Go to Post If you have a problem with a team, go to that team and address it with them. Don't air your slanderous opinions here for all to see. - Andy Baker [more]
Unread 12-04-2006, 11:23
Funzo Funzo is offline
Funzo can only hope to improve
coursework, help please.
im uising windows programing language and basically in need to make a booking file print in a human friendly kind of way. Here is the code i am using:
try
readfile := false;
read(bookingFile, Abooking);
readfile := true;
while
readfile
do
memo1summary.lines[1] := Abooking.eventtitle;
memo1summary.lines[2] := Abooking.name;
memo1summary.lines[3] := Abooking.audience;
memo1summary.lines[4] := Abooking.event;
memo1summary.lines[5] := Abooking.time;
until
//end of file
end;
all i need is something that will make it recall each booking until the end of the file. I also need to change tdate into a string. Any help would be much appreciated. thanks.
Unread 12-04-2006, 11:27
Re: coursework, help please.
you want someone to do your homework for you online?!
Unread 12-04-2006, 11:37
Adam Shapiro's Avatar
Adam Shapiro Adam Shapiro is offline
FRC #0555 (Montclair Robotics)
Adam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud ofAdam Shapiro has much to be proud of
Send a message via AIM to Adam Shapiro
What language is that? I can't seem to recognize it as any of the ones I've seen at all.
Mentor to Teams 555, 1929, and 2070!
Currently working in hardware design at Cisco.
Cornell University DARPA Urban Challenge - http://www.cornellracing.com
Co-Captain Team 555 - 2003,2004,2005
Trust, Love, and Magic
Unread 12-04-2006, 11:43
Jack Jones Jack Jones is offline
Retired
Jack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond reputeJack Jones has a reputation beyond repute
Been a long time, but looks like Pascal?
Unread 12-04-2006, 11:50
Stuart's Avatar
Stuart Stuart is offline
#include coffee.h
FRC #1745 (P51- Mustangs)
Stuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond reputeStuart has a reputation beyond repute
Send a message via AIM to Stuart
well I know in C++ you can do
while(getline << eventitle)// isnt it great that streams can return a bool
//other stuff.
I have know idea how to do a End of file test for . . what ever language your useing. but if I were you I would read the documentation on the read(), and readfile functions.
edit ok Ive read up on this . .
if the readfile function has an error(like the file has no more info in it) it will return a 0
so I would suguest that you use that for your else(its not a fancy way of doing it but it will get it working)
as for changeing the date to a string. . . thats something that you can figure out
Proud mentor of Team #1745 the P-51 Mustangs
If at first it doesn't work, use a hammer.
If that doesn't work, use a bigger hammer.
Unread 12-04-2006, 11:52
Yes i do want you to do my homewok for me and i thought you guy were surposed to be nerds. Im using delphi.
Unread 12-04-2006, 12:17
we are nerds. Some of us have PHDs in nerdology
but you are on the wrong forum. We are robot nerds, not Delphi language nerds:
http://www.chiefdelphi.com/forums/sh...ad.php?t=29944
Unread 12-04-2006, 12:40
Tristan Lall's Avatar
FRC #0188 (Woburn Robotics)
That's Delphi, (formerly Object Pascal). (Some of us were "Delphi language nerds" in a former life....)
Alright, what's going on here? You want to read from a textfile, and pass the output to a memo box? First of all, if you're using the try structure, you're probably familiar with exception handling. Can I assume that you want to check the status of the file reading operation, and throw an exception on an error?* And further, I'll assume that you're using the built-in textfile routines (check the Delphi help for the code example for AssignFile), and not the binary file routines.
To read until the end of file, try using the EOF function to determine whether you've reached the end of the file (check the documentation; there's surely an example that you can study).
Don't call your variable "readfile". There's a built-in function with that name already. (It won't interfere with your program, unless you use ReadFile, but it's bad style.)
To reiterate, you're in the wrong place for Delphi help; didn't you see the message when you posted that tells you that this forum isn't normally used for the Delphi language?
*This is ugly, from a UI point of view. Try to make a "friendly" error message, rather than let the user see a Windows exception. To do this, you could use try with the except block.
