Go to Post Dean: We encourage kids to learn about science, technology.... Colbert: And does that include creation science? Dean: .... Well we teach kids to be very creative..... - Kevin Sevcik [more]
Unread 28-03-2006, 20:12
Dan Petrovic's Avatar
Dan Petrovic Dan Petrovic is offline
Got my degree and ready for more!
FRC #0166 (Chop Shop)
Dan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond reputeDan Petrovic has a reputation beyond repute
Re: The advantage of holonomic drivetrains
Originally Posted by Starke340
i have also seen this at many regionals. a robot with holonomic drive would have to be so fast that a 4wd or 6wd bot could not stop you. think of Hot team 67 last year (see below). it was similar drive, i witnessed the robot do a pick and roll maneuver that you see in basketball with. you need to have holonomic drive perfectly right to have it work effectively.
Last year the omni-directional drives worked considering the tight space you have to manoeuvre around. There wasn't nearly as much pushing and shoving and there weren't any 3D elements that you had to climb.
Unread 28-03-2006, 22:05
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Oh... Witness the BEAST! This was one amazing robot with a crab system. It took quite abit to push them considering they had a holomonic drive. Sure they were pushable but the advantages of their system was greater than the disadvantages.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 28-03-2006, 22:21
Ianworld's Avatar
Ianworld Ianworld is offline
AKA Ian Ferguson
AKA: Ian Ferguson
FRC #0694 (StuyPulse)
Ianworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud ofIanworld has much to be proud of
Send a message via AIM to Ianworld
Many people here are getting confused between holonomic and swerve drives. A holonomic drive has 4 omni wheels at the corner of the robot rotated 90 degrees from each other. This allows the robot to effectively move in any direction and spin in place by powering each of the wheels independently a different amount. The reason why people have said that they are weak and easy to push around is because you can never have more than 50% of your power in any one direction. Along similar lines if the wheels are not being driven the robot can be slid across the ground very easily.
A mechanum drive is very similar to a holonomic drive in that it effectively works the same way. It uses complicated mechanum wheels which allow a robot to place its omni-wheels in a front to back configuration like a regular wheeled robot. It however doesn't pose any advantages other than the easier mounting I believe.
A swerve drive is a very different animal which is what the picture of the HOT bot from last year and the BEAST from this year use. They usually have 4 wheels which are rotatable. Usually driven by a motor the wheels are able to rotate in place allowing the robot to drive in any direction. The advantage of this is that you don't sacrifice much traction while gaining a lot of maneuverability. The downside comes in the form of extra motors, extra hardware and a lot of complexity.
As far as I've seen the competition has been dominated 6 wheel drive set ups and treads. Treads and swerve drives are definitely coming out as the top contenders. Treads for their dominance in terms of strength and immovability and swerve drives for being both maneuverable and strong. However teams with just 6" traction wheels from IFI are going to be doing just great this year.
As for the holonomic drives I've seen, they have all broken down under the stress of the competition. They're tough to make really sturdy and powerful and just don't seem up to snuff this year. Its too bad since they're really starting to become common and a bad year like this will slow their adoption I think.
Team Website
Unread 29-03-2006, 01:42
Eldarion's Avatar
Eldarion Eldarion is offline
Electrical Engineer / Computer Geek
AKA: Eldarion Telcontar
no team (Teamless Orphan)
Eldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond reputeEldarion has a reputation beyond repute
Send a message via AIM to Eldarion Send a message via Yahoo to Eldarion
Yeah, I don't think our team will be doing one next year unless the game really demands it. Oh well, lesson learned.
CMUCam not working? Tracks sporadically? Try this instead: http://www.falconir.com!
PM me for more information if you are interested (it's open source!).
Want the FIRST Email blasts? See here: http://www.chiefdelphi.com/forums/sh...ad.php?t=50809
"The harder the conflict, the more glorious the triumph. What we obtain too cheaply, we esteem too lightly; it is dearness only that gives everything its value."
-- Thomas Paine
If it's falling apart it's a mechanical problem. If it's spewing smoke it's a electrical problem.
If it's rampaging around destroying things it's a programming problem.
"All technology is run on 'Magic Smoke' contained within the device. As everyone knows, whenever the magic smoke is released, the device ceases to function."
-- Anonymous
I currently speak: English, some German, Verilog, x86 and 8051 Assembler, C, C++, VB, VB.NET, ASP, PHP, HTML, UNIX and SQL
Unread 29-03-2006, 01:47
KVermilion's Avatar
KVermilion KVermilion is offline
... clearly ...
#0649
KVermilion is infamous around these parts
649 decided on out holonomic drive train, because we had used it last year, and we thought we could step it up, and we did. Keeping the holonomic drive (we call it omnidrive) allowed our mechanical design team to concentrate on our shooter and ball train. If we had not reused our drivetrain scheme from last year, our shooter and ball delivery system would have been likely to suffer. Keeping the holonomic also allowed our programmer and our electronics guy (me) to do some neat stuff, that just wouldn't have happened on a normal drive train.
Simply put, the drive train did not serve us well in quals where one or both of our alliance partners were disabled, or worse, disabled each other. When we had a proper communication and competant alliance partners, it worked well, because we were able to harvest, and line up our shots in a much quicker manner then with a conventional drive train. Of course none of this panned in the QF because were were essentially out there alone, stuck as back bot
Unread 29-03-2006, 01:50
KVermilion's Avatar
... clearly ...
#0649
649 maintained a working holonomic robot though both SVR and Sac-town. Our holonomic drive gave us minimal issues.
Unread 02-04-2006, 22:55
Daniel Morse Daniel Morse is offline
former 213 member
FRC #0213 (The Dirty Birds)
Daniel Morse is a jewel in the roughDaniel Morse is a jewel in the roughDaniel Morse is a jewel in the roughDaniel Morse is a jewel in the rough
213 decided to pursue a holonomic drive with 4 sets of dual Kornylak omni wheels mounted to the KOP gearbox mounted under our machine. We were at BAE and Boston this year, and we were a corner goal dumper. The disadvantage going into the competition we saw immediately, that being we could be pushed. When we finally got out onto the field, and had our driver perfect his method, we were actually able to become nearly as strong as the other robots. At full power we were capable of stopping (or severely impeding) our competitors. Only when we were not moving could we be pushed around. Because of our incredible maneuverability and ability to stop opponents from scoring we were often utilized as ramp defenders at the end of the match, and against high scoring teams sometimes we played nearly exclusive defense. We got to be pretty good at it (especially in Boston). The only problem came in the form of wheel durability, our wheels could easily shatter and did after matches. I suppose this was not necessarily the year for holonomic drives, but I think my team did pretty well (finals in Boston). To see videos of our matches in Boston, go to this site, and download any videos with 213 in them. You will find that a couple of them showcase the omni drive quite nicely. We are also in the eliminations (qf4m1,2 sf2m1,2,3 finals).
Rensselaer Polytechnic Institute class of 2010 - Mechancial Engineering
Student and Mentor, Keene High School Team 213 "The Dirty Birds" 2003-2006
College Mentor, Team 1493, RPI and Albany High School "The Falcons" 2008
Unread 02-04-2006, 23:02
I really want the game to demand it cause that's something I want to do. We'd have to sacrifice our awesome 2-speeds, but still.
I'd much rather have a swerve drive but it's much more complex. We have drawings and the concept for it all done because we planned on doing it for this year. After seeing the game we kind of decided against it.
Unread 03-04-2006, 01:18
irishninja's Avatar
irishninja irishninja is offline
I count as two people!
AKA: Nathan Bixler
FRC #0694 (Stuypulse)
Team Role: Marketing
irishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of lightirishninja is a glorious beacon of light
Send a message via AIM to irishninja
Adding to what Ian said this happened with my team this year. We originally were using a tread drive sytem but our tread snapped. By the time we were on our 5th drivetrain and it was Thursday at the NYC regional we swapped for omni wheels in the front, knowing full well we wouldn't be able to get up the ramp.
Consequences of the omni wheels
We were able to turn which let us realign ourselves for shooting very quickly
We were able to be pushed very quickly while shooting
Instead of turning in very small degrees we made huge arcs, although our drivers got that under control
Our omni wheels actually broke
We were able to wreak havoc during the last 20 seconds of the game on the other side stopping from robots getting up the ramp knowing that we couldn't
We usually played backbot
In my opinion the good outweighed the bad, (we came in second), so it was a good tradeoff. If we had been primarily defensive and not played backbot, I'm not so sure the omni wheels would have been a good idea.
VEX Robotics Blog
Unread 06-04-2006, 22:51
newton418's Avatar
newton418 newton418 is offline
AKA: Ryan Newton
FRC #0418 (Purple Haze)
Team Role: Driver
newton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to allnewton418 is a name known to all
Team 231 chose us as alliance partners in the finals. I'm not sure, but I believe they had omni wheels that were all at 45 degree angles.
Yes, they did get pushed around; however, their driver did manage to "roll" around defending robots and pop a couple in the goal. Another advantage they had was, their infeed rollers were mounted on the long side of their robot, and their shooter was too. This provided room for the shooter and a large margin of error for the driver when they needed to pick up balls.
Here's the second match in the Lone Star Regional finals, if you really watch it you can see that nifty roll move used a couple of times.
http://video.google.com/videoplay?do...gional&pl=true
Team 418 Purple Haze
http://www.lasarobotics.org/
Unread 07-04-2006, 12:56
ClayScales ClayScales is offline
#0231 (High Voltage)
ClayScales is an unknown quantity at this point
Team 231's robot uses only two omni wheels in front of two pneumatic traction wheels (conventionally aligned). These afford extreme maneuverability at the cost of some lateral traction... surprisingly though, the omni wheels have pretty good traction fore and aft. Also, since our machine is oriented such that our wheel base is shorter than the track (wide and short), it maximizes the leverage of the traction wheels and we're still able to 'point' fairly well. Omni's do carry liabilities, but the trade off seems to have been worth it. NOT holonomic though.
Clay
Clay Scales
Unread 07-04-2006, 21:46
Doug G's Avatar
Doug G Doug G is offline
Coach / Teacher
FRC #0701 (Robovikes)
Your holonomic system worked very well and your manueverability was outstanding, but often times the area in front of the ramp was crowded and the lack of shooters at UC Davis (aka Sac-"cough"), meant you (and everyone else) got pushed around a lot. Also it meant not getting on the ramp. Anyhow - we so much enjoyed your gracious professionalism when our AndyMark omni's broke apart on us and you gave us not just one but two replacements - Thank you!!
We had to use two omni's on the back of our robot to improve our ability to turn.
Unread 09-04-2006, 21:06
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
all i can say is that in a game like this if i would make a swerve drive it would be a coaxle with ifi roughtop tread.
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 12-04-2006, 19:29
James Dowd's Avatar
James Dowd James Dowd is offline
A Michigan Man
FRC #1739 (Chicago Knights)
James Dowd will become famous soon enoughJames Dowd will become famous soon enough
Send a message via AIM to James Dowd
Originally Posted by Richard
Congratulations to 830 on a great regional and Autodesk Visualization Award at Waterloo!
Another holonomic team (854) was 8th alliance captain, picking 830 and 1189 (J&J Sportsmanship). My own team (931) also had holonomic drive, won the Saturday Judges Award, and was part of the 5th alliance along with 1680 (the third Niagara triplet) and 1901 (GMID and Rookie Inspiration). So holonomic teams were well recognized and in good company; however, I don't think any advanced to the semifinals.
I don't recall which other team had holonomic drive at Waterloo. Any help?
I think that one of the reasons we had a tough time advancing was because we had two holonomic robots on one alliance. Like someone mentioned before, one of the most effective ways to use a holonomic drive is similar to the pick and roll in basketball. But if there is no robot to use as a pick, then it is hard to compete against strong defenders.
As for defense, I don't think we sacrificed that much. Because of the extra maneuverability, we are able to out position some robots, stopping them from shooting. We have beaten high-profile teams like 1680 (a triplet) and 68 by doing this.
James Dowd
FRC Team 1739 Mentor, FTC Team 329 Coach
Former Team 830 Mentor and Coach
Former Member of Team 573
2009 Wisconsin Regional Engineering Inspiration Award, Midwest Regional Engineering Inspiration Award
2007 Waterloo Regional Xerox Creativity Award
2006 Waterloo Regional Autodesk Visualization Award
2003 West Michigan Regional Engineering Inspiration Award, Buckeye Regional Xerox Creativity Award
2001 Curie Division Finalist, Great Lakes Regional Finalist, West Michigan Regional Rookie All-Star Award
Red Advantage ? Krystine T. General Forum 90 16-06-2008 13:41
Holonomic drive and ramp robotaddict Technical Discussion 11 13-01-2006 16:57
CAD/Inventor Drawings for Drivetrains twolf Inventor 10 21-11-2005 12:17
Holonomic Drive Question Jeff Waegelin Technical Discussion 12 20-11-2005 21:23
Holonomic... Greg Perkins Technical Discussion 2 02-02-2005 11:59
