Go to Post Remember the volunteering is not mandatory for the people to do it. It IS mandatory if FIRST is to survive and the regionals to leave a positive impact on everybody. - Alavinus [more]
Unread 26-03-2006, 23:54
GlennGraham's Avatar
GlennGraham GlennGraham is offline
AKA: Glenn Graham
FLL #0006 (Shark Bait!)
GlennGraham is an unknown quantity at this point
Programming: MotorRcControl() vs GetRxInput()/SetServo()
Ok, I've been beating my head against this for a couple of days and haven't solved the problem. If I do the following, things work fine:
while(1) {
// control motor connected to #8 with channel #3
MotorRcControl(1, 3, 8, 0);
...but the following makes the servos connected to the uController go nuts:
int armASpeed = 0;
while(1) {
armASpeed = GetRxInput(1, 3);
PrintToScreen("armASpeed: %d", armASpeed);
SetMotor(8, armASpeed);
Also, I see a value of 127 returned, no matter the position of the R/C stick.
If I comment out the SetMotor() call I see the value of armASpeed change with the R/C stick position, as I would expect. So, it appears to be related to the SetMotor() call.
I've checked the arguments against the UserAPI.h headers. Do I have a syntax problem? Is it timing? I don't trust this dual processor arrangement (it seems fragile) and I suspect it might be involved.
Thanks,
-Glenn
Unread 27-03-2006, 00:56
AKA: Glenn Graham
Re: Programming: MotorRcControl() vs GetRxInput()/SetServo()
An earlier search didn't turn up anything on SetMotor() or SetServo() but a second search turned up some examples using SetPWM(). I believe my problem has to do with the size of the variable I was using as an argument. Things seem to be working if I use:
unsigned char armASpeed = 0;
while(1) {
armASpeed = GetRxInput(1,3);
PrintToScreen("armASpeed: %d\n",(int)armASpeed);
SetPWM(8, armASpeed);
Thanks,
-Glenn
Unread 09-04-2006, 23:48
michael714's Avatar
michael714 michael714 is offline
FRC #3863 (Pantherbotics)
michael714 is on a distinguished road
These commands look interesting. Are they available in EasyC 1.1 or are they from EasyC 2.0? I'm looking for a way to control the two motors in the SquareBot using channel 2 and 3 and then also control the servo using Channel 3 joystick with a side to side motion. The default system works this way, but when I use EasyC to combine autonomy with RC, this ability goes away. Any ideas would be appreciated.
EDIT: Silly me. The commands I was asking about are available in EasyC 1.1, you just have to choose Professional Level via the Options menu. Duh!
Unread 10-04-2006, 13:44
AKA: Glenn Graham
As you can see from the messages above, I'm new to programming Vex (many years writing C/C++ code for EDA software though). I've installed EasyC 1.1 but have been using the MPLAB IDE for development (as described in another thread). I believe all the routines are available from EasyC (each routine in my program maps to an EasyC block. You should be able to see the equivelent C code listed in the window next to the block diagram). For reference, my full program is listed at the bottom (if anyone has additional tips, please let me know):
#include "UserAPI.h"
#define OUTPUT	0
#define INPUT	1
void IO_Initialization(void)
	DefineControllerIO ( 4, INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,INPUT ,OUTPUT ,INPUT ,OUTPUT ,OUTPUT ,OUTPUT ,OUTPUT ) ;
 * This code implements the behavior for controlling our 6 wheel robot with
 * a articulated arm consisting of multiple parts. Each part will be
 * referenced as armA, armB, etc.
void main ( void )
      // Connections to the controller
      unsigned char uCMotorLeft = 3; // uController connection for left motor
      unsigned char uCMotorRight = 2; // uController connection for right motor
      unsigned char uCButton1 = 10;
      unsigned char uCArmA = 8; // uController connection for armA
      unsigned char uCArmB = 1; // uController connection for armB
      // Radio Channels and their behavior
      unsigned char channelMove = 2; // Radio channel used for move;
      unsigned char channelRotate = 1; // Radion channel used for rotate;
      unsigned char channelArmA = 3; // Radio channel used for armA;
      unsigned char channelArmB = 5; // Radio channel used for armB;
      // Position, speed, state variables
      unsigned char button1 = 1; // Button changes state from radio to <other>
      unsigned char armASpeed = 0; // Value for arm #1 position
      unsigned char armBPos = 127;
      while ( 1 )
         unsigned char c5 = 127;
         unsigned char c3 = 127;
         // Use the "canned" one stick maneuvering
         Arcade2(1, channelMove, channelRotate, uCMotorLeft, uCMotorRight, 1, 1);
         // Get transmitter value for arm joint A
         c3 = GetRxInput(1, channelArmA);
         // Joint A uses geared-down motor, so run forward or back
         // Provide a "dead" range from 117 to 137 otherwise use value as-is.
         if(c3 > 137) {
             armASpeed = c3;
         } else if(c3 < 117) {
             armASpeed = c3;
         } else {
             armASpeed = 127;
         // Get transmitter value for arm joint B
         c5 = GetRxInput(1, channelArmB);
         // Joint B is a claw utilizing a servo motor.
         // Controlled with button on back of transmitter.
         // Set position to open/closed depending on button state.
         if(c5 > 137) {
             armBPos = 255;
         } else {
             armBPos = 0;
         SetPWM(uCArmA, armASpeed);
         SetPWM(uCArmB, armBPos);
Unread 11-04-2006, 07:08
AKA: Brad
#0190 ( Gompei and the Herd)
while(1) {
int armASpeed = 0;
while(1) {
-Glenn
There are some quirks with the way EasyC V1 worked with motor and receiver commands. You could only use the PWM commands in some cases and only use the SetMotor in others and using the wrong ones would cause problems. It's all been cleaned up in EasyC V2 and they are interchangeable.
Are you using V1? If so, look at the help because I think the correct use is described there. But if you are, I'd suggest tryng to upgrade to V2 since it has some nice extra features (like user functions) and all that stuff is cleaned up.
Brad Miller
Robotics Resource Center
Programming Vex w/ MPLab dababyjebus FIRST Tech Challenge 27 25-04-2008 09:11
Programming - Getting Started Mark McLeod Programming 80 16-04-2008 23:37
VEX programming Gene F Programming 14 08-08-2006 22:21
Programming Forum Warning Brandon Martus Announcements 10 29-12-2005 13:32
Robot Programming Education phrontist Programming 11 03-05-2004 07:32
