Go to Post I would ask for Florida to take a vote on best team, but my fear of "Hanging Chad" in close decisions has not fully subsided. - IKE [more]
Unread 08-04-2006, 01:18
AKA: Dr. Brooks
no team (WRRF)
Possible bug in memory initialization?
In ifi_startup.c, the routine _do_cinit() has some static variables defined with:
_do_cinit (void)
/* we'll make the assumption in the following code that these statics
* will be allocated into the same bank.
static short long prom;
static unsigned short curr_byte;
static unsigned short curr_entry;
static short long data_ptr;
This is followed by a bunch of asm statements that are used to initialize static/extern memory locations. Since we have had lots of problems with static memory not behaving like it was initialized properly, I am wondering if the stated assumption in the comment, that the four static variables are allocated in the same bank, might not be valid, depending on just how much static memory is allocated in other files.
Can anyone shed some light on this issue?
Unread 08-04-2006, 02:38
Electrical Engineer
Rookie Year: 1995
Re: Possible bug in memory initialization?
Doc,
Are you saying that explicit or implicit initializations are corrupted?
I have seen no issues with explicit initializations and have strongly advised everyone who cares to listen to avoid them.
JMHO.
Mike
Mike Betts
As easy as 355/113...
Unread 08-04-2006, 03:40
AKA: Dr. Brooks
no team (WRRF)
Originally Posted by Mike Betts
Doc,
JMHO.
Mike
Mike, I don't think that there is any need to re-visit the thread you point to here, I don't disagree with the view you posted there. My question is whether or not the assumption that the variables in the routine in question are allocated in the same section can ever be violated...
Unread 08-04-2006, 09:22
Mike Bortfeldt Mike Bortfeldt is offline
FRC #1126 (& 1511)
Mike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud ofMike Bortfeldt has much to be proud of
I have never seen a problem with variable initialization that wasn't my own fault (mainly not recognizing how the compiler will sometimes cast constants). But as for your question, I would say that the assumption is true. Since the compiler places all static uninitilized variables within a file in the same UDATA section (assuming you don't use a #pragma statement to change that) the compiler/linker would generate a section error if it overflows a single DATABANK since a single UDATA section must fit within a single DATABANK. That being said, if you've modified the linker file so that a single DATABANK spans multiple memory banks, then I suppose it would be possible for the same bank assumption to be false.
You should also be able to check the .map file to verify that all the variables have been placed in the same bank.
Mike
Older computer memory trouble sanddrag IT / Communications 9 02-12-2005 21:43
Nasty Compiler Bug Matt Leese Programming 5 18-02-2005 18:44
initialization program and speed controllers rosebud Programming 15 05-10-2004 03:35
printf bug - beware! WizardOfAz Programming 8 10-03-2004 09:50
Whacky C Complier behavior Larry Barello Programming 12 26-01-2004 22:15
