Go to Post It shouldn’t be about whether or not you think it’s easy or not, it’s about whether or not you think the effect of the change would be a positive step for our country. - Bill Gold [more]
Unread 12-04-2006, 13:16
augeas augeas is offline
FRC #0027
augeas is an unknown quantity at this point
digital outs
Is it possible to send a signal to the same digital output on the controller more than once in a program cycle? I know the putData() function is only called once every slow cycle, but is it possible to have another function that only sends data to the digital outputs that is called more often in order to speed things up?
Unread 12-04-2006, 13:26
sciguy125 sciguy125 is offline
Electrical Engineer
AKA: Phil Baltar
FRC #1351
sciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond reputesciguy125 has a reputation beyond repute
Send a message via AIM to sciguy125 Send a message via MSN to sciguy125 Send a message via Yahoo to sciguy125
Re: digital outs
The digital i/o's are directly connected to the PIC. Anything that happens to them happens simultaniously on the connectors. So, if you modify a digital i/o, it'll change right away on its respective connector. My understanding is that the only ones that don't happen right away are the PWM outputs, but that's because they take some extra processing.
EDIT:
Oh wait. I just noticed that this is in the CMUcam forum. Were you asking about the camera or the robot controller?
-----BEGIN GEEK CODE BLOCK-----
Version: 3.12
GE/S/P a-- e y-- r-- s:++ d+ h! X+++
t++ C+ P+ L++ E W++ w M-- V? PS+ PE+
5- R-- tv+ b+ DI+++ D- G
------END GEEK CODE BLOCK------
Unread 12-04-2006, 14:07
FRC #0027
Re: digital outs
EDIT:
Oh wait. I just noticed that this is in the CMUcam forum. Were you asking about the camera or the robot controller?[/quote]
Thanks for your help! That makes a lot of sense and really clears things up. I was asking about the robot controller... I didn't realize I put this in the CMUcam forum and not the programming forum.
Unread 12-04-2006, 14:20
Electrical Engineer
Rookie Year: 1995
Re: digital outs
Yes you can. Digital inputs and outputs are directly input and output by you.
See my post here for an example of using digital outputs between putdata statements.
Good luck.
Mike
Mike Betts
As easy as 355/113...
No value in digital ins using NASON pressure switch. Ari Allyn-Feuer Programming 1 18-02-2006 01:18
Digital Caliper as a Digital Readout on Small Mill sanddrag Technical Discussion 9 13-10-2005 22:51
Dynamic Input/Output Changing Paolo Control System 6 23-09-2004 19:09
digital inputs not valid just after initialization? WizardOfAz Programming 2 26-01-2004 13:21
