.87
111	65.49	41.38
175	65.00	27.80
233	64.45	31.35
469	64.38	27.47
Top 10 Defensive Teams by average points scored against them:
Team	For	Against
1955	23.38	13.69
1657	36.88	14.06
1574	33.75	14.44
977	17.50	15.00
547	34.50	15.33
1944	16.83	15.58
1580	22.71	15.64
1578	25.57	15.86
843	21.47	16.07
1742	24.33	16.22
For the rest of the teams, see the attachment.
Unread 06-04-2006, 12:07
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Re: Offense/Defense rankings for 1043 teams
Great job...this is pretty cool.
I think your defensive ranking may reward teams that do not compete in the elimination rounds (they don't play against top scorers), but otherwise it is good info to work with.
Thanks for doing a great job!
Rob
Unread 06-04-2006, 12:24
Bongle's Avatar
Rob
I realized that I should distinguish between elimination rounds just after I posted. So here's a bunch including and excluding elimination rounds. Note that some regionals (such as the GTR) do not actually have their elimination scores posted. This is how 1281 managed to come third AHEAD of the triplets, as they were part of 1114 and 1503's winning alliance at waterloo that scored enormous amounts of points.
Edit: Finals-only corrected. It had a bit of leftover data from previous runs of the script.
Unread 06-04-2006, 12:43
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
I will admit that is pretty cool. My team was ranked much higher on the defensive side then I would have thought.
The question is, can you rerun those number only for teams going to Atlanta. It might be interesting for scouting folks.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Unread 06-04-2006, 13:01
IndySam's Avatar
IndySam IndySam is online now
FRC #0829 (Digital Goats)
I caution you against using these numbers for scouting purposes. Our team ranked 310 in offence and we were a mainly defensive robot. It also shows us ranked 1017 defensively. If you ask anyone who played with us defense was our specialty.
The majority of our high score comes from when we were at the Purdue regional and we were paired with a good shooter and played strong defense (rarely shooting) and provided solid offensive picks for our shooting partners. We could also easily get up on the platform and get the extra points. The majority of the points scored against us was from our unbelievably bad draw at Western Michigan where we were forced to play offence too often because of the weakness of our partners or when we were up against so many good teams in a match and were the only robot playing defense.
Unread 06-04-2006, 13:11
Bongle's Avatar
Indysam has a good point: These only show scores, not actual robot quality. Bad luck for alliance pairings or simply being against an unstoppable force in finals can make your defense average look very bad (or in 1281's case, make our finals offense look really, really good despite running 6/9 finals games with a 35lb strapped on instead of our shooter). Also, there are some regionals excluded, which is why not all 320 Atlanta-bound teams are in these attached files.
Unread 06-04-2006, 13:13
Bongle's Avatar
Ran out of attachments on that last post. I'll use this post to reiterate: Statistics give you a general view of things. Particularely when we're dealing with smaller numbers of matches played, they may not reflect the true quality of your robot. If GTR's results were up, then 1281's offense and defense rankings would be much higher because we performed better there. Perhaps use this as a starting point for scouting or just to see who you want to take a look at, but don't base anything on just one piece of information that some guy posted on the internet.
tl;dr: These are for entertainment purposes only. Nobody takes any responsibility for poor scouting decisions made based on this data.
Edit: The list of teams attending atlanta was lifted from the last page of that thread where they're trying to guess division placements. And apparently they forgot 1281, so now I can't find out where we'd place
Unread 06-04-2006, 13:21
akshar's Avatar
akshar akshar is offline
FIRST=life
AKA: Fro
FRC #1568 (Mechanicatz)
akshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to allakshar is a name known to all
Send a message via AIM to akshar
so pretty much, these rankings SHOULD NOT BE USED FOR SCOUTING since they include to many variables.? the biggest one is that the scores reflect an alliance as a whole and not the team itself alone
Think Bot, Dream Bot, Be Bot
Dream Big Reach High
2005: UTC Judges Award (We'll be Back Award)
2006: Boston Regional Winners with 121 and 233
2007: Boston Regional Finalists with 1626 and 121
Unread 06-04-2006, 13:25
Cory's Avatar
Cory Cory is offline
AKA: Cory McBride
Basically. Teams that can't score at all are rewarded by being on an alliance as a defensive force, due to the offensive capability of the other two robots.
Similarly, teams who didn't play at events with other strong shooters look worse, due to not having partners who can score.
A real measure would be average points scored per team. Unfortunately that's nearly impossible to do.
2001-2004: Team 100
2006-Present: Team 254
Bongle's Avatar
I never claimed they should be used for scouting, though it is good to repeat that they shouldn't since people might put a bit too much trust in numbers posted by someone anonymously on the internet. So here it is again: USE FOR SCOUTING AT YOUR OWN RISK. Also, I have now put a warning on top of the thread.
As for numbers reflecting alliances as a whole, if that was truly an enormous flaw, then FIRST should probably re-work how regionals are run. This is nothing more than an aggregation of all the average scores, as if the entire planet was at a single regional together and were being ranked by that.
Unread 06-04-2006, 13:38
As for numbers reflecting alliances as a whole, if that was truly an enormous flaw, then FIRST should probably re-work how regionals are run. This is nothing more than an aggregation of all the average scores, as if the entire planet was at a single regional together.
Statistics can be manipulated, massaged, and otherwise molded to say what ever you want them to say...
I'm didn't mean to say they SHOULD be used for scouting. But if you see a team high up in the list that is in your division, they might be worth watching to see if was luck or skill that got them there. If you could make decisions based on numbers alone, we wouldn't need scouting... just a set of match results...
Remember: "There are three kinds of lies - lies, damned lies and statistics." ~Benjamin Disraeli
Unread 06-04-2006, 13:59
Stinks for the teams who went to regionals where the scoring system was messed up..
Unread 06-04-2006, 14:19
nuggetsyl's Avatar
nuggetsyl nuggetsyl is offline
FRC #0025
nuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond reputenuggetsyl has a reputation beyond repute
Team	For	Against
25	83.42	31.23
1114	75.67	26.08
1126	69.84	26.58
987	67.73	32.39
1503	67.26	31.36
1625	67.13	32.87
111	65.49	41.38
175	65.00	27.80
233	64.45	31.35
469	64.38	27.47
Team	For	Against
1955	23.38	13.69
1657	36.88	14.06
1574	33.75	14.44
977	17.50	15.00
547	34.50	15.33
1944	16.83	15.58
1580	22.71	15.64
1578	25.57	15.86
843	21.47	16.07
1742	24.33	16.22
what we are the top scoring robot???? HELL must be frozen over right now. not bad for a defensive team.
shaun
00,12Championship winner
03,06,08 Championship finalist
02A,03C,06N,08C,11N,12G Division winner
00,03,06,07,08,10,12 NJ / MAR winner
11 VCU winner
06,10 Las Vegas winner
12 MAR Mt Olive
red is for team 348
Unread 06-04-2006, 14:22
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Looks like the Atlanta bound list is missing some teams...121 is going to Atlanta but is not on any of those lists.
It seems to me that one way to use stats like these to measure how teams really perform would be to look at margin of victory in the elimination rounds, where there are good teams on both sides and you are trying to maximize your own score/minimize your opponents. (unlike in qualifying where opponents score ties in to your ranking, giving incentive to not play shutdown defense)
You would have to look at whole alliance performance rather than individual teams, and then rely on your own scouting knowlege to know which teams in an alliance are offensive and which are defensive.
If you are bored, maybe you could run this again, but rank each alliance that competed in elims by their margin of victory (or loss).
I think that would be a useful scouting tool when combined with reports on how each team in an alliance plays the game.
Rob
Unread 06-04-2006, 14:28
Have to add a little caveat here...Teams that actively try to increase ranking points actually fudge the numbers. If you are trying to give points to your opponents then you can't at the same time, score for yourselves. Look at the "for" and "against" numbers carefully...
New Aliance Selection? mallot1243 General Forum 24 21-03-2006 10:05
YMTC: Can teams start cutting metal for 2005? Natchez You Make The Call 67 07-02-2006 21:55
The top 8 teams will be....(2004) Jessica Boucher General Forum 20 24-03-2004 22:31
Robot Collaboration Karthik General Forum 153 18-02-2004 03:40
Long post - this year's game was tough - here's why: archiver 2001 7 24-06-2002 03:31
