Go to Post The best we can all do for our kids as parents, mentors and world citizens, is to model [Gracious Professionalism] always: not to win an award, but because it is the right thing to do. - chapman1 [more]
Unread 10-04-2006, 20:01
neo-cortex neo-cortex is offline
C.Programmer
FRC #1346 (Trobotics)
neo-cortex is an unknown quantity at this point
Re: Transmission help
Our team is planning to work on a 2 gear transmission as well in the off season.. the details haven't been worked out yet but it's floating around
Unread 10-04-2006, 21:01
thoughtful's Avatar
thoughtful thoughtful is offline
FRC #1219 (Emery Iron Eagle)
thoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to beholdthoughtful is a splendid one to behold
Originally Posted by Tom Bottiglieri
It might be worth the weight, but is it worth the delayed shift time and possibility of breaking?
I dont have much experience with shifting tranys, but can you ellaborate on the delayed shift time that occurs from servos?
.:Bringling Brains to Life:.
03,04,05-Team 1219 Captain
2003 Rookie all Start @ GTR
2005 Galileo Semi-Finalist & Alliance captain
06-Team 1219 Mentor
2006 Radio Shack Innovation in control @ Waterloo
Unread 10-04-2006, 21:04
Jeff K.'s Avatar
Jeff K. Jeff K. is offline
Hmm..now what?
FRC #1138 (Eagle Engineering)
Jeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond reputeJeff K. has a reputation beyond repute
Send a message via AIM to Jeff K. Send a message via MSN to Jeff K.
Our team is also planning on designing and prototyping with a 2 speed this offseason. We bought the AndyMark 2 speeds and we found them to be expensive, yet very reliable. We have the gear ratios and calculations for torque and what not down. And now just - CAD TIME.
We're hoping to have a sponsor machine most of the stuff...that is unless we get a CNC Mill sometime soon.
Unread 10-04-2006, 21:08
ICE MAN's Avatar
ICE MAN ICE MAN is offline
ICE MAN
AKA: John Cory Brown
FRC #0832 (Chimera)
ICE MAN is an unknown quantity at this point
Send a message via AIM to ICE MAN
If you can perfect the shift on the fly and have your low gear have high torque and your high gear have good top speed, you will most likely be a force to rekon with. Reason why? Most 2 speed transmissions have pretty bad low end torque and good top speed. the problem with this is that if you get into a push match then your extra gear is pointless because you cant get away to use it. so a high torque low gear would help you get out of push matches which of this year we all know from now on will happen, and a top speed high gear will help you get away from your oppentes with ease. so the choice is up to you. personaly that is a lot of stuff that has to work in order to just get the robot moving not even to mention the rest of the robot that has to complet the game. my advice, buy a 2 speed transmission from andy mark or some other robotics company, build it and see how it works. then if you think that you can do what a professional company could do it and make it run well in 6 weeks then I say go for it. But as for me and my team will let the big first dogs do that and we will stick with our simple yet effective transimission which has so far got us to the finals two years running. Good luck with your transmission and hope it al works well in the end.
In life, if what we want and what we get isnt what we expected, then thats life, because we cant always get what we want and what we get is never what we expected.
This is our teams offical website, enjoy:http://www.angelfire.com/droid/roswellrobotics/
Unread 11-04-2006, 18:20
Mike Nawrot's Avatar
Mike Nawrot Mike Nawrot is offline
NAwrot (a.k.a. jub jub)
AKA: Mike
FRC #0011 (MORT (Mount Olive Robotics Team))
Mike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really niceMike Nawrot is just really nice
Send a message via AIM to Mike Nawrot
Post Re: Transmission help
one cause for delay would be the small difference between servos, so that one side shifts before the other, and kinda causes the robot to go in a not-so-good direction.
I developed my own two speed recently and i'm currently busy integrating it into a mock up drive train in autodesk. The transmission looks good on paper (or in this case LCD), but i'll have to see how it works in reality, with weight and costs and such. I've thought of my own little tricks for shifting and all, but those are my little secrets. As for the advantages to multi-speed transmissions, i think it is a great direction to go in. They destroy the generalization of function on the robot and open up the window of specialized functionality available in multiple scenarios on the same robot. In other words, if you're in a situation where you need to have detailed control over the robot, or you need power, you can get exactly that and nothing extra to get in the way. And then if you need the highest possible speed with no power, you can have that as well. Simply put, the two-speed's fuction has no downfall, it's only the approach towards the two-speed that can result in lost time, money, and weight.
"Its not just good... its good ENOUGH..." "Talk to me in two weeks" "It has to be done by Sunday" "Let me tell you a little something about FLL..."
"Physics don't apply on MORT robots" "What's today's roofigog?!" MIT class of 2012
Unread 11-04-2006, 18:25
Paul H's Avatar
Paul H Paul H is offline
Renegade of Funk
AKA: Paul Huston
FRC #0033 (Killer Bees)
Paul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant futurePaul H has a brilliant future
Send a message via AIM to Paul H
Check out the team 33 4 speed transmission. I may be biased, but I think it's the easiest to build, and it's definately the lightest. You can also just build half of it and have a two speed transmission. I think the 4 speed costs something like $80 in materials, and the two speed is even less.
-Paul
Unread 13-04-2006, 10:19
UCGL_Guy's Avatar
UCGL_Guy UCGL_Guy is offline
AKA: Ken YorK
None #0476 (Wildcats)
UCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to allUCGL_Guy is a name known to all
Send a message via AIM to UCGL_Guy
While the off the shelf trannies are great and work wonderfully - don't cheat yourself or students out of the learning experience available by designing and building your own. Look at it a another project. Pick a couple of ideas choose the style you want then begin designing it to meet your own criteria. The pride developed by doing this is immense. Our team loves our 3 speed trannies based off of 222's. We made our own tweaks and such and they hae worked great this year.
Most of all this can be fun and frustrating - start early - and test to refine your work of art.
Ken
Ken York
Mentor/Coach Team 476 Ponca City OK
An ignorant person is one who doesn't know what you have just found out.
Will Rogers
Unread 13-04-2006, 11:51
in between teams
AKA: Luke Van Oort
Although I have no direct experience with multi-speeds, when my brother was on team 900 in '03, they made a two speed. It would have been great, but they messed up their gear ratio calculations, the high speed was way too fast and nearly uncontrollable. Beware of incorrect ratios. Mind you, I'm not one to talk, the four speed double dog design I was pushing at the beginning of this year had a 4th gear with a speed in excess of 20 ft/s! (It got canned due to budget and lack of machining capability)
PS Shouldn't this be in Technical Discussion?
Team 1219: 2009 - Mentor
Unread 13-04-2006, 23:52
Jon Jack's Avatar
Jon Jack Jon Jack is offline
VEX Robotics
no team (No Team)
Jon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond reputeJon Jack has a reputation beyond repute
Send a message via AIM to Jon Jack
When it comes to weight the AndyMarks do help.
Last year we milled out the gears in our Kit Transmission, all in all the Kit Transmission was about 1-2 lbs lighter. When we got our AndyMarks this year we took our Kit Transmission from our robot last year and weighed it against an AndyMark. The AndyMarks were about 5-7 lbs lighter.
We actually designed a 2-Speed that used helical gears instead of spur gears. Our intentions were to use it on our robot this year, but we ran out of time and bought 2 AndyMarks. I must say that the AndyMarks are, IMHO, easier to install and maintain than even the Kit Transmissions! They easily integrated with the rest of our robot and we didn't have to change a lot on our drive train.
With that said, making your own transmission is a very valuable experience for students. Even though I personally didn't design the transmission, I learned a lot by watching the transmission be designed. I had no clue what meshing gears was or what dog gears were, but by the time we started putting together the first prototype of our 2-Speed transmission I knew what the difference was between meshing gears and using dog gears. For the students, actually getting to see a transmission designed, built and used will be an awesome learning experience.
Even though the transmission we designed was not ready to be used on this years robot, we learned a lot from how the AndyMarks that we want to use to improve our transmission. There were somethings we didn't spend much time considering, like how to mount the gear box or how to save space by changing the placement of the output shaft.
The bottom line is that I would 100% recommend designing your own transmission, if you have the money and machining capabilities, but don't over look existing or off the shelf transmissions.
Team 1538 / The Holy Cows, 2005-2016
Unread 14-04-2006, 15:51
Schneidie's Avatar
Schneidie Schneidie is offline
AKA: Marc Schneider
FRC #0177 (The Bobcats)
Schneidie will become famous soon enoughSchneidie will become famous soon enough
Originally Posted by litchfieldc
Me and a bunch of other members of team 1073 are going to be designing and building a new shiftable transmission with the help of our mentors. I'm just curious what other teams who had them think about them. Are they worth it, are they helpful for only certain times or helpful in every match. I don't need blue prints, (if you want to you can post them though ). I just want to know if this is going to be worth the trouble, thanks to all those who post, and see you all come next season.
We love our 2-speed transmissions. We got the AndyMark transmissions and they work wonders.
Schneidie
Unread 15-04-2006, 18:59
CardcaptorRLH85's Avatar
Happy Birthday! CardcaptorRLH85 CardcaptorRLH85 is offline
The master of the cards ^_^
AKA: Raa'Shaun H.
FRC #0322 (F.I.R.E. "Flint Inspires Real Engineers")
CardcaptorRLH85 is an unknown quantity at this point
Send a message via ICQ to CardcaptorRLH85 Send a message via AIM to CardcaptorRLH85 Send a message via MSN to CardcaptorRLH85 Send a message via Yahoo to CardcaptorRLH85
Our team made 3-speed (2002) and 2-speed (2003) planetary-gear transmissions however, we didn't really see the need for it in the last three competitions. The only problem with them was that we used pneumatics for shifting and that added a huge amount of weight and battery drain. If we see another game where there both high torque and high speed are needed during a match, then we will probably use a multi-speed transmission again. Otherwise IMHO it's probably not worth the design time or the expense...
Unread 17-04-2006, 09:04
stefwitt stefwitt is offline
stefwitt is on a distinguished road
I like the challenge of trying different technologies, although my team members prefer simplicity and robustness.
In theory a continuously variable transmission is the way to go, sensing the motor speed and adapt the gear ratio to it.
You'll find already so many different ideas and patents out there and you may even invent something new.
After some web-search, I found this one, which is my personal favor:
http://www.fallbrooktech.com/NuVinci.asp
Unread 19-04-2006, 17:35
litchfieldc's Avatar
litchfieldc litchfieldc is offline
Chris
FTC #1073 (The F.O.R.C.E)
Team Role: Driver
litchfieldc will become famous soon enoughlitchfieldc will become famous soon enough
I would like to use this post to thank all of you who are providing me with this info. I would send each of you an email, but I don't have the time to do so, seeing as how so many of you posted with ideas and thoughts. This forum is still open, but I just want to say thanks for all your help, it's things like this that make me want to come back to first each year. Once again, thanks.
Chris
River Rage 2006 First Place Alliance
It's one thing to get kids to pay attention, it's another to make them learn something
Tapping Into Kit Transmission Casing Madison Technical Discussion 6 13-12-2005 14:29
Is a shifting transmission really necessary? Jay TenBrink Technical Discussion 78 02-08-2005 09:21
Slickest drive transmission yet... dlavery Technical Discussion 58 10-01-2005 19:33
The perfect 2 speed Transmission..... features... Salik Syed Technical Discussion 28 20-10-2004 11:44
Need info on gears inside drill transmission. sanddrag Motors 7 14-04-2004 11:01
