Go to Post Collaboration works. DO IT. - Travis Hoffman [more]
Unread 11-04-2006, 19:37
kiettyyyy's Avatar
kiettyyyy kiettyyyy is offline
FRC #1538 (The Holy Cows)
kiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond reputekiettyyyy has a reputation beyond repute
Send a message via AIM to kiettyyyy
Potentiometer 5 or 6 detents
Hey everyone!
I'm currently looking for a potentiometer(that you can wire onto the robot controller) that has at least 5 or 6 detents that can click into those positions.
Does any body have any recommendations to where we can purchase these potentiometers? Let us know
Thanks!
-Kiet Chau
2004-2008 - Software Developer/Driver on Team #968
2008-2011 - Software Developer/Coach/Mentor/"Engineer" on Team #968
2011-Present - Mentor & Engineer on Team #1538
www.team1538.com
Unread 11-04-2006, 19:42
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
Re: Potentiometer 5 or 6 detents
What are you trying to use it for? You might want to be careful if you're using a pot for anything relatively large, it may be hard to calibrate and to prevent from breaking. We attempted to put a pot on a rotation table to limit it's rotation to 180 degrees at one point, but a faulty autonomous program would have none of that! You may want to consider using rotary encoders or some other means of measurement.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 11-04-2006, 19:57
I dont think Ive ever seen a stand-alone pot that had position detents. I have seen pots with knob designs that used detents - but I think they were custom designed for the application
ie, use an off the shelf pot, but make your own knob or level with click-stops where you want them to be.
Unread 11-04-2006, 19:58
Travis Covington's Avatar Unsung FIRST Hero
Travis Covington Travis Covington is offline
Engineering Mentor
FRC #0254
Travis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond reputeTravis Covington has a reputation beyond repute
Send a message via AIM to Travis Covington
We want to use it to select autonomous modes. Anything under 12 detents will work. We are just having trouble actually finding any. I know some of you have used these... a part number would be great! Thanks!
-Travis Covington
2008-2017 - Engineering Mentor of Team 254
2001-2008 - Engineering Mentor of Team 968
1998-2001 - Mechanical Director/Driver/Member of Team 115
Unread 11-04-2006, 20:03
It seems like it may be rather hard to find such a pot. You may want to just use a standard pot, however, and program the robot to respond to ranges of analog input rather than a specific value. So that you could turn it approximately to the correct program, rather than the specific value.
If you don't have too many autonomous programs you could use a series of switches as a binary selector. You'd only need 5 bits (5 inputs out of the 4 ports) to cover the 12 modes you seem to need and more.
Unread 11-04-2006, 20:17
Engineering Mentor
FRC #0254
We found one on digikey, but it doesnt have a shaft (to accept a knob) and is rather small at only 16mm wide.
Thanks for the help, we will keep looking. I am sure they are out there.
-Travis Covington
Unread 11-04-2006, 20:33
Kris Verdeyen's Avatar
Kris Verdeyen Kris Verdeyen is offline
LSR Emcee/Alamo Game Announcer
FRC #0118 (Robonauts)
Kris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond reputeKris Verdeyen has a reputation beyond repute
If you look around page 1433 of the digikey catalog (which I totally knew off the top of my head), you'll find a type of switch that might be better for your application. It's called a rotary switch, and they come in all kinds of configurations, including SP6T. You can solder a bunch of resistors around the terminals, and it will behave exactly how you described, and can look like a pot to the OI or RC.
...Only a few people are awake and they live in a state of constant total amazement. -JP Shanley, Joe vs. the Volcano
Unread 11-04-2006, 20:37
ZZII 527's Avatar
ZZII 527 ZZII 527 is offline
"Scale Electric Vehicle"
AKA: Shane Colton
FRC #0097
ZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond reputeZZII 527 has a reputation beyond repute
Send a message via AIM to ZZII 527
Edit: Kris beat me to it by a few minutes. And with impressive knowledge of the Digikey catalog!
One way to get approximately what you want is to wire up a SP6T switch as follows:
+5V connected to a resistor R, then to the common lead.
Signal wire should be joined to common lead.
Lead 1: straight to GND
Lead 2: thru resistor value R/4 to GND
Lead 3: thru resistor value 2R/3 to GND
Lead 4: thru resistor value 3R/2 to GND
Lead 5: thru resistor value 4R to GND
Lead 6: thru BIG resistor to GND
This sets up a 6-setting voltage divider which will give the following voltages across the common resistors:
Position 1: ~0V
Position 2: 1V
Position 3: 2V
Position 4: 3V
Position 5: 4V
Position 6: 5V
You can set up ranges in the program to check for this. These resistor ratios can all be approximate, but that gives you the widest separation possible for the analog input, reducing the risk of mistaking one mode from another.
Of course, binary inputs are simpler if you have enough pins.
MIT Mechanical Engineering
>> College Mentor, Team 97: Cambridge Rindge and Latin School with The Edgerton Center, MIT Mechanical Engineering, Bluefin Robotics, and Draper Laboratory
>> Alumnus, Team 527: Plainedge HS
Unread 11-04-2006, 20:44
See Kris Verdeyen and eugenebrooks posts in this thread for a solution on the OI that doesn't require any additional hardware. http://www.chiefdelphi.com/forums/sh...ad.php?t=44662
Unread 11-04-2006, 20:49
Yeah, what Kris said. The TechnoKats used a many-position rotary switch with resistors between each contact as an automode selector on the KatsKlaw OI in 2004.
Unread 11-04-2006, 22:21
forgive my ignorance of this years OI, is the red LED display still able to display user selected numbers?
set your code to read a joystick or pushbutton input - everytime you push the button increment a counter, and display it on the OI LED numeric output - that is your autom mode number
you could have up to 256 different auton modes that way.
Unread 11-04-2006, 22:43
Engineering Mentor
FRC #0254
The rotary switch seems like a good solution, if it does in fact have solid feeling stops, so we could easily differentiate between the 6 positions.
The only problem is, I would be the one wiring it up and have practically zero electronics knowledge and would need some help selecting resistors and wiring it up to specific pins on the switch and the RC. If you guys could help me out there, It would be HUGELY appreciated.
-Travis Covington
Unread 11-04-2006, 22:53
The idea here isn't as much the actual resistance as the concept. The current through the circuit I is defined as I=V/Rtotal where Rtotal is the sum of the two resistors: the initial one connecting from 5V to the common lead, and the secondary resistor from the switch to ground. Then the voltage measured at the common lead can be calculated as V=IRswitch (the resistance from the switch to ground). The actual R value will cancel out.
----- Rc ----- Rswitch <--the dashes are just spacers here...
5V--^v^v--|--^v^v--gnd
________Input
Rc=R, Rswitch=#R
I=(5V)/(Rc+Rswitch)
Vinput=I(Rswitch)=(5V)(#R)/(R+#R)=(5V)(#)/(1+#)
Hope this helps.
Unread 11-04-2006, 23:10
Engineering Mentor
FRC #0254
Originally Posted by Adam Shapiro
Hope this helps.
Sort of... In reality, I still have no idea where to start. I am an ME/MFE with very little electronics experience... so please bear with me.
-Travis Covington
Unread 11-04-2006, 23:12
Heh, not a problem. You should probably choose some value of R in the 10000s to protect the input (I believe).
EDIT: It seems the OI manual suggests 100k ohms for a value. This seems resonable as it will only allow for a very small amount of current between 5V and gnd (I=V/R=5/(100000)=50uA). This is for safety as well as to prevent against large flows of current when using the OI. Don't forget the OI has its own built in fuses to protect itself, but you still want to be careful.
Best source for a potentiometer? railerobotics Electrical 20 28-11-2007 22:24
Confused about potentiometer values Kirk Technical Discussion 4 11-03-2006 16:29
Potentiometer help Unholy Programming 4 07-02-2006 17:48
Potentiometer Help! thoughtful Programming 4 18-02-2005 08:21
Potentiometer Joshua May Technical Discussion 8 22-05-2004 19:51
