Go to Post Happy 6 days till FIRSTmas! (and Happy New Year, but that pales in comparison =D) - VKP [more]
Unread 11-04-2006, 07:08
AKA: Brad
#0190 ( Gompei and the Herd)
Re: Programming: MotorRcControl() vs GetRxInput()/SetServo()
Originally Posted by GlennGraham
Ok, I've been beating my head against this for a couple of days and haven't solved the problem. If I do the following, things work fine:
while(1) {
// control motor connected to #8 with channel #3
MotorRcControl(1, 3, 8, 0);
...but the following makes the servos connected to the uController go nuts:
int armASpeed = 0;
while(1) {
armASpeed = GetRxInput(1, 3);
PrintToScreen("armASpeed: %d", armASpeed);
SetMotor(8, armASpeed);
-Glenn
There are some quirks with the way EasyC V1 worked with motor and receiver commands. You could only use the PWM commands in some cases and only use the SetMotor in others and using the wrong ones would cause problems. It's all been cleaned up in EasyC V2 and they are interchangeable.
Are you using V1? If so, look at the help because I think the correct use is described there. But if you are, I'd suggest tryng to upgrade to V2 since it has some nice extra features (like user functions) and all that stuff is cleaned up.
Brad Miller
Robotics Resource Center
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
VEX programming Gene F Programming 14 08-08-2006 22:21
Programming Forum Warning Brandon Martus Announcements 10 29-12-2005 13:32
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
