Go to Post A FIRST door is always open. - Chris Fultz [more]
Unread 09-04-2006, 14:04
Billfred's Avatar
Billfred Billfred is online now
pic: What else has Billfred been doing?
Adam Richards's Avatar
Adam Richards Adam Richards is offline
I'm baaaaaaack.
FRC #1902 (Exploding Bacon)
Adam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond reputeAdam Richards has a reputation beyond repute
Send a message via AIM to Adam Richards
Re: pic: What else has Billfred been doing?
Kiwi drive?
Unread 09-04-2006, 14:05
REVving up for a new season
FRC #2848 (All-sparks)
i hope you are going to have some ball casters or skids under the corners of the triangle or it might be unsteady.
Greg Needel│www.robogreg.com
Co-founder REV Robotics LLC www.REVrobotics.com
2014 FRC World Champions with 254, 469, & 74
Unread 09-04-2006, 14:33
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
I personaly would move the wheels to the corners instead
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 09-04-2006, 14:36
Billfred's Avatar
Man, I thought they didn't post these things until after I finished the description! (insert anime-style sweat drop here)
Yes, it is indeed a kiwi drive. I've been working on it as part of a research grant from Preston Residential College here at USC for the better part of the semester. (Preston offered grants up to $500 to research a topic with a faculty member. It was a good excuse to learn to CAD, among other things.)
The idea is to create a kiwi drive that a team with limited resources and fabrication abilities can create. The only thing that you'd have to add on top of the list of tools needed to fabricate the Kitbot is a power drill. A center punch and/or scribe wouldn't hurt either, but you can live without them. (You can get fancier with this design--if you could find an appropriate sprocket, you could substitute an AndyMark Gearbox for the third IFI transmission and possibly shave a few bucks off of the cost. But since I couldn't find the right sprocket for the job without having one custom-machined, I kept with three IFIs.)
Most of my time has been spent just learning the finer points of Pro/ENGINEER (what USC uses) and designing those corner brackets. (You can cut two from a Kitbot's top plate. You can't really use it for its intended purpose in this setup anyway, so you might as well get something from it, right?)
We're hoping to get this thing together for Discovery Day (USC's annual undergraduate research shin-dig) in a couple of weeks. It should be fun.
Something will be going under there. I'm thinking PVC, since I already had to buy some to make spacers with.
It could be done like that, but one of the first things I learned from my mentor (Dr. Philip Voglewede, if anyone was at the Palmetto team social) was that the wheels's axes needed to converge in the middle for things to work out smoothly. To get them in the corners would take, at least in my judgement, a lot more trouble than it's worth. (But if someone has an idea, I'm all ears.)
Unread 09-04-2006, 14:53
Stuart's Avatar
#include coffee.h
it is an equilateral triangle isn't it? . . . cause if it is just moving the wheels to the coroners would keep the axises centered. . . then for the kit drives just move them above the wheels instead of to the side of them. . . . this is all of course assuming that it is an equilateral triangle
Unread 09-04-2006, 15:01
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
Billfred, I think that people are suggesting that the wheels be mounted to the triangular brackets, with their axes perpendicular to the long edge of the brackets. That allows the robot to be fully supported on its wheels, rather than causing some of the weight to rest on undriven wheels/casters/skids (which would reduce the amount of force that the robot could exert in a pushing match).
Also, why not consider a quadrilateral version of the Kiwi drive? Like what 854, 931 and others used this year? It seems even simpler to build, and a little more powerful (provided that the extra CIM wasn't needed elsewhere).
A note on the kitbot sprocket. I just realized that we ought to be looking for ISO 04 and ISO 06 sprockets, not #25 and #35. They're functionally equivalent to ANSI roller chain sprockets, if I'm not mistaken, but they do come in 16 mm bore sizes. In fact, SDP/SI has some, in larger tooth sizes for ISO 04/#25. And Martin sells a few ISO 06/#35 ones with 16 mm bores. Search GlobalSpec for "Sprockets, Roller Chain, Metric", for more sources.
Unread 09-04-2006, 15:02
supermosquito69's Avatar
supermosquito69 supermosquito69 is offline
AKA: Daniel Mendez
FRC #1251 (Tech Tigers)
supermosquito69 is on a distinguished road
Send a message via AIM to supermosquito69
Smile Re: pic: What else has Billfred been doing?
Nice job on the 3-D Modeling man!!
Actually, the "steady" factor depends on the center of gravity of robot. So, if the robot is as tall as it can be but the center of gravity is very low then the robot will have no problem. Otherwise the skids are the way to go since the casters need a direction on their axis while the skids don't need any directionality, they just stand there.
Team 1251 The Techtigers
2006 Palmetto Regional Winners w/ 247 and 11....Oh YEAH!!
2006 Palmetto Regional DaimlerChrysler Team Spirit Award
2005 Mayhem @ The Museum Champions w/ 1523 and 1390
2005 Palmetto Regional 1st seeded and finalist w/ 25 and 301
2005 Palmetto Regional Xerox Creativity Award
2005 UCF Regional 3rd seeded and finalist w/ 845 and 1270
2005 UCF Regional Judges Award
2004 UCF Regional Rookie All-star Award
Unread 09-04-2006, 15:05
Tim Delles's Avatar
Tim Delles Tim Delles is offline
Since 2001.
FRC #0078
Tim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond reputeTim Delles has a reputation beyond repute
Billfred, here is a video of our kiwi drive. (Looking for the pictures still. Will post when i find. and the other picture i posted was actually teams 857's design) Hope it gives you some ideas.
Edit:// Also don't run it on any hard floor, only use carpet. If you run it on a hard floor it makes the most horrible sound in the world. Well close to it
Timothy Delles - Clarkson University
2011 - Present: FRC Team 78 - AIR Strike
2011 - Present: VEX Team 78 - AIR Strike
2010 - 2011: FRC Team 3280 - Rhode Rebels
2001 - 2009: FRC Team 229 - Division By Zero
Unread 09-04-2006, 15:34
Rohan_DHS Rohan_DHS is offline
AKA: Kayla's big bro...
FRC #1620 (Robolution)
Rohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of lightRohan_DHS is a glorious beacon of light
Send a message via MSN to Rohan_DHS
<noob>
how exactly does this type of drive system work, and what are the advantages of using such a drive system over a normal type of drive system?
</noob>
Rohan K
2008: Alumni, Helper
2007: Webmaster, Alumni
2006: Team Captain, Driver, Electrical/Electronics Head
2005: Safety Captain
Unread 09-04-2006, 15:39
pakrat pakrat is offline
Rich Ross
no team (The Rat Pack)
pakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nicepakrat is just really nice
Send a message via AIM to pakrat
one awesome thing about these kinds of drives is that they can have increased maneuverability without having to build a complex swerve drive system (having motors to rotate the wheels. You can spin very easily and many teams use a 4 wheel configuration of this idea. I know we did, and about 5 or 6 or the Waterloo teams did too.
I think This is 229's version with wheels at the corners. Billfreds is simpler i think, but it may need casters or whatnot. I think this is a solid design by the way.
Unread 09-04-2006, 15:42
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
If those were 6" wheels (they look like 8" right now, are they?) you could get away with putting them right on the gearbox output shafts. Although you'd need a custom hub, which is not desired in this project I guess.
Unread 09-04-2006, 15:54
Billfred's Avatar
The angle of the drawing (and my comments) might be unintentionally tricking folks--it does rest solely on the omniwheels. Any skids I might add to the corners would be just for some extra insurance--a wheelie bar of sorts. (Though don't most kiwis attempt to avoid pushing matches anyway?)
Why not quadrilateral? Good question. Besides a desire to do something a little different (I only know of 857's in 2002 and 229's prototype kiwis in FIRST, but there have been many more quadrilateral ones), a three-wheeled version has an additional thing going for it: cost. You don't have to buy or make the fourth omniwheel/transmission/etc. (Besides, that also frees up a CIM motor for other things, which I'll leave to the reader's imagination.)
Simplicity shouldn't be too much of an issue--those corner brackets are the sole part you have to custom-fabricate, and that's just a matter of lining up your hacksaw correctly. Everything else is just assembling the Kitbot with the low-rider configuration (although you could go the traditional way if you desired--I just went low-rider for the center of gravity benefits.)
Interesting. I'll have to check it out.
Something to keep in mind--luckily, the halls of both 300 Main (the mechanical engineering building) and Preston are carpeted. Fwahaahaa.
It is an equilateral triangle--the corner brackets only took me about 47 tries to get right. The wheels are mounted where they are for simplicity and durability (how many decently-constructed kitbots have you seen smashed to pieces?). This setup is basically just the lowrider configuration with some interesting corners. I haven't fully investigated mounting them on the corners, but I can't picture it being done in a cheap-and-easy fashion.
Those are 6" AM omniwheels. I didn't plan on traversing anything other than flat carpet, so I didn't see a benefit to spending $12 more for 8" wheels all around. You're right, though--the hub was undesired.
I appreciate the feedback--it's good to hear it from a lot of folks.
Unread 09-04-2006, 17:22
JVN JVN is offline
@JohnVNeun
AKA: John Vielkind-Neun
FRC #0148 (Robowranglers)
The 229 version that was linked in this thread was designed primarily by Chris Carnevale.
Chris' design consisted of designing a simple "Omni-Module" which was a solid unit consisting of one AM omni-wheel, 1 gearbox (he used the Bosch Drill+Gearbox, but a kitbot gearbox could easily be substituted), and all the mounting/framing that comes with it.
Chris then built 3 of these simple omni-modules, and bolted them onto a big triagular piece of plywood. Simple, and easy; this design can definitely be built by low-resource teams.
-JV
Want to learn PIC Programming? Good deal here! Rombus Chit-Chat 2 10-04-2006 11:43
pic: Billfred (1293) Billfred Extra Discussion 1 24-03-2006 20:37
pic: 1018 - Pic 5 - TWINS ? ... (or mirrors ?) Stu Bloom Robot Showcase 7 18-02-2006 15:17
pic: 1018 - Pic 4 - Welded Chassis Stu Bloom Robot Showcase 17 03-02-2006 21:36
pic: River Rage 9 pic JohnBoucher Extra Discussion 2 30-10-2005 14:43
