Go to Post ...FIRST was created to change that world for the better. To presume that FIRST is simply here for your enjoyment is to demote it to nothing more than an expensive game... - RogerR [more]
Unread 08-04-2006, 21:23
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Camera Pinouts?
Hey all!
I just finally updated my code in order to use the camera (procrastination is bad). After reading through the code, it shows that Default_Routine(); is commented out.
Above it shows that the PWM1,2 are used for the camera PAN/TILT. I don't remember if the camera has the servos plugged into that board, or if it were plugged into the robot controller.
If it was plugged into the camera board, how would I make the camera work if I changed (tracking.h's)
// By default, PWM output one is used for the pan servo.
// Change it to another value if you'd like to use PWM
// output one for another purpose.
#define PAN_SERVO pwm01
// By default, PWM output two is used for the tilt servo.
// output two for another purpose.
#define TILT_SERVO pwm02
to become
#define PAN_SERVO pwm09
#define TILT_SERVO pwm10
Isn't the Camera board controlling the servos? If the PWM09 and 10 are used, doesn't the cam board only use 1 and 2?
Kind of seems weird to me.. I haven't got my hands on the cam yet..
Thanks!!
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
CMU Camera kills robot controller if not found. Chris_Elston Programming 21 27-03-2006 14:30
Camera shows no love to drive motors anifinder Programming 4 13-02-2006 10:31
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Camera Is Spazzing Out! BrittanyV Programming 15 04-02-2006 13:39
Scripting Setup and the Camera + Serial Port Drivers CJO Programming 22 11-01-2006 17:42
