Go to Post You all have made me think about this in a new way - which I appreciate. - aaeamdar [more]
Unread 11-04-2006, 22:21
Re: Potentiometer 5 or 6 detents
forgive my ignorance of this years OI, is the red LED display still able to display user selected numbers?
set your code to read a joystick or pushbutton input - everytime you push the button increment a counter, and display it on the OI LED numeric output - that is your autom mode number
you could have up to 256 different auton modes that way.
Unread 11-04-2006, 22:43
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
The rotary switch seems like a good solution, if it does in fact have solid feeling stops, so we could easily differentiate between the 6 positions.
The only problem is, I would be the one wiring it up and have practically zero electronics knowledge and would need some help selecting resistors and wiring it up to specific pins on the switch and the RC. If you guys could help me out there, It would be HUGELY appreciated.
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 11-04-2006, 22:53
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
The idea here isn't as much the actual resistance as the concept. The current through the circuit I is defined as I=V/Rtotal where Rtotal is the sum of the two resistors: the initial one connecting from 5V to the common lead, and the secondary resistor from the switch to ground. Then the voltage measured at the common lead can be calculated as V=IRswitch (the resistance from the switch to ground). The actual R value will cancel out.
----- Rc ----- Rswitch <--the dashes are just spacers here...
5V--^v^v--|--^v^v--gnd
________Input
Rc=R, Rswitch=#R
I=(5V)/(Rc+Rswitch)
Vinput=I(Rswitch)=(5V)(#R)/(R+#R)=(5V)(#)/(1+#)
Hope this helps.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 11-04-2006, 23:10
Engineering Mentor
FRC #0254
Originally Posted by Adam Shapiro
Hope this helps.
Sort of... In reality, I still have no idea where to start. I am an ME/MFE with very little electronics experience... so please bear with me.
-Travis Covington
Unread 11-04-2006, 23:12
Heh, not a problem. You should probably choose some value of R in the 10000s to protect the input (I believe).
EDIT: It seems the OI manual suggests 100k ohms for a value. This seems resonable as it will only allow for a very small amount of current between 5V and gnd (I=V/R=5/(100000)=50uA). This is for safety as well as to prevent against large flows of current when using the OI. Don't forget the OI has its own built in fuses to protect itself, but you still want to be careful.
Unread 11-04-2006, 23:49
Engineering Mentor
FRC #0254
My plan was to mount it on the RC.
-Travis Covington
Unread 11-04-2006, 23:52
The RC has the same thing going for it. The only thing I would be concerned with however is that using a rig like this might be a bit cumbersome. Personally I'd use a 100k ohm potentiometer, rather than a rotary switch, and just set specific ranges as certain programs. This could also be reprogrammed to allow for smaller ranges -> more programs. That's up to you though. The math/physics behind the voltage divider idea would stay the same though, you'd just hook it to an analog input on the RC rather than one on the OI.
Unread 13-04-2006, 10:46
kaszeta's Avatar
kaszeta kaszeta is offline
FRC #0095 (Grasshoppers)
kaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of lightkaszeta is a glorious beacon of light
That's what Team 95 has done several times. We just had a pot on the robot, no detents, and ranges marked by the knob corresponding to each strategy. With the little knob we used, this allowed us to do up to 12 positions[1] without worrying about ambiguity, although after BAE we realized that we were only really using 4 of these positions, so we reprogrammed the switches.
I think next year I'll encourage the team to make something for the OI, however.
[1] Which meant that the switch went from 0 to 11. One team member asked "can't it just to to 10 instead." Of course, I had to answer "no, these go to 11." Only one person got the joke.
Unread 13-04-2006, 11:31
Personally I like having the ability to switch the program at the last minute from the OI. We normally do a binary selector of some sort mounted on our controls.
How could they not get that?? More people need to see that movie!
Unread 14-04-2006, 22:03
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Here's a quick way to turn a DP6T switch into a 6-position binary encoder that only needs three pins:
POS   A   B   C
1     0   0   0
2     1   0   0
3     0   1   0
4     1   1   0
5     0   0   1
6     1   0   1
Name:	DP6T binary.jpg
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 15-04-2006, 15:55
I found the following 11 detent potentiometer that is cheap: http://jameco.com/webapp/wcs/stores/...uc tId=286512
Unread 12-04-2006, 07:29
There are pots that exist that have detents built in but there are generally used for volume controls (are log taper, 10K) and have 10-12 detent positions. A better solution is to pick up a six position switch at Radio Shack.
http://www.radioshack.com/search/ind...ar y%20switch
This switch is easily modified to become a twelve position switch by bending one of the stopper tabs out of the way and cutting one of the contact springs. Wire 9.1K ohm resistors from each terminal to the one next to it to form a series string. When you are done, you have a stepped 100K pot. Wire as you would any pot to an analog input on the OI and then set your programmers to work. RS has some nice shiny knobs as well. If you would like to see one in action, stop by our pit in Atlanta.
Unread 12-04-2006, 21:59
Engineering Mentor
FRC #0254
Are you saying to use the 9.1k resistors if I wanted to have 12 positions? Would I still use the 15k resistors if I were to only use the 6 positions?
-Travis Covington
Unread 12-04-2006, 22:04
You can use either. If you use the 6 position switch, 15k resistors will give your programmers a little more leeway to distinguish one "step" from another.
Unread 12-04-2006, 23:28
For an OI-connected selector, you definitely want the maximum resistance to be just under 100k, and the minimum resistance should probably be at least 2k to keep from overloading the +5 source. That's why I suggested 15k for six positions. 9.1k will be fine for 11 steps, but I think it's a little too high for comfort if you want 12.
The total series value of an RC-connected "stepped potentiometer" is not that critical, but 100k is still a good target.
Best source for a potentiometer? railerobotics Electrical 20 28-11-2007 22:24
Confused about potentiometer values Kirk Technical Discussion 4 11-03-2006 16:29
Potentiometer help Unholy Programming 4 07-02-2006 17:48
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
