Go to Post I would feel more comfortable if you used rock-paper-scissor-lizard-Spock. - IndySam [more]
Unread 11-04-2006, 08:10
President, AndyMark, Inc.
FRC #3940 (CyberTooth)
Re: 222's TigerDrive
Very, very nice transmission. The compact design is fabulous. The reversed direction pneumatic cylinder is a nice twist to save space. I do have some questions:
1. What made you switch from bushings to bearings?
2. Why use collar clamps on the CIM shafts as opposed to steel shaft clips (like the ones used on the Kit Transmission)?
3. Are the CIM gears pressed onto the CIM shafts?
This is definitely another outstanding design coming from the Tigertrons.
Way to go!!
Andy B.
Unread 11-04-2006, 08:41
camtunkpa camtunkpa is offline
it's like shooting fish in a barrel
AKA: Cliff Mock
FRC #0222 (Tigertrons)
camtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond reputecamtunkpa has a reputation beyond repute
Way to go!!
Andy B.
1. We switched from bushings to bearings for a couple reasons. The first reason was simply to increase efficiency. The second reason is because bearings worked out very well for our input cluster. Bushings were a simple and cost effective method for 2005, but were not the best way to do things on a high RPM gear cluster.
2&3. The gears on our CIM motors are not stem pinions. We had planned on stem pinions and using another bearing in the plate opposite the CIM motors, but decided we could save some weight and headaches by switching to a regular gear. the reason we have collars on the CIM gears is to 'pinch' the gear onto the shaft. We did this mainly because our team doesn't have any metric broaches and we didn't want to modify the CIM shaft. We have used this design previously in 2004 and it worked very well for us.
Thanks all for the kind compliments! Transmissions like this only happen when enthusiastic STUDENTS get involved in the design and build and constantly push the team to do better! Thanks Henry and Bunney you guys put in alot of time convincing the team we needed a dual motor drive and even more time machining your wishes.
"Engineering is making the impossible happen"
"We are here to create, not merely survive" - unknown fortune cookie
"If you don't push the envelope you're just spinning your wheels"
Unread 11-04-2006, 23:19
Rabbit222's Avatar
Rabbit222 Rabbit222 is offline
reffed PARC for 3 yrs now
AKA: DA BUNNEY
Rabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really niceRabbit222 is just really nice
Send a message via AIM to Rabbit222
Thanks Cliff for believing in us!
PARC 12 CHAMPIONS 222, 2753, 1640
2009 Archimedes Champions with 2753 & 1218 Einstein Semifinalists
2009 Philadelphia GM Industrial Design Award
2009 Pittsburgh Champions with 1218 & 1743
2009 Pittsburgh Judges Award
2009 Pittsburgh Autodesk Visualization Award
2008 Pittsburgh Motorola Quality award
2007 Pittsburgh Finalists with 48 & 1038
PARC 9 CHAMPIONS 25,222,423
Unread 12-04-2006, 00:34
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
I thought somebody told me once that you were running 20 pitch 11 tooth pinions on the CIM motors and the reason for those clamping collars is that you cannot fit a keyway because the "wall thickness" between the root diameter and the bore diameter is so thin. I might be dreaming though. I can't remember.
Unread 12-04-2006, 08:20
AKA: Cliff Mock
yup you are correct I just looked at the measurements last night.
pic: Team 222's 2005 Claw henryBsick Robot Showcase 3 23-02-2005 21:48
White Paper Discuss: 222's 3 Speed Shift-On-The-Fly Transmission CD47-Bot Extra Discussion 4 14-07-2004 15:43
Team 222's 2004 Inventor Award submission team222badbrad Inventor 0 15-03-2004 20:08
pic: 222's wheels CD47-Bot Robot Showcase 14 11-12-2003 08:14
Image Discuss: One of 222's BIG STACK CD47-Bot Extra Discussion 8 12-02-2003 17:12
