Go to Post Failure is not an option. - [more]
Unread 12-04-2006, 18:40
Hutch Hutch is offline
NOTAG
Hutch will become famous soon enoughHutch will become famous soon enough
Strange Camera Problems
At the last regional we were at , we finally started really using our camera... It was working great and tracking and everything until we noticed a problem: whenever we turned on our ball collection mechanism, the camera would freak out and go all the way to the left.
Since our collector has two fisher price motors, we tried to just run one at a time: with only one running (regardless of which), it would work just fine (maybe be a wee bit jerky but not freaking out). The motors are located on the complete opposite side of the robot from our camera (camera is top left, motors are bottom right).
We thought it might be the Van De Graff generator thing, but we tried grounding things and it didn't change; it also happens immediately so we ruled that out.
We are really at a loss as to what the problem could be, so anyone have any ideas?
Unread 12-04-2006, 18:51
Andrew Blair's Avatar
FRC #0306 (CRT)
Re: Strange Camera Problems
Here's the one thing I can think of:
When you turn on the Fisher Prices, unless you use some ramp code, the motor brushes arc. Now, somewhere, I heard some tech nonsense about collapsing magnetic fields when arcing occurs(or rather, the arcing is caused by the collapse of the field), and back EMF, and lots of junk like that. Perhaps this could be causing it. I'm sure someone brighter than I can elaborate.
Because it only occurs when you run the collection mechanism, which only contains FP's, I wouldn't think it's a current drop issue, though that is possible. The only thing I don't get is why it occurs only when *both* motors are run. Maybe you've got your FP power lines near your camera wires, and are inducting a power or signal current. Interesting...
-Sir Francis Bacon
-Albert Einstein
Unread 20-04-2006, 14:10
Alex G Alex G is offline
FRC #0201 (FEDS)
Alex G is an unknown quantity at this point
It can be because of noise in the PWM outputs. If the camera draws power from the PWM outputs, I would recommend using an LC(coil-capacitor) filter before the camera. He had similar problems when the backup battery was low. Noise can temporarily lower the voltage, so i suspect this to be the cause.
Here's some info on the LC filters:
http://www.tpub.com/content/neets/14.../14179_204.htm
Unread 20-04-2006, 22:58
Keith Watson Keith Watson is offline
FRC #0957 (WATSON)
Keith Watson is just really niceKeith Watson is just really niceKeith Watson is just really niceKeith Watson is just really nice
First dump your pwm values to the terminal window to ensure that they are what you expect.
Long runs of multiple wire cable (like pwm wire, also known as servo wire in the world of radio control models) are known to act as excellent antennas. DC brushed motors are an excellent source of noise for that style of cable. Ways to reduce the noise that is picked up include twisting the cables, adding chokes (magnetic rings) at each end of the cable, adding a filter (capacitors) where the power wires connect to the brushed motors, etc.
Keith Watson - Professional Software Engineer
No relation to "Kevin" Watson, who created the camera tracking code.
Unread 23-04-2006, 17:02
coldabert's Avatar
coldabert coldabert is offline
The Dude
FRC #0888 (Robotiators)
coldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of lightcoldabert is a glorious beacon of light
Send a message via AIM to coldabert
To isolate the problem, use an oscilloscope to monitor voltages your pwms.
This might seem like too much for a simple problem, but it will definitely show you which systems are not causing the camera to move.
(Plus its cool and you can tell people that the wavy lines are talking to you in computerspeak)
Let me know if you need help setting up the scope.
Unread 25-04-2006, 12:45
FRC #0957 (WATSON)
To be clear, the signal line is monitored and you watch the width of the pulse. Pretty cool.
Problems Combining Camera Code and Driving Code cmurdoch Programming 20 10-02-2007 16:34
Camera \ EMF problems... zachriggle Electrical 17 02-05-2006 23:48
Camera Servo Problems pi_guy578 Programming 2 28-01-2006 13:17
Camera Problems pickle Programming 21 20-01-2005 20:43
Camera "Grab Frame" Problems Isabel Cole Programming 7 15-01-2005 21:53
