Go to Post I can't wait to get to St. Louis!! Oh wait.. I'm already here!! - Team 288 [more]
Unread 10-04-2006, 09:11
Eisner664 Eisner664 is offline
FRC #1100
Eisner664 can only hope to improve
Need your help
Hey teams, i need your help:
I need to right a program in c++ for my final project, i decided to make it on FIRST, so i decided to make a program that will ask a user ten questions, and then you will get a rank of how much of a roboholic you are,
i need some help on what questions to ask???
Go Team 1100
Unread 10-04-2006, 10:28
Qbranch Qbranch is offline
wow college goes fast.
AKA: Alex
FRC #1024 (Kil-A-Bytes)
Qbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond reputeQbranch has a reputation beyond repute
Re: Need your help
1. what baud rate does the ifi loader run at? 115.2 Kbaud
2. what is the maximum storage pressure for the pneumatics system? 120psi
3. what should one do if they want to lighten a robot? Drill Speed Holes
4. how many amps does the main breaker trip at? 120A
5. what is the heaviest guage of wire used in the robot? 6guage
6. what clock speed does the secondary (user) processor run at within the robot controller? 40MHz
7. what is the size of the pit area, in all 3 dimensions? 10x10x10'
Tell me what you think of these, I'll think of some more later. I can ask some higher level programming/electrical/mechanical questions if you want them.
Electrical Engineer Illini
1024 | Programmer '06, '07, '08 | Driver '08
Unread 10-04-2006, 10:32
GeorgeTheEng's Avatar
GeorgeTheEng GeorgeTheEng is offline
Former Lord of the Vex
AKA: George Marchant
FRC #0087 (Red Devils)
GeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud ofGeorgeTheEng has much to be proud of
Send a message via AIM to GeorgeTheEng
Re: Need your help
5. what is the heaviest guage of wire used in the robot? 12guage
Not bad questions, but the answer to number 5 should be 6 guage.
George Marchant - Lockheed Martin Engineer & General Nut Case
FIRST Credentials: Team 87 Mentor | Former Director FIRST Vex Challenge
NJ FIRST Planning Committee Member & NJ FVC Committee Member
Philadelphia Alliance Regional Corporate Advisory Board Member |
FRC and FTC volunteer at too many places to list (NJ, VA, DE, PA, NY, Championship)|
"Hi my name is George and I'm a FIRST-aholic. I've been a FIRST-aholic since 2000..."
Unread 10-04-2006, 10:40
AKA: Alex
Re: Need your help
oh how about some camera trivia:
1. how many volts does the CMUcam run on? 5v
2. what communications format does the camera use? TTL
3. to what format does the TTL converter convert to? RS-232
4. how many kilobaud does the camera talk at? 115.2
rufu5's Avatar
rufu5 rufu5 is offline
20something
FRC #6721 (Trailblazer Robotics)
rufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud ofrufu5 has much to be proud of
Send a message via AIM to rufu5
Re: Need your help
1) What style 40 amp fuse block was provided in the 2005 KOP? Maxi-Style Fuse Block
2) In what year was the FVC pilot season? 2005
3) Who is the only man to round-house kick a solid chunk of aluminum and create 3 fully functional robots? Andy Baker
4) Is carbon fiber on the prohibited materials list? No
5) What was the name of the first FRC game? Maize-Craze
One of those questions was on my physics final, you guess which
have no fear of perfection, you will never reach it.
-Salvador Dali
Jeremiah H Jeremiah H is offline
FRC #0393 (Full Metal Jackets)
Jeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of lightJeremiah H is a glorious beacon of light
Re: Need your help
~Do you ever find yourself "daydreaming" about robot design?
If so, how in depth are your designs? (Rate 1-10)
~How? (Any way that works. )
And the ever-present, ever-important
~Why? (Why not? )
I'll post more when I come up with them.
Johnson & Johnson Sportsmanshp Award, Buckeye '07
Johnson & Johnson Sportsmanshp Award, VCU '07
Finalists at Pittsburgh '06
Pittsburgh GM Industrial Design Award '06
Voted 2006 Boilermaker 'Best Defensive Robot' '06
Unread 10-04-2006, 10:48
AKA: Alex
Re: Need your help
~Why? (Why not? )
to add on to that:
do you find yourself making 1/4 scale models of the 2006 and previous FRC games with vex kits?
do you go on chief delphi almost every day?
you worry about your robot feeling alone in the drayage warehouse?
ok i'm getting off now.
Unread 10-04-2006, 11:10
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Re: Need your help
Gee! I don't know. Maybe I just don't get it. I have but two questions:
Who's final project is this? & Why can't you earn your own grade?
Unread 10-04-2006, 11:18
Re: Need your help
do you work on your robot first thing in the morning?
do you work on your robot when you are all alone?
have you ever lied to your friends and family and told them you were doing something else, when you were really working on your robot?
do you sometimes dissapear for 3 or 4 days at a time?
do you ever wake up in the morning and you cant remember how many robots you worked on the night before?
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
Re: Need your help
Originally Posted by Jack Jones
Gee! I don't know. Maybe "I just don't get it." I have but two questions:
I'm guessing that give this thread a week and coming up with 10 questions on his own would have been easier than picking from the donzens that will be appearing here.
Unread 10-04-2006, 11:19
Re: Need your help
sounds like the project is C programming - he's only asking for FIRST input to make it interesting.
Unread 10-04-2006, 11:28
Retired
Re: Need your help
OIC - good catch! So this is the uncreative C programing discipline. We have bunches who must have took the same class.
Unread 10-04-2006, 13:39
Dillon Compton Dillon Compton is offline
Jack-Of-All-Trades
FRC #1391 (Metal Moose)
Dillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud ofDillon Compton has much to be proud of
Send a message via AIM to Dillon Compton
Re: Need your help
Actually, in 2005 we got the IFI panels- the 40amp fuse block was built in.
www.metalmoose.com
Unread 10-04-2006, 14:17
FRC #1100
Re: Need your help
Those are good questions, but i am looking mroe for questions about activeness in FIRST
****Once i am done witht eh program, i will try to put it one the web!!!!!!
Go Team 1100
Unread 10-04-2006, 14:59
rufu5's Avatar
20something
Re: Need your help
Sorry, that was a typo, I got my years mixed up, I meant 2004 (the big gold one, the year they gave us the glorious gift of 40amp breakers).
Maybe a better question would be:
What year did FIRST first allow 40 amp to run to a motor. 2004
-Salvador Dali
