Thread Tools |
Rating:
Display Modes |
Re: Potentiometer 5 or 6 detents
The rotary switch seems like a good solution, if it does in fact have solid feeling stops, so we could easily differentiate between the 6 positions.
The only problem is, I would be the one wiring it up and have practically zero electronics knowledge and would need some help selecting resistors and wiring it up to specific pins on the switch and the RC. If you guys could help me out there, It would be HUGELY appreciated. |
----- Rc ----- Rswitch <--the dashes are just spacers here... 5V--^v^v--|--^v^v--gnd ________Input Rc=R, Rswitch=#R I=(5V)/(Rc+Rswitch) Vinput=I(Rswitch)=(5V)(#R)/(R+#R)=(5V)(#)/(1+#) Hope this helps. Last edited by Adam Shapiro : 11-04-2006 at 23:18. |
EDIT: It seems the OI manual suggests 100k ohms for a value. This seems resonable as it will only allow for a very small amount of current between 5V and gnd (I=V/R=5/(100000)=50uA). This is for safety as well as to prevent against large flows of current when using the OI. Don't forget the OI has its own built in fuses to protect itself, but you still want to be careful. Last edited by Adam Shapiro : 11-04-2006 at 23:41. |
My plan was to mount it on the RC.
I think next year I'll encourage the team to make something for the OI, however. [1] Which meant that the switch went from 0 to 11. One team member asked "can't it just to to 10 instead." Of course, I had to answer "no, these go to 11." Only one person got the joke. |
#8
Here's a quick way to turn a DP6T switch into a 6-position binary encoder that only needs three pins:
POS A B C 1 0 0 0 2 1 0 0 3 0 1 0 4 1 1 0 5 0 0 1 6 1 0 1 |
#10
I found the following 11 detent potentiometer that is cheap: http://jameco.com/webapp/wcs/stores/...uc tId=286512
#11
There are pots that exist that have detents built in but there are generally used for volume controls (are log taper, 10K) and have 10-12 detent positions. A better solution is to pick up a six position switch at Radio Shack.
http://www.radioshack.com/search/ind...ar y%20switch This switch is easily modified to become a twelve position switch by bending one of the stopper tabs out of the way and cutting one of the contact springs. Wire 9.1K ohm resistors from each terminal to the one next to it to form a series string. When you are done, you have a stepped 100K pot. Wire as you would any pot to an analog input on the OI and then set your programmers to work. RS has some nice shiny knobs as well. If you would like to see one in action, stop by our pit in Atlanta. |
#12
Are you saying to use the 9.1k resistors if I wanted to have 12 positions? Would I still use the 15k resistors if I were to only use the 6 positions?
#13
The total series value of an RC-connected "stepped potentiometer" is not that critical, but 100k is still a good target. |
#15
Here is a photo of our switch from last year, which was connected to the RC. It’s a six position switch with five 22k resistors (100k / (# positions - 1) = 20k, 22k was the closest we could find at Radio Shack). The switch positions were then 0k, 22k, 44k, 66k, 88k, & 110k. This would give analog values of about 0, 205, 410, 615, 820, and 1024. In the autonomous code, we looked for a range of 205, centered on each of those values.
void User_Autonomous_Code(void)
switch (((Get_Analog_Value( rc_ana_in01 )+100)/205)+1) //read autonomous switch
case 1: //switch position 1
while (autonomous_mode) /* DO NOT CHANGE! */
if (statusflag.NEW_SPI_DATA) /* 26.2ms loop area */
Getdata(&rxdata); /* DO NOT DELETE, or you will be stuck here forever! */
/* Add your own autonomous code here. */
Putdata(&txdata); /* DO NOT DELETE, or you will get no PWM outputs! */
break; //end of case 1
case 2: //switch position 2
default:
// something's wrong - do nothing
} //switch
} //User_Autonomous_Code
| Best source for a potentiometer? | railerobotics | Electrical | 20 | 28-11-2007 22:24 |
| Confused about potentiometer values | Kirk | Technical Discussion | 4 | 11-03-2006 16:29 |
| Potentiometer help | Unholy | Programming | 4 | 07-02-2006 17:48 |
| Potentiometer Help! | thoughtful | Programming | 4 | 18-02-2005 08:21 |
| Potentiometer | Joshua May | Technical Discussion | 8 | 22-05-2004 19:51 |
