Go to Post The best way to build a brand is to win. - Tom Bottiglieri [more]
Unread 10-04-2006, 19:37
Mike's Avatar
Mike Mike is offline
has common ground with Matt Krass
AKA: Mike Sorrenti
FRC #0237 (Sie-H2O-Bots (See-Hoe-Bots) [T.R.I.B.E.])
Mike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond reputeMike has a reputation beyond repute
Mechanical Robotic Kits
Being a programmer, I'm not the most mechanically inclined. I'm planning on building a small (35lbish) robot over the summer to test stuff on, but the only tools I have access to are a small bandsaw and tablesaw. So I can't really build my own robot. Are there any kits I can buy that build a generic four wheel bot?
http://www.mikesorrenti.com/
Unread 10-04-2006, 19:57
amos229's Avatar
amos229 amos229 is offline
Retired chicken man
AKA: amouse
FRC #0229 (Division By Zero)
amos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud ofamos229 has much to be proud of
Send a message via AIM to amos229 Send a message via Yahoo to amos229
Re: Mechanical Robotic Kits
i would find some quarter 20 aluminum extrusion and fp motor/gearboxes. build a basic platform and voila
Govenors see innovation like judges see pornograpghy, they dont know exactly what it is but they know it when they see it, Dean Kamen, BAE Regional, 2007
229 alumni= lifetime of inspiration
Unread 10-04-2006, 20:06
Not2B's Avatar
Not2B Not2B is offline
AKA: Brian Graham
If you like using the 8020 stuff many teams use, you can get cheap stuff from the 8020 surplus store on eBay.
8020-Inc-Garage-Sale
I am in no way associated with them, but it's dirt cheap, and it's easy to work with. The tricky part will be hooking up your motors.
Maybe you can partner up with some local mech-people that would love to build you a frame over the summer?? You fund the base, and you get to keep it, but they get the experience building it?
Plywood is the ultimate cheap base. Maybe that is a good idea for your uses?
Brian Graham
Unread 10-04-2006, 22:48
EricRobodox's Avatar
EricRobodox EricRobodox is offline
AKA: Eric... I think a lot
FRC #0599 (RoboDox)
EricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant futureEricRobodox has a brilliant future
Send a message via AIM to EricRobodox
i cant believe nobody said this yet....
IFI Robotics Kit. ahahaha.
www.ifirobotics.com
go to their mini-robot controller, and also you can find the rest of the kit there. Its basically a more FRC like kit than Vex, even though Vex is the new generation of the IFI kit. contact them, im sure they can help you.
My other car is being built to go to Mars in 2011.
Bet you aint got one of these...
Unread 11-04-2006, 15:44
Mike's Avatar
AKA: Mike Sorrenti
www.ifirobotics.com
Ehh, I considered that. Problem is I don't like the general PIC setup, plus with IFI controller's you are sandboxed a good amount. I'm also looking at building a robot that will be about 3x2x2 and sturdy enough to take a good beating... you can't get that with the EDU parts.
It's also a cost of $249 for the controller. I could build a high end (for robotics) computer and just mount that for that price.
Unread 11-04-2006, 17:28
Ben Piecuch Ben Piecuch is offline
Bengineer
Ben Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond reputeBen Piecuch has a reputation beyond repute
What's wrong with using a bit of wood? It's not going into competition, it's not going to break any speed records. Just screw together some 2x4's, 1x3's, whatever... If you need to strengthen it, just use some triangular gusset plates (aka, thin plywood) and voila! I'm sure you could find a lot of unused globe and window motors to directly mount a wheel onto. If it's just for programming, testing, etc...
However, if you want the best solution to your problem, I suggest using the good old VEX system. Cheap, simple, and all your sensors can be adapted to it. (Well, maybe not a gear tooth sensor, plastic gears and all...)
Is this along the lines of what you're looking for?
BEN
Unread 11-04-2006, 19:44
Not2B's Avatar
AKA: Brian Graham
OK, let's try something else...
What do you want this to do?
What kind of payload (12v car battery, or 7.2v RC car battery pack? BIG robot arm or just a sensor array?)
What kind of terrain?
Radio controlled? Or auto mode all the way?
Size? (Just big enough, or room to play with other add-ons?)
Use? (Just to test sensors, or future battle bot frame?)
Speed?
Complexity? (Sounds like you want simple as possible, with bandsaw fabracation only.)
Cost? (Can we spend $35,000?)
Etc...
SO, if you could describe what you want this to do, exactly and to as much detail as possible, I bet people here could help you come up with a design good for you.
Tell us as MUCH as possible. Even if it seems obvious to you. I'm not so smart most of the time, so you'll have to spell it out for me.
This could be fun!
Brian Graham
Unread 11-04-2006, 19:46
sanddrag sanddrag is offline
On to my 16th year in FRC
FRC #0696 (Circuit Breakers)
The wonderful country of China can help greatly in reducing the cost of this project. Did somebody say drill motors?
Unread 11-04-2006, 20:06
Not2B's Avatar
AKA: Brian Graham
I just got back from a trip to China. Those drills are only the tip of the iceburg. I could go down to the local hut and buy a 200 Ton injection molding machine and have it delivered that day. CNC Mills? Right next to the chickens. Take your pick - they are laying about. Just about everyone I met could weld (not well, but they could do it.) And you can buy ANYTHING with iPod stamped on it. iPod cameras. iPod TVs. iPod memory sticks. iPod music players. Now keep in mind NONE of them were iPods, but if you are going to do copywrite infringement, you may as well go BIG.
But most importantly, everyone wanted to learn as much as they could. I've never seen anything like it. The entire City of Shenzhen was like a 24 hour a day FIRST build season.
OK, sorry - back to the base design. Sorry bout that.
Brian Graham
Unread 11-04-2006, 20:32
J Flex 188's Avatar
J Flex 188 J Flex 188 is offline
"flock their sheep"
AKA: Jeffrey Li
FRC #2505 (The Electric Sheep) & FRC #0188 (Blizzard)
J Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond reputeJ Flex 188 has a reputation beyond repute
Send a message via ICQ to J Flex 188 Send a message via AIM to J Flex 188
Put in a nutshell, that's exactly why Dean wants FIRST to expand and to grow across North America. How often do you see such a scene in your average North American city. There's no question that this can't be repeated in every city around China, but there is a definite eagerness to learn more, do more and be more in that country. The only problem is doing it legally. Growing up in that environment means people lack a certain sense of ethical reasoning, where you would find a different kind of collaboration amongst FIRST teams in China, probably the importation and copying of the Simbots without their permission
Now to get this post slightly back on to topic,
Has anyone experimented with old controllers and the old school PBASIC controller from past years at home? I'm thinking of buying a VEX kit and tinkering with it at home, or for something cheaper, but possibly less reliable and much more complicated, using old controllers from my team's stash (of course I'd have to clear it with them first )
Woburn Robotics, Class of 2005.
Unread 11-04-2006, 21:17
Elgin Clock's Avatar
FRC #0237 (Black Magic)
Hmm.. note to self.
edit: Learn how to speak Chinese, and negotiate deals more better. LOL
THEN Go to China and visit some street markets.
w00t for capitalism!
Unread 11-04-2006, 21:23
Cody Carey's Avatar
Cody Carey Cody Carey is offline
AKA: C. Carey
FRC #0306 (CRT)
Cody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond reputeCody Carey has a reputation beyond repute
Send a message via AIM to Cody Carey Send a message via Yahoo to Cody Carey
Why not wood? just mount stuff with drywall screws.
I'm not joking... There are robots that go into competition with wood bases, and all you need it for is testing anyway, right? It's cheap; You can work it into any simple machine with a table/band saw, and it is readily replaceable.
Unread 13-04-2006, 02:39
FRC #0599 (RoboDox)
R/C car? mod the electronics. im sure there are plenty of R/C cars that have programmable controls anyways.
Unread 13-04-2006, 08:21
Jeremiah Johnson's Avatar
Jeremiah Johnson Jeremiah Johnson is offline
Go VOLS!!
AKA: Budda648
no team (QC Elite)
Jeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond reputeJeremiah Johnson has a reputation beyond repute
Send a message via AIM to Jeremiah Johnson Send a message via MSN to Jeremiah Johnson
Any good websites that actually teach you how to mod an R/C car? I have a couple just lying around and I want to make me a robot. LOL.
Do The Tyler!
XBOX Live Gamertag = theVelvetLie
Unread 13-04-2006, 10:18
MikeJ675's Avatar
MikeJ675 MikeJ675 is offline
Near Chaos Robotics
AKA: Mike Jeffries
no team (Near Chaos Robotics)
MikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to allMikeJ675 is a name known to all
Send a message via AIM to MikeJ675
I know it's not quite what you were looking for, but as far as quality and power go, these are probably the best robot kits you'll find.
BattleKits
These kits are made by Carlo Bertocchini, of Biohazard fame.
"Kit" might not be the best word to describe our products. We ship them fully assembled, (except for electrical connections), so that you can go right to work adding your finishing touches. Leaving the armor and weapon up to you preserves maximum versatility and flexibility and it requires you to use your creativity to come up with a winning design. We did not want to create a situation where several identical robots show up at a competition. We would rather provide a rugged, low-profile, mobile platform on which you can build the next killer robot.
Team 675-Alumni
Near Chaos Robotics
Robotic fish swim in a aquarium! mechanicalbrain Chit-Chat 4 09-10-2005 02:57
Are the VEX kits worth buying? Ken Delaney 357 FIRST Tech Challenge 29 15-05-2005 11:51
Robotic Competitors Uniform dennis_team40 General Forum 5 06-02-2005 15:44
Mechanical Wheel Encoders? Jaine Perotti Electrical 15 04-12-2004 22:46
Max mechanical power of motors, how is it useful? Ken Leung Motors 1 09-11-2001 14:15
