Go to Post Well, air conditioners when pointed inside the house make it cooler. So I figure if EVERYONE turns their air conditioners on full blast and just point them out the window, we should more or less get rid of this "warming" nonsense. - Mike [more]
Unread 09-04-2006, 00:30
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Camera without servos
Hey all,
If I were to mount the camera without servos and just use the drive base to allign the camera to center.... what should i do?
I've been looking through the code and I saw that it was checking if the target pixels are within center of the camera view..
I just don't know what i should do to make the bot track without the servos.. please help
Thanks
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 09-04-2006, 08:04
JJG13's Avatar
JJG13 JJG13 is offline
Yoda
AKA: Joshua Graffman
None #0180 (SPAM)
JJG13 has a spectacular aura aboutJJG13 has a spectacular aura aboutJJG13 has a spectacular aura about
Re: Camera without servos
First you need to find how far the camera is off from target using the same method you would when using the camera servos.
Relevent code:
pan_error = (int)T_Packet_Data.mx - PAN_TARGET_PIXEL_DEFAULT;
if the pan_error is less than zero you have to drive the robot\turret one way and if it is greater than zero, you have to drive the robot\turret the other way.
Behold the power of SPAM.
Unread 09-04-2006, 13:27
lemoneasy lemoneasy is offline
AKA: Evan Crawford
FRC #1334
lemoneasy is on a distinguished road
Do you also mean without a tilt servo? I think its simpler with servos, have the camera parallel to the side of your bot, and just turn until the pan angle on your camera is 0, or within 1 to -1 degrees. Otherwise, the pan error method would work. As for tilt you would have to decide how close you want your bot, if you have your camera tilted at 19-20 degrees, your bot will be centered at around 25 feet from the net. Just put the bot however close you want it to the net, point the camera's tilt at the light, fasten it tight. Then just use the pan error method with the tilt_error instead.
Unread 09-04-2006, 16:07
kiettyyyy's Avatar
I actually mean without BOTH servos... our mentors dont want them because something could potentially happen :-/ who knows. Any way, im thinking now to run a little loop thats similar to a pid that just compares the error in certain directions, if its towards the right, move the left motor, if its toward the left, move the right motor... hopefully that would work..
Please put some suggestions
Thanks!
-Kiet Chau
www.team1538.com
Unread 09-04-2006, 16:41
kiettyyyy's Avatar
Okay, I have something mocked up now.. How does this look??
if (swt_camera)
// If the image is not center, check with the allowable error range
if (pan_error > PAN_ALLOWABLE_ERROR_DEFAULT)
// Attempt to turn left
pwm_rightDrive_cim = pwm_rightDrive_cim = 200;
pwm_leftDrive_cim = pwm_leftDrive_fp = 120;
else if(pan_error < -1 * PAN_ALLOWABLE_ERROR_DEFAULT)
// Attempt to turn right
pwm_rightDrive_cim = pwm_rightDrive_cim = 120;
pwm_leftDrive_cim = pwm_leftDrive_fp = 200;
else
// Set drive motors to neutral
pwm_rightDrive_cim = pwm_rightDrive_cim = 127;
pwm_leftDrive_cim = pwm_leftDrive_fp = 127;
// Tell the controller that it is now on target
Tracking_State += STATE_PAN_ON_TARGET;
Should this work?
-Kiet Chau
www.team1538.com
Unread 09-04-2006, 16:55
kiettyyyy's Avatar
Oops.. I just realized that we need to set what color to track with Track_color(????????).. What has your team been using for these values? And where should track_color go? Should it be where the switch is turned on? Or is this already pre set? *IM USING THE STREAMLINED VERSION *
-Kiet Chau
www.team1538.com
Unread 09-04-2006, 17:16
DanDon's Avatar
DanDon DanDon is offline
ohhh MY god
AKA: Dan Hoizner
FRC #0375 (The Robotic Plague)
DanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond reputeDanDon has a reputation beyond repute
Send a message via ICQ to DanDon Send a message via AIM to DanDon Send a message via MSN to DanDon
All the tracking is done in tracking.c.
It should track out of the box.
And it would send the values to the pwm outs, you would just not have anything connected to those outs.
Unread 09-04-2006, 18:01
kiettyyyy's Avatar
I just commented out the parts where it sent data to the pwm outs so that my code that I wrote earlier today -^ should have the camera control the bot instead of servos.. It sounds risky to me
-Kiet Chau
www.team1538.com
Unread 09-04-2006, 18:04
Matt Krass's Avatar
AKA: Dark Ages
FRC #0263 (Sachem Aftershock)
if (swt_camera)
else
Should this work?
It's going to be a bumpy ride. Chances are your robot isn't going to stop dead right on target, it will glide, spin back quickly, glide...overshooting back and forth. A basic P loop would help, but that would always introduce a steady state error.
P = error * gain;
Error is the pan_error, gain is the factor at which the motor responds, the higher, the more the motor responds. The problem is as you get close, the error decreases, meaning motor output decreases. Eventually the power level will get low enough that you stop moving. This is called "Steady state error" you can only get so close before the power output is insufficient to move. You can turn up the gain, but that will very likely make it oscillate again. You should look in to PID control, or even PI, if you search around here and on google I'll bet you can find some nice references. Also, if by experimenting you determine you need a minimum PWM value of Z to keep moving, you can do a check that if the error is past the deadband and the PWM is below Z, set it to Z, that's a crude PI, with a fixed I output. That should work but it won't be as precise as PI. Does this reply make any sense?
Matt Krass
Unread 09-04-2006, 18:14
kiettyyyy's Avatar
I kind of understand it, but how would i impelement it into the code?
-Kiet Chau
www.team1538.com
Unread 09-04-2006, 18:48
Bharat Nain's Avatar
Look at Kevin Watson's navigation code from 2005. http://www.kevin.org/frc/2005/
Although that is probably too complex for your use, it should give you a good idea of how PID loops work and how you can make yours. Good luck and feel free to ask more questions.
-= Bharat Nain =-
Whatever you do, you need courage. Whatever course you decide upon, there is always someone to tell you that you are wrong. There are always difficulties arising that tempt you to believe your critics are right. To map out a course of action and follow it to an end requires some of the same courage that a soldier needs. Peace has its victories, but it takes brave men and women to win them. - Ralph Waldo Emerson
Unread 09-04-2006, 19:31
kiettyyyy's Avatar
:-/ I don't really understand the pid code.. It seems a tad bit complex I think i might have to hope the bot doesnt over shoot, or i can just move the values by a little bit or make a different if and then loop that compares the values of the pan error and the allowable error that just changes the values of the motors instead of being high speed or low speed..
-Kiet Chau
www.team1538.com
Unread 09-04-2006, 20:08
DanDon's Avatar
ohhh MY god
AKA: Dan Hoizner
During user mode, you can just pulse the button that alligns the robot, and have a feedback that shows whether the bot is within the allowable deadband....and thus lessening the overshoot.
Unread 09-04-2006, 20:26
kiettyyyy's Avatar
So you mean something like this?
if (swt_camera)
	if (pan_error < 5 | pan_error > -5)
	else
		else
Sorry I can't really format it inside this little form :-/
Thanks for the help!
-Kiet Chau
www.team1538.com
Unread 09-04-2006, 20:59
You can use the [code ] vbcode tag to keep your formatting.
Camera shows no love to drive motors anifinder Programming 4 13-02-2006 10:31
How To Use the Google Camera generalbrando Kit & Additional Hardware 2 07-02-2006 16:00
Servos controlling camera and purple screen ryan_f Programming 6 17-01-2006 23:21
servos and the camera incognito_NICK Programming 5 09-02-2005 00:00
Servos for the camera MV_Hirsch Programming 4 24-01-2005 16:35
