Go to Post I love the smell of burning silicon in the morning. - Al Skierkiewicz [more]
Unread 06-04-2006, 15:52
gnormhurst's Avatar
gnormhurst gnormhurst is offline
Norm Hurst
AKA: gnorm
#0381 (The Tornadoes)
gnormhurst will become famous soon enoughgnormhurst will become famous soon enough
Re: SONAR Sensor Software Driver
Just a further update on the sonar system. We were successful in using the sonar to control our distance to the corner goal (our doors won't open if we're too close, and the balls won't go in if we're too far away). We used sonar both in autonomous and as a driver control (driver initiates "autonomous" using a button. Control is returned when the balls have been dumped or the driver hits the "abort" button.) We even got a Xerox Creativity Award for the system.
But here's why I'm writing this note...
We had a strange problem. The sonar system would give steady values until we enabled autonomous, and then the values would start to drop: 150, 150, 150, [start auto] 150, 150, 130, 115, 90, 75, ... All this while the robot was on blocks and unable to move!
I figured it was some bizzare resource interrupt limitation timing thing. Until I discovered that it would do this just by me running the motors. It took a mechanical engineer to put his hand on the frame and say, "I bet it's picking up vibration from the motors!" We removed the sonar unit and held it -- the problem went away. We ended up mounting the unit on a block of foam (a block we made by cutting up one of those balls from the game).
Oddly, the autonomous code seemed to work anyway. It only did this for long distances -- at short distances ( < 30" ) we didn't see this problem.
So, everyone --- be careful how you mount the sonar unit -- it can pick up vibrations and give bad readings!
Thanks again for the driver code -- we never would have been able to complete this in time without it!
-Norm
Trenton Tornadoes 381
2004 Philadelphia Regional Winners
2006 Xerox Creativity Award
My corner of the USPTO.
My favorite error message from gcc: main is usually a function
My favorite error message from Windows: There is not enough disk space available to delete this file.
Toshiba Cardbus Problem? jpsaul7usa Chit-Chat 12 01-01-2006 02:37
Introducing the Driver Strategy Database's Online Database impulse3D Rules/Strategy 17 17-03-2005 03:04
Updated: Serial Port Driver Code Kevin Watson Programming 4 05-02-2005 18:39
New Serial Port Driver Kevin Watson Programming 16 09-01-2005 01:56
Middle School Drivers ram General Forum 40 26-02-2003 17:01
