Go to Post ... we are really in FIRST to develop a love and appreciation for Math, Science, and Technology. This is our goal. Every team can do this effectively regardless of how well they do in competitions. - tennispro9911 [more]
Unread 11-04-2006, 00:44
Gabe's Avatar
Gabe Gabe is offline
Pocket Full of Tools
FRC #0604 (Quixilver)
Gabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond reputeGabe has a reputation beyond repute
Custom Extrusions
I am looking for a way to have an aluminum extrusion custom made to dimensions.
The material would be 0.125 thickness (1/8") and the design is not very complicated. What information would I need to provide to have an extrusion made? How much would it cost?
(It's for a summer robot project.)
Team site: Q U I X I L V E R
My favorite tool is my imagination; I’m always finding new ways to use it.
Unread 11-04-2006, 01:04
Jizvonius's Avatar
Jizvonius Jizvonius is offline
AKA: Jevawn Roberts
FRC #1002 (CircuitRunners)
Jizvonius is just really niceJizvonius is just really niceJizvonius is just really niceJizvonius is just really nice
Send a message via AIM to Jizvonius
Re: Custom Extrusions
Custom extrusion is an expensive affair that usually doesn't pay off unless you need a lot of the extruded material (like hundreds of feet for a machine that will turn a profit). The machine time as well as the cost to create the die will get very expensive even for simple shapes. If this is just a summer project, I would suggest finding another means to create the parts you need, or modifying the design to use existing extrusions.
Either way if you still want to have the extrusion done, you would want to specify the alloy, the geometry(profile) and tolerances at the very least. This is all assuming that you know of someone who will extrude this for you.
Jevawn Roberts
Georgia Tech Mechanical Engineering Senior
Co-Leader - GT FIRST
gtfirst@robojackets.org
1997-2007 w00t for robots!
108-132-408-832-1002
5 teams worth of head scratching
Unread 11-04-2006, 01:19
Rohith Surampudi's Avatar
Rohith Surampudi Rohith Surampudi is offline
probably needs a new WAI
FRC #0075 (RoboRaiders)
Rohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond reputeRohith Surampudi has a reputation beyond repute
Send a message via AIM to Rohith Surampudi
if in fact you do want to use extrusion, the prices will vary, my suggestion would be find a local metal/machine shop and take them your request.
Blargha!
Unread 11-04-2006, 02:39
Gabe's Avatar
Question Re: Custom Extrusions
Maybe I should explain that I need several hundred small, identical pieces (chain links). My idea is to have the extrusion made and then bandsaw it crosswise to get as many pieces as I want. Otherwise I would CNC each individual part, which would take time. This help?
Unread 11-04-2006, 03:23
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
You're making an omnitrack aren't you?
Unread 11-04-2006, 12:37
Woodie Flowers Award
Ken Patton Ken Patton is offline
purple
FRC #0051 (Wings of Fire)
Ken Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond reputeKen Patton has a reputation beyond repute
I have not seen your design, but could you make the part as a stamping?
Unread 11-04-2006, 13:00
Rob Rob is offline
AKA: Rob
FRC #0131 (CHAOS)
Rob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond reputeRob has a reputation beyond repute
Send a message via AIM to Rob
Ken is (as usual) right on the ball here. It seems like a sheetmetal operation would be best for getting what you want.
Extrusions need extreme quantities to be economical, and bandsawing them would probably not be conducive to high quality parts.
You should look into stamping, punching (may have a high tooling cost), or simply laser or waterjet cutting the parts you want.
For what application are you trying to make custom chain?
Rob
Unread 11-04-2006, 13:01
Peter Matteson's Avatar
Ambitious but rubbish!
FRC #0177 (Bobcat Robotics)
I would make a drawing of the cross section to be extruded and send it to a shop for a quote if you want a good idea. Also the smallest quantity I've ever been able to get is ~1000 lbs. order.
Tooling isn't too expensive (relatively) as long as the cross section is simple and the wall thickness is constant. The shop should take your net shape and correct it to a mold for die swell etc. once you have and agreement.
Thank-you 294 & 67
www.bobcatrobotics.org
Unread 11-04-2006, 17:32
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
Laser cutting, water jetting, chemical etching, stamping... I think these are your best solutions to getting 1,000's of identical, flat metal plates. If it's plastic, you can certainly find some rapid prototyping companies to make you a mold to pop those out. The more info you get us, the more help we can be for you.
BEN
Unread 12-04-2006, 04:05
Gabe's Avatar
I'll reveal what my project is: omnitracks. I need about 250 links for two belts on an experimental base. Since a picture is worth a thousand words, I uploaded an image of the ommnitrack links in the photo gallery (tag: omnitrack). I would want ab extrusion or metalwork that has that profile.
has anyone made a custom com-1 output? binary_sandman Programming 8 17-01-2006 16:05
EasyC v. 2.0 - New features, custom user functions, and more! artdutra04 FIRST Tech Challenge 1 02-11-2005 13:36
Drive Assembly Sprockets are Custom Bored Mark Pettit Kit & Additional Hardware 35 09-03-2005 19:05
Custom Colors and Weights in Inventor ? sanddrag Inventor 3 26-02-2005 18:14
So what's in YOUR Custom Circuit this year? kmcclary Technical Discussion 7 10-04-2002 12:20
